balancing carbs
Keir
PostPosted: 09:39 - 12 Jan 2015    Post subject: balancing carbs Reply with quote
Recently tried to balance the carbs on my fazer 600 mk1 hack. proved to be difficult as the vacuum gauges were bouncing all over the place.
im using these gauges:
https://www.z1enterprises.com/images/parts/DSC05601.jpg
and the procedure was raise revs to a steady 3-4k and balance 1&2 then 3&4 then both together. I tried to hold the revs at 3k with the choke first then the idle but it didn't seem to make any difference. then I tried to use the damper screws that came with the gauges but as I tightened the screw to damp the needle the reading changed so it would be impossible to sync them accurately.
what am I doing wrong? Laughing
Current : '08 Yamaha FZ1s
andym
PostPosted: 09:58 - 12 Jan 2015    Post subject: Reply with quote
I didn't realise you could use the choke when balancing the carbs, I thought you were supposed to turn the idle screw up after the engine had a while to warm up properly.
Having never used gauges I'm guessing here, but shouldn't all the damping screws be set the same before starting the balancing?
PostPosted: 10:05 - 12 Jan 2015    Post subject: Reply with quote
What is the point in balancing the carbs on choke?
YBR Ric
PostPosted: 10:08 - 12 Jan 2015    Post subject: Reply with quote
The idea of synchronizing the carbs at 3-4K is to ensure the slides are not sitting on the throttle stops. Using the choke rarely accomplishes this - although there are a few carbs about that richen the AFR and also lift the slide up a bit at the same time.
If you can obtain a steady idle than just use one carb to set all the gauges. Just keep swapping the tubes over until all readings are the same on every gauge, then once they've all been set then you can start the balancing procedure.
Taught2BCauti...
PostPosted: 10:11 - 12 Jan 2015    Post subject: Reply with quote
Start off by setting the damping screw on each gauge in turn on the same carb, so all 4 gauges read the same - then connect 1 gauge to each carb, and go from there.
Also check for any air leaks on the engine side, and that the throttles are mechanically in sync.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Fizzer Thou
PostPosted: 11:06 - 12 Jan 2015    Post subject: Reply with quote
Carb balancing should be done at tickover speed,not at 3,000+ rpm.The whole idea is to synchronise the carbs.Anything from 2,000rpm and above is more to do with float height up to about 4,00rpm.
If the choke is used it will upset the procedure as you would be enrichening the mixture at tickover.Warm the engine thoroughly,then start the procedure.I use two fans blowing air onto the front of the bike.
Once you have got the gauges as close to the same reading as possible,rev the engine several times and let the revs settle down.Readjust as required.
If the gauges are not showing a steady reading at tickover,reduce the flow to the gauges a small amount at a time.
Before adjustment
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture561.jpg
After initial adjustment
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture566.jpg
Always have a 'Plan B'
pdg
PostPosted: 11:08 - 12 Jan 2015    Post subject: Reply with quote
You can't.
Well, you can but it'll likely be out of balance when you let the choke off...
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Fizzer Thou
PostPosted: 11:18 - 12 Jan 2015    Post subject: Reply with quote
The carbs sync procedure is only for when the carb slides are in the closed position and resting on the throttle stop.Your advice is wrong.And carbs are there to manage the air flow and enrichening circuits so that the AFR should be the same across from tickover to wide open throttle.So your advice about how some carbs do this is also not worth stating.
On a four cylinder engine like the Fazer 600 it is not possible to set the carbs up one at a time using just one gauge.The reason for using a bank of four gauges at the same time is so as to do the work in one go,not faff about attempting the procedure the way it has been suggested.
pdg
PostPosted: 11:41 - 12 Jan 2015    Post subject: Reply with quote
I don't think ric means to use one gauge for all 4 carbs - more to have a constant single source to balance the 'flow' to all the gauges first, then use one gauge per carb as normal.
IMO it's still pointless, adjusting the 'damper' clamp on the hose shouldn't affect the reading unless you close off the hose completely.
Fizzer Thou
PostPosted: 11:55 - 12 Jan 2015    Post subject: Reply with quote
It is still not worth trying to sync the carbs on a four cylinder bike unless all four gauges are used from the off.Adjust one carbs slide height and it will affect the revs of the engine overall - which will affect the readings of the other gauges.
On my old Honda 750/4 number two carb was fixed.So the procedure was to balance number one carb to number two carb,then to balance numbers three and four to numbers one and two.
On my R1 and Exup1000 you balance one and two together,then three and four.Then,using the mechanism between carbs two and three,balance the left pair with the right pair.
The ingoing pulse when the inlet valve opens causes the fluctuation of the gauge reading.At tickover this is more obvious because of the space between one cylinder inlet valve opening and the next one.As the revs rise,there is less of a time lapse.By reducing the size of the pulse to the gauge it steadies the reading.Without the restrictor it would be impossible to get a steady reading.On my gauges,the restrictor to each gauge is almost fully closed.
pdg
PostPosted: 12:03 - 12 Jan 2015    Post subject: Reply with quote
I don't think anyone so far suggested using one gauge - I know I certainly didn't because it would be a pain in the arse excercise that would lead you to chasing your own tail over and over and over and over.....
Ric (and apparently others) seems to be under the impression that the restrictor affects the reading - hence the suggestion to balance the gauges before starting on the carbs. Unless they have changed how vac gauges work the restrictor won't alter the actual reading, it will only affect the reaction of the needle.
RodYork
PostPosted: 00:36 - 13 Jan 2015    Post subject: Reply with quote
use this video on a Fazer (square headlight) 600-mk...1??
https://youtu.be/CYgN2-96Ik0
I had more hair then!...but contact me!
Bike trip through Europe! https://www.youtube.com/watch?v=Z2yTtFPM7Xc
YBR Ric
PostPosted: 22:02 - 13 Jan 2015    Post subject: Reply with quote
yes, my inadequate explanation was to ensure all the gauges were damped the same amount prior to their use.
Fizzer Thou, We must have had different models Wink
I found on my Honda 750/4 the problem with balancing the carbs on the slide stops was that it was the only time they'd ever be in balance, because each of its four separate throttle cables seemed to have a mind of their own. By wedging the throttle slightly open you could adjust each separate cable adjuster and end up with all four carb slides synchronised, then with the throttle closed and the cables slack, move onto the stop screws to get rid of any excessive clutch knock.
I used to use Davida gauges, but recently swapped over to the Carbtune. I unfortunately burnt through one of the tubes the last time it was in use on my last 4 cylinder job, but now I have a three cylinder bike it looks like I don't need to replace that tube just yet!
Keir
PostPosted: 16:45 - 14 Jan 2015    Post subject: Reply with quote
right well I tried again with a warmed up bike at idle. still didn't really work. the needles fluctuate so much that getting a reading is impossible - even with the damper thing screwed right in. doin my head in and running like a dog.
mentalboy
PostPosted: 17:32 - 14 Jan 2015    Post subject: Reply with quote
If the damper screw is fully home and the needle has any movement then you have a fault in the region of the screw. When it is fully home there should be no movement of needles because the screw acts just like a water tap cutting off the connection between bike and gauge
Edit: No offence, but are we talking about the same screws?
The damper screw in question is midline on each of the tubes connecting the gauge to the carb vacuum point NOT the carb adjustment screw
Make mine a Corona.
Keir
PostPosted: 10:31 - 18 Jan 2015    Post subject: Reply with quote
yes we are talking the same damper screw. I think youre right in that theres a fault with the screw as it wont fully close, even with it done as tight as it goes theres still movement so it cant be fully shutting it off. ill get some new ones and go from there.
am I right in thinking that all the screws need to be screwed in the same number of turns? they are just cheap plastic so im not convinced that they will be accurate anyway.
Also, ive noticed that when the bikes idling and I put it on the side stand the revs rise. ideas?
mentalboy
PostPosted: 13:39 - 18 Jan 2015    Post subject: Reply with quote
I've seen balancing gauges with the plastic screws thrown away and self - tappers used in their place, how efficient they were is anyone's guess (If I were going to try a bodge I'd at least try with BA type machine screws).
Failing that I would have thought it worth googling the gauge manufacturer's site and seeing if you can get replacement screws and their housings.
You turn each screw in until the flickering is barely noticeable, too far and the gauge needle will stop altogether (which means it's not getting any input/feedback). the idea being that you balance the flickering needles until they can be read as a foursome (or twosome if you've only got a dual gauge), enough to be able to effectively match up the readings for all four carbs.
Re. Rev rising on stand do you mean when you kick the stand down, when you rest the bike on the stand, does turning the bars affect it? Has this started since you tried to balance the carbs? (if so, trapped cable with fuel tank is the likely suspect).
Might be a badly routed cable, might be nothing.
Make mine a Corona.
Fizzer Thou
PostPosted: 17:17 - 18 Jan 2015    Post subject: Reply with quote
My Honda CB 750 was the F2 https://www.bikechatforums.com/viewtopic.php?t=234539
On my gauges there is a grub screw within the tube connecting the gauge to the carb and a very small jubilee clip clamping around this.It very effectively dampens the pulses so that a steady reading is achieved Thumbs Up
The last post was made 11 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 112.64 Kb
