tokico 6 pots ( yawn)
devojunior
PostPosted: 13:23 - 09 Jan 2015    Post subject: tokico 6 pots ( yawn) Reply with quote
Hello and good afternoon to all those who havnt died from the wind today,
i have a zx6r with the dreaded tokico 6 pots which have been stripped cleaned new pads ect but im really struggling to get a solid lever even with braided lines iv tried the convetional way to bleed and also reverse bled them with big fu%$ off syringe but still a spongy lever
please see other post about z1000 4 pot nissin conversion.
CaNsA
PostPosted: 13:27 - 09 Jan 2015    Post subject: Reply with quote
Master cylinder rebuild?
whitedevil
PostPosted: 13:49 - 09 Jan 2015    Post subject: Reply with quote
spongy leaver means air in the system still. My zx6r has a bleed nipple at the master cylinder, maybe you overlooked this one?
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
devojunior
PostPosted: 14:11 - 09 Jan 2015    Post subject: Reply with quote
first iv heard of that lol
Wull
PostPosted: 14:53 - 09 Jan 2015    Post subject: Reply with quote
Bleed at the m/c as well
I had one of those bleed nipples on my Gixer thou at the m/c,makes it easier but just use a rag to stop the fluid going over the plastics.
Pump the lever a few times then crack the banjo bolt open,then repeat a few times.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Snorty
PostPosted: 15:37 - 09 Jan 2015    Post subject: Reply with quote
I just replaced them with 4-potters on the gixxer... direct swap no brackets required, instant brake improvement. Just need a pair for the ZX9 now.
RhynoCZ
PostPosted: 16:59 - 09 Jan 2015    Post subject: Reply with quote
Get rid of them, and get some 4 pots from Nissin. ZXR P1, happy owner of 4 pots from Nissin. Thumbs Up
Here: https://www.bikechatforums.com/viewtopic.php?t=278676&postdays=0&postorder=asc&start=0
I already moved the pictures, but you can see them here: https://s970.photobucket.com/user/RhynoCZ/library/ZX7R?sort=4&page=1 Thumbs Up
Fizzer Thou
PostPosted: 18:03 - 09 Jan 2015    Post subject: Re: tokico 6 pots ( yawn) Reply with quote
If you had reasonable pressure before the rebuild then there is not much of a reason to not get pressure now other than for air in the system.
I have some Sumitomo 6 pot calipers on the front of my Exup1000 and had air in the system after fitting them.By removing the front master cylinder from the clip on I tilted it so that the air trapped around the banjo bolt moved to the bleed hole in the master cylinder and I was then able to bleed it thoroughly and have had no loss in pressure.
Not sure what it is about the Tokico 6 pot calipers.They have not got a good reputation on TL1000R or GSXR1000K1/K2 models either Rolling Eyes
Always have a 'Plan B'
YBR Ric
PostPosted: 18:06 - 09 Jan 2015    Post subject: Reply with quote
Have you wrapped the bleed nipple threads with PTFE tape to prevent air from being sucked back into the caliper during the bleed procedure?
totalllama82
Ah the old Tokico 6 pots. What I ended up doing is attaching the hose from the nipple back into the res and just kept pumping the lever - creating a big loop with the res being the vent. Switching between callipers periodically.
This seemed to work but did take a fair bit of time.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
0l0dom0l0
PostPosted: 21:16 - 09 Jan 2015    Post subject: Reply with quote
I had a similar experience when I rebuilt mine.
Have you tried cracking the bleed nipple off with a pipe on it and leaving the other end of the pipe submerged in a tub of brake fluid and pumping the lever? This really works a treat you can get so much fluid through the system in a really short space of time.
The last post was made 11 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 68.37 Kb
