Engine dies at high revs
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
pdg
PostPosted: 17:36 - 12 Jan 2015    Post subject: Reply with quote
Whatever made you think it was a good idea to use the killswitch to create backfires?
Edit: seeing as I can't be bothered to try and find out another way, what bike?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
mentalboy
PostPosted: 17:46 - 12 Jan 2015    Post subject: Reply with quote
Is this the same bike that you changed the carb on back in October? If so did you ever sort out the mixtures?
Sounds to me like it was originally a fuelling issue but I'd be checking the compression before I started any work (not much use to you unless you've been keeping tabs on the compression and know whether it's changed or unless it's significantly low for the model)
Make mine a Corona.
pdg
PostPosted: 18:35 - 12 Jan 2015    Post subject: Reply with quote
So you might well have buggered your RC valve then - well done Thumbs Up
And if you've been running it since october on the wrong mixture, yes your extremely low compression reading may well have been caused by that....
mentalboy
PostPosted: 18:39 - 12 Jan 2015    Post subject: Reply with quote
Finnian3 wrote:
Yep, same bike, NSR 125 JC 20 model. It ran fine so I didn't change the mixture. I tried to check the compression a month a go but I only got really low readings for my bike, I'm supposed to get 10kg +-2 but I would only get 2kg. It was really hard to get the tester on and even then I don't think it was quite on properly.
I think it might be something related to to running at the wrong mixture . Doh!
Do you have any mechanically adept friends who can look at the bike?
Make mine a Corona.
The last post was made 11 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 58.63 Kb
