Rider Tips - Snow & Dark
iginge
PostPosted: 23:46 - 13 Jan 2015    Post subject: Rider Tips - Snow & Dark Reply with quote
Hi all,
So I think having my work holiday booked for me over the next two weeks was possibly the best chance holiday I've ever had.
I would leave my bike sitting for two weeks and stay in my house all day but have things to do, so I think I'm just going to go out during the day for no more than a couple of hours and hope I don't get caught out in it.
All in all, it's started snowing so I was just wondering what tips other riders have if it starts snowing while out and about, both in the day and during the darker times (seems to be after 5pm this time of year)..
I'll share my one experience;
First time I've ridden during the snow and currently the only time, coming home roughly about two miles from home, put the lights on.. let the bike warm up-ish.. and rode off..
Bike cut out at a roundabout, felt as if it was loosing power (all in all not a good ride), worked fine ever since.. could of been me pancaking and not letting the machine warm up, proper controls etc.
Worst ride of my life, honestly don't now how I made it home in one piece.
Your turn..
SQL
PostPosted: 00:04 - 14 Jan 2015    Post subject: Reply with quote
When it is dark and snowing put your full beam on and visor down and it looks like you are going light speed Embarassed
iginge
PostPosted: 00:08 - 14 Jan 2015    Post subject: Reply with quote
Trying to keep the visor partly open was probably one of my main mistakes, learnt minutes into the ride as I got some snow in my eye and was on an island (small quiet back ground island) and was practically blind.
Tips on keeping a fairly un-snow filled visor.. method in the madness?
SQL
PostPosted: 00:19 - 14 Jan 2015    Post subject: Reply with quote
Pinlock, visor shut and balaclava.
Oh and lots of this
https://stream1.gifsoup.com/view4/1893376/windshield-wiper-fail-o.gif
Charlie
PostPosted: 00:22 - 14 Jan 2015    Post subject: Reply with quote
Found my normally fog free pinlock visor fogging thanks to the snow building up on my visor. Keeping the visor closed or just a crack open and regular wiping with the finger is what I found best. Snow still got sucked in from round my chin but wasn't so bad.
Went up and down some steep hills this evening. Only advice is to go very steady (1st gear steady) and plan how you'll deal with a slide. Fortunately some of the worst bits had a grass verge I could aim the front wheel towards if it went a bit pair shaped. Also kept close to give me a place to put my foot down on something less slippy than the tarmac
I am really hoping it doesn't freeze over night Praying if it does then I don't think I'll be chancing it. Fresh isn't so bad, still slippy mind, ice is pretty traitorous.
Riding in the snow should cause your bike to cut out... I imagine you just stalled it.
iginge
PostPosted: 00:40 - 14 Jan 2015    Post subject: Reply with quote
Having one single cheap helmet with no pinlock is probably my downfall, use a foggy mask though so try to prevent it as much as possible.
Doesn't help once fully locked I can't open it with one hand things stiff as it is (locking mechanism is probably poorly designed).
Probably, just going around a roundabout in 3rd gear and probably to slowly, plus the factor of not letting my bike warm up properly and setting off straight away at normal speeds.
I've fiddled about with the bike since and changed simple things like the idol speed etc, was having trouble even in the dry prior so if I do get caught out should be a good test.
Plus at the time there was some gear box problems (turned out to be a simple adjustment of the gear lever positioning).
I was still breaking the machine in at the time so could of been an adding factor.
Since my bikes Chinese 125 first gear is so short it shouldn't exist, third would probably be a suitable slow cursing speed gear.
Commuter_Tim
PostPosted: 00:56 - 14 Jan 2015    Post subject: Reply with quote
Ahh, that's where you went wrong, you set the Idol speed to "Billy" and it cried "More, More, More"
...I'll get my coat.
I ride a Bandit 600... badly.
iginge
PostPosted: 01:12 - 14 Jan 2015    Post subject: Reply with quote
rookie mistake Rolling Eyes
wr6133
PostPosted: 07:39 - 14 Jan 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Fog-City-Proshield-Amber-Universal-Visor-insert-none-pined-visors-only-/321365028616?pt=UK_Helmets_Headwear_Visor_Inserts_Tear_Offs&hash=item4ad2d92f08
https://www.ebay.co.uk/itm/FOG-CITY-Hyper-Shield-Anti-Fog-Insert-Arai-SAL-visor-Clear-/200891865775?pt=UK_Helmets_Headwear_Visor_Inserts_Tear_Offs&hash=item2ec6169aaf
https://www.ebay.co.uk/itm/Fog-City-Proshield-Dark-Smoke-Universal-Visor-insert-none-pined-visors-only-/191118642657?pt=UK_Helmets_Headwear_Visor_Inserts_Tear_Offs&hash=item2c7f8f0de1
I use those in my non-pinlock lids. Cheaper and easier than the universal pinlock thing that you drill your own holes for. These things just stick on and work pretty well.
darkhorizon
PostPosted: 08:08 - 14 Jan 2015    Post subject: Reply with quote
Move south - no snow.
2009 CBF600 - London hack - stolen then recovered - still going!
2006 CG125 - Was SORN'd, now back on road - sold Nov '16
Chuffin Nora
PostPosted: 08:38 - 14 Jan 2015    Post subject: Reply with quote
iginge wrote:
rookie
https://stickerish.com/wp-content/uploads/2011/03/RageFaceBlackSS.png
novice!
There's a fine line between integrity
Kris
PostPosted: 10:16 - 14 Jan 2015    Post subject: Reply with quote
I found heavy snow sticks to the visor until you get to 80mph.
www.prisonplanet.com
iginge
PostPosted: 15:12 - 14 Jan 2015    Post subject: Reply with quote
I'll be sure to save the links thanks.
Higher than the top speed on my bike, time to invent a string and a wiper I think Laughing
SQL
PostPosted: 15:17 - 14 Jan 2015    Post subject: Reply with quote
I want a heated visor on mine
Atomic Punk
What bike is it?
I may have lost my way but I'm way ahead of schedule.
Snorty
PostPosted: 15:21 - 14 Jan 2015    Post subject: Reply with quote
I've ridden a 125 in a light frosting of snow.
That was fine, bar the back end slipping out a few times, feet out by my side.
I won't take any of my bikes out in the snow to be honest, I don't think it's worth the potential damage and cost just to say "I rode in snow, I'm a proper biker, innit". I'd get a taxi and let them risk their insurance and vehicles...
I know of two people who dropped their bikes today.
iginge
PostPosted: 15:58 - 14 Jan 2015    Post subject: Reply with quote
Atomic Punk wrote:
What bike is it?
Lexmoto Arrow.
Think my case was just the whole not letting it warm up properly, and in honesty when I set off (it was a unavoidable trip home) it wasn't to bad but then started to come down really quite quickly.
Went out today and the wind was light but still enough to try and take me from one side of the lane to the other, rode at 40mph on main roads and wasn't a problem.. just be sure to keep an eye on conditions over the next two weeks.
I don't own my bike yet as I haven't drop** oops, cursed Idea Rolling Eyes
KnuckleShot
PostPosted: 16:00 - 14 Jan 2015    Post subject: Reply with quote
I've asked for advise in the snow previously last month.
The response I got was don't - it really isn't worth it.
If it snows again I'd be using public transport or telling my boss I can't make it to work.
Snorty
PostPosted: 16:20 - 14 Jan 2015    Post subject: Reply with quote
You mean you don't work for somebody who would expect you to get a taxi to and from work totalling just under your day's wages?!
KnuckleShot
PostPosted: 16:49 - 14 Jan 2015    Post subject: Reply with quote
And if you don't have enough for a taxi?
I found in the town I live public transport still runs after it snows.
The Tot
PostPosted: 18:21 - 14 Jan 2015    Post subject: Reply with quote
Back when I was on the company grad scheme, I had to do London to Gloucester a few times in the snow. Also, did a few gloucester to bournemouth runs in the snow before via salisbury plains!
It wasn't that bad to be perfectly honest. Goretex kit all round, balaclava and my trusty Arai. Rode with half the vents open to demist and it was fine. Make sure your battery is in good nick, and install the best lightbulbs you can get - Osram night breakers and HIDS (although latter is technically illegal)
The key for me was to be as smooth as possible and ride in the wheeltracks where it was guaranteed to be slush. OK, there was a chance of black ice but at the end of the day it's all about throttle control and appreciation of weight transfer. I rarely use my brakes since I ride with a bit of a flow and read the road.
Another time I was moving attachments so had to move from Ashford back to London in the snow as well. M20 only had 2 lanes working so I was sat in 5th/6th gear on tickover slowly filtering past most cars. Still could reach 40-50, but at the end of the day, you need to have faith in your tyres and know what the bike is telling you through the chassis.
At the end of the day, it was quite fun... and this was on a 929 Fireblade.
Tips
Arrow Wrap up warm - get a kidney belt to stop heat loss. Better still, buy heated clothing. Football socks work well. Tape up any vents on gloves and boots, and if you can, install muffs on your handle bar.
Arrow Ride smooth - crack the throttle and use it progressively. If you need to slow down, anticipate and use engine braking where possible. Use your rear brake to come to a stop.
Arrow If it's clear that the wheeltracks are wet and runny, ride in them. Meltwater is better than black ice.
Arrow Get crash protection - Yes, you WILL fall off. Speed humps on sheet ice are a bitch and I stacked my bike on one when the bike stalled and lost my footing. Sidestreets are a lot more trickier than main roads! I was literally 200 metres from my destination!
Never argue with autism
iginge
PostPosted: 18:38 - 14 Jan 2015    Post subject: Reply with quote
Very helpful advice and points, thank you.
I was at the bottom of my ride when the bike stalled and had trouble getting going again, if anywhere close to home is the best way.
Sadly on Chinese bikes crash protection isn't an option, no manufactures both with it.
talkToTheHat
PostPosted: 02:54 - 15 Jan 2015    Post subject: Reply with quote
Pinlock and a foggy mask is the way to go, with either a buff or balaclava sealing the gaps in the neckline. I've not found a balaclava that didn't mess with the fit of my helmet, but I've not looked too hard or tried a silk or bufflike material one.
My shark lid is either open or locked tight, but the chin vent sends a howling gale straight up the inside of the visor, working better than cracking the visor on any previous lid. If anything a slightly open visor is the enemy of pinlock systems.
Bandit. does. everything.
The last post was made 11 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 133.29 Kb
