Gilera Coguar cold start issue.
stuartadair
PostPosted: 12:44 - 08 Jan 2015    Post subject: Gilera Coguar cold start issue. Reply with quote
Hi folks,
Got a Gilera Coguar 125 which is a pain to start from cold. You have to wind the engine for about 5 minutes before it eventually fires. Once its warmed up a bit it starts first time.
Battery, plug and carb are both new and its spinning over fine. Mixture screw set to 2 turns out. Yes, I am using the choke!
I've done a compression test at 75psi which I suspect is low (Am I right?)
Could low compression cause my cold starting issues ?
If you think compression is low then first port of call will be the valve clearances I think.
Thanks
Stu
Taught2BCauti...
PostPosted: 14:58 - 08 Jan 2015    Post subject: Reply with quote
75psi sounds a bit low - if the valve clearances are good and you're not burning oil, you might need to take the head off for further checks.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 15:17 - 08 Jan 2015    Post subject: Reply with quote
Sounds quite low indeed.
stuartadair
PostPosted: 11:38 - 09 Jan 2015    Post subject: Reply with quote
It does use a little bit of oil so we might be looking at broken rings or general wear and tear on the barrel and piston then. I'll check the valve clearances today.
I don't suppose if anyone knows of a Chinese FM156 125cc engine will fit if I do need to replace parts. Its impossible to get hold of bits for this bike but the engine mounting points look very similar to a standard Chinese 125 engine.
The last post was made 11 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 39.22 Kb
