| PC800 Lee |
 PC800 Lee Derestricted Danger
| temeluchus |
| moonzoomer |
 moonzoomer World Chat Champion
| PC800 Lee |
| moonzoomer |
| Shaft |
 Shaft World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 02:01 - 11 Jan 2015 Post subject: |
Could be that your charging problem has fried the ECU but more likely it's just not happy about being sat for a few months.
First job - find out if you have a spark. Remove a plug and put it in the plug cap. Make sure it's touching the engine and crank it over. See if it sparks. If it does you probably have a fuelling issue. ____________________ a.k.a 'Geri'
| PC800 Lee |
| moonzoomer |
| Pete. |
 Pete. Super Spammer
 Posted: 02:10 - 11 Jan 2015 Post subject: |
Perhaps someone could take a look. Where are you? ____________________ a.k.a 'Geri'
| Shaft |
| Pete. |
 Pete. Super Spammer
 Posted: 11:07 - 11 Jan 2015 Post subject: |
Semantics. If it isn't points ignition it'll have some form of electronics. ____________________ a.k.a 'Geri'
| PC800 Lee |
| sickpup |
 sickpup Old Timer
| PC800 Lee |
 Posted: 16:49 - 11 Jan 2015 Post subject: |
i have actually managed to change the air filter
changed most of the fluids and filters about 4 months ago |
| Pete. |
 Pete. Super Spammer
 Posted: 17:26 - 11 Jan 2015 Post subject: |
I am actually coming to Eastbourne this evening leaving in an hour or so. I can only spare 10 minutes but I do I have a narrow plug socket you can borrow, so I'll bring that with me and you can post it back. Send me your address and mobile number and I'll right you when I'm en-route. ____________________ a.k.a 'Geri'
| sickpup |
 sickpup Old Timer
| PC800 Lee |
| PC800 Lee |
| PC800 Lee |
 Posted: 22:30 - 13 Jan 2015 Post subject: |
Got a spark plug spanner today (its a start lol) |
| PC800 Lee |
| Pete. |
 Pete. Super Spammer
 Posted: 18:23 - 14 Jan 2015 Post subject: |
Two coils don't die together. 'Dead coil' is the normal 'diagnosis' to no spark, but it's seldom the cause. Having no moving parts and no reason to go wrong except failed insulation they really are a long-lived part.
Check first the power at the coils. They will have one wire that's the same colour on both coils and that's the power feed. If there's no power then you have a switch or fuse problem. If there's power at the coil it could be pickup, ECU or earth.
My money is on the run switch or ignition switch. ____________________ a.k.a 'Geri'
| PC800 Lee |
| PC800 Lee |
 Posted: 00:07 - 20 Jan 2015 Post subject: |
WD40 seemed to make no difference Still aint got a multi meter yet either |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 11 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
