What would improve your bike
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5  Next
PostPosted: 17:21 - 11 Jan 2015    Post subject: What would improve your bike Reply with quote
What could the maker of your bike have done differently to improve your bike? With nominal change to the cost (say 1% max) and without changing whether it is road legal (so no noisy exhausts, etc)?
So for my 1200 Bandit, probably use more sporty profile cams (ie, GSXR11 cams). Pretty much zero cost change when the bikes are made.
b422063
PostPosted: 17:27 - 11 Jan 2015    Post subject: Reply with quote
Proper HID headlights for improved night riding.
Fisty
PostPosted: 17:31 - 11 Jan 2015    Post subject: Reply with quote
TL1000R:- conventional rear suspension.
Fatter and faster than Fret
PostPosted: 17:35 - 11 Jan 2015    Post subject: Reply with quote
Suzuki Savage LS650P - They could have either left it as a 4 speed, or spaced the 5 gears more evenly so you can tell the difference between 4th & 5th. They could also have given it a trip counter.
FretGrinder
PostPosted: 17:36 - 11 Jan 2015    Post subject: Reply with quote
CBF 1000:
- The ENTIRE electrical system.
Yamaha MT-09
ಠ_ಠ
b422063
PostPosted: 17:41 - 11 Jan 2015    Post subject: Reply with quote
How do you know when to fill up?
Formerly known as
P.
PostPosted: 17:44 - 11 Jan 2015    Post subject: Reply with quote
MC wrote:
BodyGuard wrote:
Honda should of made the Varadero 125 and 1000 fuel cap hinged or flip up instead of completely coming off as it is it's just an unnesery annoyance unzipping jacket to put it inside whilst filling up.
Confused Is there nowhere to rest it on the bike?
Between handlebars and tank is where I used to put it.
With my bike, its all good however could have put the screen on as stock rather than having to pay more. Aside from that its pretty faultless.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:50 - 11 Jan 2015    Post subject: Reply with quote
Are you some sort of weak spacker who needs both hands to hold the pump nossle in the filler hole?
Triumph Sprint ST 1050
pepperami
PostPosted: 17:52 - 11 Jan 2015    Post subject: Reply with quote
What would improve my bikes? a bit more use!
On the Hyosung? a thicker softer seat Thumbs Up , jeeze! the seat is like bloody wood Crying or Very sad
EDIT! I know what would improve my bikes = FIRE!
wr6133
PostPosted: 18:01 - 11 Jan 2015    Post subject: Reply with quote
ZZR400K - Fuel gauge would be nice but the main thing would have been better brakes, the Tokico 4 pots are legendarily crap.
PostPosted: 18:02 - 11 Jan 2015    Post subject: Reply with quote
Hit reserve at 100 mile mark, keep a note of mileage when I filled using a knitting row counter.
The Tot
PostPosted: 18:26 - 11 Jan 2015    Post subject: Reply with quote
If sportsbikes would come with pazzo-type levers from the factory. The ergonomics and feel are so much better than OEM. And if sportsbikes came with double bubble screens from the factory.
Never argue with autism
DrDonnyBrago
PostPosted: 18:30 - 11 Jan 2015    Post subject: Reply with quote
Cbr 600 f. Higher spring rate springs and diff valving, front and back.
garth
PostPosted: 18:35 - 11 Jan 2015    Post subject: Reply with quote
Stainless fittings where appropriate and capheads in place of JIS screws.
Applicable to most generic jap bikes.
chickenstrip
PostPosted: 18:37 - 11 Jan 2015    Post subject: Reply with quote
FZS1000, if they'd jetted it more like the Ivans kit, with 5-taper needles instead of the standard 3, and the carbs ready-drilled to improve the pilot settings. Gives it much improved transition between idle, pilot and full throttle, and a nice boost in go, everywhere.
Stainless steel bolts on the EXUP, so they don't snap when you come to remove them. In fact, all bikes ought to have stainless bolts fitted everywhere as standard.
garth
PostPosted: 18:39 - 11 Jan 2015    Post subject: Reply with quote
Unless it's somewhere where you need high tensile strength. Brakes etc.
grr666
PostPosted: 18:41 - 11 Jan 2015    Post subject: Reply with quote
Adjustable footpegs. Could do with them being a little lower.
Suntan Sid
PostPosted: 18:44 - 11 Jan 2015    Post subject: Reply with quote
FZ1-N
Would prefer carbs to the, snatchy, FI.
A seat that doesn't cut into the top of your legs after an hour, would be nice!
yen_powell
PostPosted: 18:47 - 11 Jan 2015    Post subject: Reply with quote
Edit - Also having to take the rear wheel out to change a set of brake pads is annoying I don't fancy the challenge on the 1000 model of course whoever designed it probably knew this.
My Varadero fuel cap is hinged.
XT1200Z and a DR350 in bits
Snowdonia Rider
PostPosted: 18:55 - 11 Jan 2015    Post subject: Reply with quote
Stiffer front suspension for less dive on braking. '98 GSX600F.
mattyfattyboo...
PostPosted: 18:56 - 11 Jan 2015    Post subject: Reply with quote
CB1000R
Somewhere to attach a net to on the rear seat, a headlight cowl that doesnt wobble as much as it does.
LongJohn22
PostPosted: 18:58 - 11 Jan 2015    Post subject: Reply with quote
Weld it on, that'll sort it.
The last post was made 11 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.08 - MySQL Queries: 13 - Page Size: 130.47 Kb
