Air In Braking System ?
barnesy213
PostPosted: 13:29 - 07 Jan 2015    Post subject: Air In Braking System ? Reply with quote
basically as the title suggests i think i may have some air in the system on my bike (2009 honda cbr 125) .
when i press my foot on it (back brake) there is hardly any feel in it , its like a switch either on or off and also when i have the back brake on when i'm on a hill it will start to roll back and make a creaking noise untill i apply more pressure too it , but if i use the front brake its fine and the front has plently of feel in it.
so i'm wondering if there is air in the system or if some parts may need replacing .
any help is much appreciated many thanks .
DrSnoosnoo
PostPosted: 13:32 - 07 Jan 2015    Post subject: Reply with quote
The way to check would be to try and bleed the system, do you know how to do this?
EDIT- is there fluid in your reservoir?
Andy_Pagin
PostPosted: 13:36 - 07 Jan 2015    Post subject: Reply with quote
Sounds more like a seized calliper to me. Air in a braking system either manifests itself by excessive lever/pedal travel, or a 'spongy' feel to the pedal movement.
barnesy213
PostPosted: 13:49 - 07 Jan 2015    Post subject: Reply with quote
Yeah i know how to bleed brakes , but would rather someone else help so i know i'd be getting it right lol and yes the brake fluid in reservoir is upto the max line .
[quote="snoosnoo"]The way to check would be to try and bleed the system, do you know how to do this?
EDIT- is there fluid in your reservoir?[/quote]
barnesy213
PostPosted: 13:51 - 07 Jan 2015    Post subject: Reply with quote
well what happens is when you press it nothing really happens then press it a tiny bit more and you can feel it slowing but sometimes it locks on , quite dangerous tbf
[quote="Andy_Pagin"]Sounds more like a seized calliper to me. Air in a braking system either manifests itself by excessive lever/pedal travel, or a 'spongy' feel to the pedal movement.[/quote]
PostPosted: 13:58 - 07 Jan 2015    Post subject: Reply with quote
Sounds like a piston sticking. Never mind bleeding, give your caliper and pistons a good clean and inspection.
monkeybiker
PostPosted: 14:39 - 07 Jan 2015    Post subject: Reply with quote
Are they the slide type brakes were you have pistons just on one side? Sometimes the sliding part can get stuck.
DrSnoosnoo
PostPosted: 15:28 - 07 Jan 2015    Post subject: Reply with quote
I took the "having no feel" to be kinda spongey (?).
Undo the probably 2 bolts that hold your caliper on, get the pads off and spray brake cleaner in and give it a scrub with a toothbrush, that's my method of sorting mucky pistons. Chuck a block of wood in there and pump the piston a bit to see a shiny bit, clean the rest up to look that nice.
Robby
Dirty Old Man
PostPosted: 19:12 - 07 Jan 2015    Post subject: Reply with quote
If it feels like an on/off switch, it's sticking. The rear caliper on the CBR125 is a traditional single piston sliding caliper, so there are lots of bits that can wear or seize. The whole things needs a strip down and clean, including removing the piston and seal and scraping out any corrosion from under the seal.
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 60.25 Kb
