road salt
bikenut
PostPosted: 15:45 - 08 Jan 2015    Post subject: road salt Reply with quote
so, its that time of year again for sticking brakes dudes........
time to service the calipers and pads etc......
pads can stick on their "stops", the bit the pads butt against and "resist" the force.........or is that transfer the force etc........
slide pins can stick or go stiff......same with pistons.........and pad retaining pins too!!
I did mine before the cold weather ( see gets really angry when I fix the ped in the kitchen :D :D ) but the pads are due a remove and clean and service again as there is loads of salt on the roads around here............unless of course you are a fair weather biker, meaning the brakes will be seized solid in the spring? :karma:
nuts about bikes
Minty
PostPosted: 15:51 - 08 Jan 2015    Post subject: Reply with quote
I have never performed a winter road salt brake service. Never had a problem.
My fingers smell of your mum.
bikenut
PostPosted: 15:57 - 08 Jan 2015    Post subject: Reply with quote
zen....little and often........etc.
remember ktm in motorcycle news last year??
nuts about bikes
pdg
PostPosted: 17:04 - 08 Jan 2015    Post subject: Reply with quote
I 'serviced' my brakes today by giving them a good wash. While I was there I did the bottom half of the bike as well just to make sure.
https://i.imgur.com/1eBf3g7.jpg
The rain did the top half this morning.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Fisty
PostPosted: 17:33 - 08 Jan 2015    Post subject: Reply with quote
Saving money like a true Jew!
Fatter and faster than Fret
Casper
PostPosted: 18:06 - 08 Jan 2015    Post subject: Reply with quote
Take car, take bus, get a pushbike, walk. Every year is the same. Deal with it or stop moaning. Thumbs Up
gavbriggs
PostPosted: 21:11 - 08 Jan 2015    Post subject: Re: road salt Reply with quote
Not on my bike me owld sparra!!!
Ive a secret trick!!! Lithium grease on the discs and as they go through they lube the pads and pins etc!!!
Genius eh!!!! Laughing
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
bikenut
PostPosted: 11:10 - 09 Jan 2015    Post subject: Reply with quote
and I suppose you are in a hospital bed with your legs in plaster?? :D
nuts about bikes
cheeseman
PostPosted: 11:49 - 09 Jan 2015    Post subject: Reply with quote
and I suppose you are in a hospital bed with your legs in plaster?? Very Happy
Strangely, I was approached by a bloke in a supermarket car park some months ago who recommended spraying WD40 all over the brake disc and pads for the winter to prevent siezing. Surprised
XJ600S->Sprint ST 955i * ; Now ST1100 + W650
UrbanRacer
PostPosted: 12:44 - 09 Jan 2015    Post subject: Reply with quote
When i used to ride through the winter months i never needed to service the brakes, however the salt always manged to make the bike look sh!t with corrosion.
I don't bother riding through winter now, its too expensive replacing corroded parts when the good weather comes back around.
bikertomm
PostPosted: 17:04 - 09 Jan 2015    Post subject: Reply with quote
Front wheel up onto a paddock stand.
Turn wheel and spray the hose down there.
Then get hot soapy bucket of water and scrub discs,
Rinse and repeat. Thumbs Up
drbaig
PostPosted: 22:50 - 09 Jan 2015    Post subject: Reply with quote
Currently mine are pissing me off properly. I am not riding much these days, maybe twice a week. Every time I go to move the bike they are jammed stuck with the rotors caked in rust. Back wheel starts spinning, no movement on the front. It takes a good few jugs of water to get the rotor free.
I thought fitting braided lines would help but nope that has not helped.
Once on the move they seem to be fine but this rotors getting rusted and the front wheel getting stuck is getting on my nerves now. Will tackle it tomorrow to see if I can come up with a solution. Hopefully it is as simple as the rusty retaining pins. I only recently cleaned it as well.
yzf 600r Very Happy
Nobby the Bastard
Harley Gaydar
PostPosted: 22:56 - 09 Jan 2015    Post subject: Reply with quote
BodyGuard wrote:
I unbolt the front calliper from the fork leg on my varadero and dunk it in a bucket of hot soapy water and scrub it clean every Sunday in the winter.
....said the person who thinks that welding a sprocket on is a long term solution.
Triumph Sprint ST 1050
Commuter_Tim
PostPosted: 00:36 - 10 Jan 2015    Post subject: Reply with quote
Would anybody happen to know if 0000 wire wool is too abrasive to use of the disc?
I ride a Bandit 600... badly.
pdg
PostPosted: 03:52 - 10 Jan 2015    Post subject: Reply with quote
It certainly won't stop you very well.
or
Have you felt a new brake pad friction surface?
Commuter_Tim
PostPosted: 14:14 - 10 Jan 2015    Post subject: Reply with quote
or
I see, so kitchen scourer or something the most abrasive that should used?
It's not a new disc (so none of that preservative stuff they supposedly put on it) its just the inner 'race' where the pad edge meets is excessively rusty.
I've never even seen a new brake disc up close tbh, unless you count bicycle ones, but theyre dinky little things. Smile
bikenut
PostPosted: 15:25 - 13 Jan 2015    Post subject: Reply with quote
https://i.imgur.com/1eBf3g7.jpg how deep dude and did you need a snorkel :D :D
be prepared for new wheel bearings and s/arm, caliper overhaul kits and seized centre stand etc etc etc
nuts about bikes
UncleFester
PostPosted: 15:36 - 13 Jan 2015    Post subject: Reply with quote
bikenut wrote:
https://i.imgur.com/1eBf3g7.jpg how deep dude and did you need a snorkel Very Happy Very Happy
I think this guy has you all beat for 'washing' technique.
https://www.youtube.com/watch?v=XFTY99Ol_mI
2017 Z1000SX
bikenut
PostPosted: 15:42 - 13 Jan 2015    Post subject: Reply with quote
time will tell or will he???????
problems looming for him unless.......mind you any water in the wheel bearings etc is doing its good work as we speak!
nuts about bikes
monkeybiker
PostPosted: 15:48 - 13 Jan 2015    Post subject: Reply with quote
Maybe he just didn't like you Thinking
iooi
PostPosted: 16:14 - 13 Jan 2015    Post subject: Reply with quote
How does water free them off?
Best to give the calipers a kick when you stop and are not using the bike to push the pads back a bit. So they do not stick to the disk Thumbs Up
Why would braided line help?
Well disks rust as they have iron in them. You not going to get round that one.
Fitting non sintered pads may help them not sticking to the disk.
The last post was made 11 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.82 - MySQL Queries: 15 - Page Size: 116.48 Kb
