Counter-steering
meyrick
PostPosted: 16:55 - 25 Jan 2005    Post subject: Counter-steering Reply with quote
I just had a really good ride...and here's why:
My dad seems to think that steering a bike is a natural instinct and when questioned seems to have absolutely no idea how he does it. He says "You just choose a line and follow it." He also said that counter-steering is something you have to be taught on a race track.
My instructor refused to explain counter-steering in any detail claiming that it was too confusing. Rolling Eyes
So, when dotti posted a link to a website that explained counter steering I took notice. In fact the advice from most sources appears to be that you literally turn the handlebars in the opposite direction to the one you want to go in. This is obviously complete b****cks and probably why my instructor didn't want to talk about it. Anyway, after reading countless articles and a few papers on gyroscopic precession, I finally figured it out.
Now that I actually know how to steer, I found myself going round corners twice as fast with 10x the confidence. I wish someone (my instructor?) had bothered to tell me how to do this from the start.
Ride was so good I came home and dropped the bike putting it onto the stand (don't ask). No damage this time though Thumbs Up Very Happy
Paul Smile
PostPosted: 16:59 - 25 Jan 2005    Post subject: Re: Counter-steering Reply with quote
Erm, Confused, I must be doing something wrong then.
That’s what I’ve always done and it’s always worked for me Smile, I might not be quite so literal when describing it, but that’s about the sum of it.
Obviosuly you don’t turn the bars a large amount; but you never do unless you’re going very slowly anyway. In the same way, in a car you are only turning the steering wheel slightly at high speed.
nc30 chick
PostPosted: 17:02 - 25 Jan 2005    Post subject: Reply with quote
Erm, , I must be doing something wrong then.
That’s what I’ve always done and it’s always worked for me , I might not be quite so literal when describing it, but that’s about the sum of it.
Me too, its the only way I can get my NC around a bend at more than 25mph! You countersteer without even thinking about it. Its only when you do think about it and take notice of what you are doing that you realise you are doing it anyway to a certain degree.
Gazdaman
I did a trackday!!!
PostPosted: 17:04 - 25 Jan 2005    Post subject: Reply with quote
Counter steering is natural.
Just ride along in a straight line, next time you're cruising through a 30, just push the right bar gently and the bike will fairly violently lean to the right.
It's nothing complicated, and you do it without thinking, but once you've seen it work whilst going along a road you wonder why the hell it works.
Gaz
meyrick
PostPosted: 17:50 - 25 Jan 2005    Post subject: Reply with quote
Shocked Shocked Shocked Shocked
Ooooookay. My mistake, obviously learning here....
You mean you literally turn the handlebars in the opposite direction to the turn, within the same 2D plane of movement??? Obviously this is not what I am doing, nor would I agree that I am doing it 'automatically.' Oh balls! I'm now officially confused all over again!!! Back to the text book...
Paul Crying or Very sad
Edit: Oh, the irony! Crying or Very sad
instigator
PostPosted: 17:53 - 25 Jan 2005    Post subject: Reply with quote
No, lol, just apply a little bit of force to the right hand side of your bars and you'lll go left. I guess you dont physically turn the bars when you're going along at 50mph Laughing Just a slight even push and you'll feel it turn Thumbs Up
PostPosted: 18:03 - 25 Jan 2005    Post subject: Reply with quote
The bars do only turn very slightly.
This couter-turning causes the bike to lean over in the opposite direction, this cause you to enter the turn quicker. This is the only way to turn a bike at speed, so you will be doing this.
If you turn them a signficant amount the bike will lean over very quickly.
Try going along in a straight line on an empty road at around 50mph. Aplly pressure to the bars as if to turn the right. You will find the bike leans to the left, to stay going straight you will have to lean your body weight the other way.
Gazdaman
I did a trackday!!!
PostPosted: 18:06 - 25 Jan 2005    Post subject: Reply with quote
I guess you meant a bit of force on the right hand side of the bars i.e wheel goes left as you sit on the bike and the bike will pitch right...
It's not really turning the bars, just putting a bit of pressure on one side.
Gaz
instigator
PostPosted: 18:31 - 25 Jan 2005    Post subject: Reply with quote
You guess right Laughing
My bad Thumbs Down
meyrick
PostPosted: 18:33 - 25 Jan 2005    Post subject: Reply with quote
That's some trippy s**t. Shocked Basically before I was slowing down to about 10mph and coasting round turning into the corner. Not very practical in a 50 limit. Today I was turning by moving the handlebars up and down....meh, I'm going to draw a diagram! Right, as you can see from this beautiful diagram *cough*, today I was steering by turning the bars through a different plane of motion. Is this wrong or bad in any way? I found I could steer much more precisely like this than before. Got to get to the bottom of this...
*EDIT: Diagram removed due to its exreme rubbishness
meyrick
PostPosted: 19:07 - 25 Jan 2005    Post subject: Reply with quote
Ok, I think I have it sorted in my head now. If I am trying to force one side of the bars up and the other down and my arms are not perpendicular to the ends of the bars in that plane of movement I will inevitably apply some turning force to the bars in the opposite direction to the direction of travel...et voila! Counter steering! Smile
...I think...I hope.
Paul Smile
PostPosted: 19:14 - 25 Jan 2005    Post subject: Reply with quote
Counter steering only works above a certain speed.
It works because of the gyroscopic effects of the wheel... turn it one way and the wheel will lean the opposite way.
Below this certain speed this does not have a big enough effect, so you steer 'normally'.
As I said, if possible, just find an empty road and have a play.
Note that intentionally countersteering only really needs to be done if you need to turn faster. A useful thing to know about, but the knowledge is not required to ride a bike Smile.
To show quite how instinctive it is; you do do it on a push bike to a certain extent. I rode a friends push trike. Ended up going in circles and almost hit several parked cars.
Because you steer 'normally', rather than counter steering, the natural reaction to correct a slight steering error is to turn that way more, to counter steer away. On the trike this made it worse, so your brain naturally makes you do it more. Hilarious to watch Smile.
ian_s
PostPosted: 19:41 - 25 Jan 2005    Post subject: Reply with quote
Yeah, I read that article as well. After reading it several times and lots of arm movements I concluded that you do it naturally to keep balance.
Gazdaman
I did a trackday!!!
PostPosted: 20:38 - 25 Jan 2005    Post subject: Reply with quote
Meyrick the bars only will turn in one plane, unless something is seriously wrong with your bike.
Just coast along a straight road at about 40mph, loosen your grip on both bars, and gently push one side of your bars. The bike will lean over as if it's going to turn the other way.
Go and try it, those diagrams are helping no-one.
Gaz
meyrick
PostPosted: 21:40 - 25 Jan 2005    Post subject: Reply with quote
Lol Laughing They are awful aren't they. Embarassed There, I got rid of them. I really can't explain effectively what I was doing today, diagrams or no, so I won't bother.
Thanks everyone for your input, I will go out on the bike and try a few things before I make any more embarrassing faux pas.
Paul. Smile
AcIdBuRnZ
PostPosted: 01:21 - 26 Jan 2005    Post subject: Reply with quote
Laughing Laughing Laughing
Sorry, just reminds me of when I first though I was going to see what this counter steering was all about.
I was amazed at just how quickly the bike would fall into the corner with a quick push on the bars. I then figured how Rossi and Co. are able to ride like that.
It's not complicated, just basic physics. But a bit of a head fuck at first..... so I turn right to steer left? WTF? Laughing
Now it's natural, but because I know how it work, you learn to use it more effectively. Makes riding easier I think, as you don't need to hang off the bike like a monkey on every corner!!! (G is the exception here Laughing )
PostPosted: 08:45 - 26 Jan 2005    Post subject: Reply with quote
A quick note;
Hanging off the bike will only make you turn the other way!
Try taking your hands off the bars and lean off the bike a bit one way. The bike will lean the other way to compensate. You can then center yourself if you want to actually turn that way.
Hnaging off like a monkey always helps give you a bit extra safety factor for 'normal' turning though; I have been known to hang off a near vertical dr600 when turning in the wet on slippy roundabouts.
meyrick
PostPosted: 09:46 - 26 Jan 2005    Post subject: Reply with quote
Erm...maybe later...*cough* Shocked Wink
DM
PostPosted: 15:28 - 26 Jan 2005    Post subject: Reply with quote
I read up on this a long time ago but never actually used it to throw bikes around until about two years ago when I started riding the RX. When I was riding an RT125 for awhile I HAD to use it due to the extra weight over the 2-strokes I was used to. It's also the only way to judge how easily a bike can change direction. Try riding a scooter through an S-curve and yucking the handlebars from one corner into the other and it'll go up and over onto the other side in a shot. That's one reason I used to have so much fun riding my friend's Runner. I could change direction in a split second and arrive at whatever lean angle I wanted to with high precision.
fuzz
PostPosted: 20:30 - 26 Jan 2005    Post subject: Reply with quote
Did you never do that experiment at school or a science museum with the bicycle wheel. You hold it at arms length, arms parallel to the floor, by the axle and spin it. If you turn the axle to the left, the wheel leans to the right and your right arm ends up below your left. It's exactly the same principle.
Just remember to push in the direction you want to travel off throttle, and when you reach the desired lean angle to make the corner, open the throttle slightly to hold you at that angle.
meyrick
PostPosted: 21:21 - 26 Jan 2005    Post subject: Reply with quote
Nope, never did do that experiment. In fact I'm pretty sure I never did any work on gyroscopic forces, even after a year of Physics at University...must have had a hangover that day Laughing
Just read a counter-steering FAQ on the survival skills website. They reckon it actually doesn't have much to do with gyroscopic forces at all, more inertia and camber thrust...whatever that is. Anyway, can't be arsed with the physics anymore. Just going to find a wide empty road, give the bars a poke to the right and see what happens (Famous last words?).
fuzz
PostPosted: 21:24 - 26 Jan 2005    Post subject: Reply with quote
By jove you have it. That's the only way you'll understand it and the only way to put it to good use Thumbs Up
MADDOG
PostPosted: 00:04 - 28 Jan 2005    Post subject: Reply with quote
[u]Counter steering for dummies[/u]
1) Hold your handle bars.
2) Set off
3) Get some speed up
4) Approch the corner
5) Push the rights side of the bars to lean left an turn left
or
5.a) Push the left side to leand right and turn right
simple effective and to the point who care how it works it just does... nuff sed
thats exactley how my CBT instructor taught me
Aprilia RS125 Harada. has gone now have a SV650s K5
Are you meant to scrape knee slides or rip them clean off?
Knisis
PostPosted: 09:24 - 28 Jan 2005    Post subject: Reply with quote
After reading about counter-steering and just general riding I came up with this easy to understand principle.
To turn left - You lean to the left - Which puts weight on your left hand bar - Which turns the wheel slightly right = Counter Steer
AcIdBuRnZ
PostPosted: 11:07 - 28 Jan 2005    Post subject: Reply with quote
By jove he's got it Clapping Wink Laughing
The last post was made 21 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 134.24 Kb
