Break levers
chrisjose1913
PostPosted: 22:05 - 11 Jan 2015    Post subject: Break levers Reply with quote
Hello I have a suzuki gp100, I am looking for a new set of levers for it.
Because it's drum on the front I uses cables. I am looking for cnc style levers for it. Are they any such levers in the wild for cable operated breaks ?
1997 CB500
Nobby the Bastard
Harley Gaydar
PostPosted: 22:07 - 11 Jan 2015    Post subject: Re: Break levers Reply with quote
Why are you throwing money at this? The standard levers are more than up to the job.
Save your money for test and big bike.
Triumph Sprint ST 1050
chrisjose1913
PostPosted: 22:20 - 11 Jan 2015    Post subject: Re: Break levers Reply with quote
Yes i am putting money into it, but with all due respect this doesn't answer my question, I also plan on keeping it after i have done my full bike test, but i am waiting for another year to do my a1 test instead of doing one now and another in a years time, it's would be an even bigger waste of money.
1997 CB500
Snowdonia Rider
PostPosted: 22:24 - 11 Jan 2015    Post subject: Reply with quote
A cheese string makes a good lever.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:36 - 11 Jan 2015    Post subject: Reply with quote
You do know that money doesn't go off and can be saved for more than a year?
mentalboy
PostPosted: 22:51 - 11 Jan 2015    Post subject: Re: Break levers Reply with quote
To answer your question, yes there are CNC levers to fit cable operated brakes but not for a 100cc Suzuki that's over 30 years old!
Best bet would be to head down to your local breakers yard and find something to fit (or head off to a local engineering firm and ask them for a 'one-off')
Make mine a Corona.
ws4936
PostPosted: 00:15 - 12 Jan 2015    Post subject: Reply with quote
Topic is called:
Break levers
So is the lever broken?
If everything seems under control, you're just not going fast enough.
chrisjose1913
PostPosted: 00:24 - 12 Jan 2015    Post subject: Reply with quote
ws4936 wrote:
Topic is called:
Break levers
No i just want to build a bike to my own taste.
1997 CB500
pdg
PostPosted: 03:09 - 12 Jan 2015    Post subject: Reply with quote
ws4936 wrote:
Topic is called:
Break levers
Swapping a brake lever doesn't count as 'building a bike'.
You said you wanted to change the brake levers, are you intending to change the clutch lever to match?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
fatjames
PostPosted: 11:15 - 12 Jan 2015    Post subject: Reply with quote
First thing that comes to mind is one from a bike (as in cycle).
The second thing that comes to mind is searching ebay..there are quite a few to chose from.
[url]
https://www.ebay.co.uk/itm/New-Black-Universal-Motorcycle-Motorbike-Brake-and-Clutch-Levers-with-Bracket-/400824045327?pt=UK_Motorcycle_Parts_13&hash=item5d52f98f0f[/url]
chrisjose1913
PostPosted: 14:52 - 12 Jan 2015    Post subject: Reply with quote
[url]
thanks but i am looking for something more along the lines of fold in breaks
1997 CB500
CaNsA
PostPosted: 14:54 - 12 Jan 2015    Post subject: Re: Break levers Reply with quote
The universal, politically correct way of saying "Fuck you".
mentalboy
PostPosted: 15:54 - 12 Jan 2015    Post subject: Reply with quote
Presume you mean something like this?
If so buy them, or equivalent, then remove the black part of the lever that fixes it to the bike. Take your old levers and cut off the bit that attaches to the bike - leaving enough room for adjustments. Shape the end of the old bit to fit in the new levers, you may need to build them up to be wide enough. Probably requires an engineering shop if you have limited tooling/experience in this kind of work (not really the type of thing you need snapping if you make a dog's dinner of it!)
Make mine a Corona.
andys675
PostPosted: 16:29 - 12 Jan 2015    Post subject: Reply with quote
I've seen these, fucking works of art they are
https://www.bikehps.com/acatalog/ISR_Front_Brake___Clutch_Master_Cylinders.html#a41907
£144 each............
probably buy another couple of GP100's for that!
The last post was made 11 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 88.57 Kb
