| totalllama82 |
 totalllama82 Crazy Courier
 Posted: 18:47 - 09 Jan 2015 Post subject: Mancave Leaking |
Oh dear, after some heavy rain on the run up to Christmas my 4 month old felt gave up the ghost and started letting in the rain.
The cave is a 12 x 6 pent shed which sits next to the house.
Anyway, I refelted the roof last week with brand new stuff and sealant between the sheets of felt. I reckoned that I'd done a pretty good job of it too. All of the layers overlapped correctly and I used clout nails at 50mm intervals.
Tonight I go into the man cave to find that the shed is leaking like a sieve at the lower end. There is no sign on the roof itself of any damage to the felt. It just seems to be letting rain water in
So where am I going wrong? The bike and all of my stuff is currently sitting in a big puddle of water with more rain and shit weather forecast.
I'm now tempted to get a pro roofer to do *something* to it as the contents are just going to get destroyed. ____________________ Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F |
| doggone |
 doggone World Chat Champion
| totalllama82 |
| pdg |
 pdg World Chat Champion
 Posted: 20:38 - 09 Jan 2015 Post subject: |
If you have water coming through your roof, the most likely cause is that there is a hole of some description. To stop the water, I recommend finding said hole, and making not a hole any more
It's entirely normal to put clouts through the felt. Just so long as you have the appropriate amount of overlap and the clouts are properly in they shouldn't leak. It's usually a good ldea to put decent felt adhesive in the overlap as well, and a blob under the head of each clout when you put them in.
When I did my shed roof, I put the 'sheets' of felt over the roof (with a full covering of bitumen), instead of along it - the joins are 'vertical' instead of horizontal. I used clouts to hold it down, then I put a treated batten along each join (with a double bead of bitumen mastic under) which covered all the clouts.
Problems I have seen with shed roofs have mainly been because people use shed felt (which is paper thin, hard to work with without tearing and sometimes actually lets water through...) I have also seen someone cut off the ungritted section along the roll and then just butt the sheets up against each other - the 'bare' part is for the overlap. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| totalllama82 |
| Bikeless |
 Bikeless World Chat Champion
| totalllama82 |
 Posted: 21:01 - 09 Jan 2015 Post subject: |
Researching a little and it seems that a 1 piece rubber roof which is actually glued down may be an alternative. It comes in at £90 though so is an expensive experiment.
I just want to get the bloody thing watertight so that I can insulate and line the walls and floor.  ____________________ Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
| Islander |
 Islander World Chat Champion
| Chuffin Nora |
 Chuffin Nora World Chat Champion
| totalllama82 |
| pdg |
| totalllama82 |
 Posted: 21:59 - 09 Jan 2015 Post subject: |
| pdg wrote: | Personally, I would have put the strips of felt across the 6' so the joins all point toward the house. The joins should overlap in the direction of the prevailing wind (less chance of any lifting due to said wind) and then I would batten along those joins.
From your description, I think I have it right that your joins run along the long way (3 strips along the 12' length). Did you start on the low side, putting the next bit of felt over the top of the lower one? If you started at the high side, water will very easily get under the next sheet....
EPDM, as said, is an excellent solution even if it is a bit more expensive than felt.
BTW, if you think £90 is a bit expensive, don't even bother phoning a roofer..... Around here, I would be surprised to see change from £300 for a bit of roof that size. |
You're right, the joins run along the length - if it wasn't so dark i'd stick some photos up. I started at the low side adding a bead of sealant under each length and the nails to secure. It's layered so that, in theory, the water doesn't encounter an edge where it wont freely run onto the next level.
I had about £200 in mind for a pro job - £90 being for the materials for a DIY job. I suppose the prices may be a little better up here though.
I might just try your suggestion of the seams running towards the house with batons away from the prevailing wind. I'm in a pretty exposed place - last night the winds hit 90mph. ____________________ Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
| Chuffin Nora |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 22:40 - 09 Jan 2015 Post subject: |
Was the felt folded or in a roll? If it was folded and had something stacked on it there's the chance it might be split along the fold. ____________________ a.k.a 'Geri'
| totalllama82 |
 - Super Spammer
 Posted: 14:28 - 10 Jan 2015 Post subject: |
| Islander wrote: | | totalllama82 wrote: | Researching a little and it seems that a 1 piece rubber roof which is actually glued down may be an alternative. It comes in at £90 though so is an expensive experiment.
I just want to get the bloody thing watertight so that I can insulate and line the walls and floor.  |
EPDM roofing, if done properly is superb stuff and will outlast the shed. It's also a doddle to fit - I have it on two sheds and can recommend it. The stuff I bought came from rubber4roofs - helpful people and a fast service too.
Make sure you buy enough to give a good all round overlap and once it's glued on the flat, turn the excess under the overhang and fix it with a batten on top, screwed through to the structure under the rubber - this stops wind from getting under it and causing it to lift. |
Another fan of EPDM. My garage roof has very little pitch to it, so after removing the leaky Asbestos stuff (wearing the correct gear and double bagging it before taking to the tip), I decided to ply board and EPDM it.
It's great stuff, cheap (from £6 a square metre), completely watertight and a doddle to fit. You can buy a single sheet something like 15M X 30M without joints. I really don't know why people still bother with felt. You lay it over the roof, fold one half back over the other half, apply PVA glue and fold it back over the glued half, then repeat for the other half. I then glued the sides down with contact adhesive and fitted some plastic trims to create a ledge, so it drained to the back gutter. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| totalllama82 |
 Posted: 13:10 - 11 Jan 2015 Post subject: |
Seems like the EPDM might be the way forward. I'm going to try and have a chat with a roofer to see what they'd take to do a professional job.
It's now got about 3" of snow on the roof and there is a constant trickle of water coming down and into the floor. I'm doing my best to mop up the puddles and have buckets under the worst bits. I need to get it sorted soon though  ____________________ Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
 - Super Spammer
| totalllama82 |
| spriddler |
 spriddler Two Stroke Sniffer
| bikenut |
 bikenut World Chat Champion
| totalllama82 |
| mentalboy |
| totalllama82 |
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
