gp100 not starting
andyscooter
PostPosted: 17:46 - 06 Jan 2015    Post subject: gp100 not starting Reply with quote
bought as a project last year but only just got round to getting it started
cleaned the carb
cleaned the fueltank
new plug
new battery
now when i kick it over it is trying to start and runs for a second or two then cuts out
any ideas what it could be causing it
was running last year as it was moted in june
bradh511
PostPosted: 18:45 - 06 Jan 2015    Post subject: Reply with quote
These engine run points and could also do with a clean / resetting..
To me it sound like the engine isn't getting enough fuel when you had the carb apart did you reset the float hight etc..
Brad
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
Blue_SV650S
PostPosted: 19:38 - 06 Jan 2015    Post subject: Reply with quote
Try a bump-start, sometimes these things need a bit of further encouragement the first time after a layup! Thumbs Up
bypass2
PostPosted: 22:21 - 06 Jan 2015    Post subject: Reply with quote
Is the Petrol tap working. When you cleaned the tank out any thing blocking the petrol flow from the tap.
chrisjose1913
PostPosted: 12:39 - 08 Jan 2015    Post subject: Re: gp100 not starting Reply with quote
cleaned the carb
new plug
new battery
Did you check for a spark ?
1997 CB500
andyscooter
PostPosted: 16:36 - 08 Jan 2015    Post subject: Reply with quote
yes it runs for a second or two then cuts out
chrisjose1913
PostPosted: 19:40 - 08 Jan 2015    Post subject: Reply with quote
take the plug out and check it, tell me what colour it is and also check if it's wet. I had this issue.
1997 CB500
andyscooter
PostPosted: 07:50 - 09 Jan 2015    Post subject: Reply with quote
plug is clean as new but is wet
STONEY!
PostPosted: 08:12 - 09 Jan 2015    Post subject: Reply with quote
Is the plug resistant? If so bin it and get a non resistant plug for starters. Chances are if its wet its fucked anyway gp100's always foul plugs up quick if not setup just right. Here are some things I would check:
Have you put it together right? Ie with the carb cover on and most importantly both rubber bungs in the 2 holes on the carb case?
Is the air filter the right type and clean? Any air leaks between airbox and engine?
Is the exhaust clean inside or bunged up full of crap?
Any play in the crank?
Head/base gasket leaking?
Compression good?
Points clean and correctly adjusted?
Carb clean and correctly adjusted?
Coil/lead/cap in good condition/working correctly?
Oil pump correctly adjusted?
If all that is ok then its probably flooded. Good luck with that!
Gp100's are fussy little bastards so everything needs to be right!
andyscooter
PostPosted: 08:34 - 09 Jan 2015    Post subject: Reply with quote
Have you put it together right? Ie with the carb cover on and most importantly both rubber bungs in the 2 holes on the carb case? yes
yes and no
yes
no
no
Compression good?
yes
yes as far as i know
yes but will be changing it anyway
yes
cb1rocket
PostPosted: 10:38 - 09 Jan 2015    Post subject: Reply with quote
try easy start, if it does start and run briefly then your carb is probably blocked again, have you got a fuel filter fitted?
If no then compression is either no good or the spark isnt working under pressure inside the engine
The last post was made 11 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 69.32 Kb
