MK1 Bandit 1200 poor idle.
Carvel
PostPosted: 20:07 - 14 Jan 2015    Post subject: MK1 Bandit 1200 poor idle. Reply with quote
Can't get the bandit to idle properly when it's hot. Throttle response off of idle is also poor. Past that it sings like a good'un. Aswell as that it pops and bangs on the overrun.
I've had the carbs off and all seems well, needles don't appear worn etc, set the idle mixture screws to 1 3/4 turns, checked all the rubbers.
Are there any common issues with these things as I'm struggling to sort it.
RhynoCZ
PostPosted: 20:16 - 14 Jan 2015    Post subject: Reply with quote
What do your air filter and spark plugs look like?
Also, how fast is the idle?
Carvel
PostPosted: 20:33 - 14 Jan 2015    Post subject: Reply with quote
Filter is dirty but not too bad.
Forgot to mention the airbox is also wet, pretty sure it's not just petrol either, feels oily.
Plugs are new and don't look too bad, a little black.
RhynoCZ
PostPosted: 21:50 - 14 Jan 2015    Post subject: Reply with quote
A bit greasy airbox is perfectly normal. All the engine breathers are directed there. Thumbs Up
MK1 that'd be a 1996. It's an old engine, and there are possibly carbon deposits in the combustion chamber and all over the plugs = hence a bit black colour. My ZXR sounds like a turbo diesel at idle, but when I go flat out for a while and then back to the idle, it gets much better. The flat out riding cleans the engine. Thumbs Up
No need to be speeding though, there are fuel cleaners, such as STP engine treatment (Sea Foam). You pour that into the tank, mix with petrol and ride the motorcycle, that'll get rid of the carbon deposits for you. I had a '88 GPz and with that cleaner/treatment the bike ran much better, almost like if it needed the additive.
Anyway, ä video or rather audio of the motorcycle idling would be helpful.
Check this, about the a bit black plugs:
https://www.mts1200.info/motorcycleinfo/resources/6795/assets/images/FAQs/electrics/check_spark_plug_condition.jpg
doggone
PostPosted: 21:58 - 14 Jan 2015    Post subject: Reply with quote
Carb balance maybe?
temeluchus
PostPosted: 05:33 - 15 Jan 2015    Post subject: Reply with quote
It could be a sign you need new float needles or possibly a stuck choke. Either will cause it to be rather rich.
Have a look at the spark plugs and post pics. Best to stick a fresh air filter in at the same time, if only to rule it out.
Ant132
PostPosted: 10:13 - 15 Jan 2015    Post subject: Reply with quote
I used to periodically balance the carbs with one of the cheap tube kits with the ball inside the line, always resulted in a much better throttle response on my bandit. It had quite sensitive carbs i found, maybe it was just me, or the fact that it took me a while to realize that when i was turning the mixture screw, i was turning it half a turn (180) whilst thinking i had turned it a full turn (360), looking back, what a retard! Laughing
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Carvel
PostPosted: 23:16 - 19 Jan 2015    Post subject: Reply with quote
Slow reply on this.
Had the plugs out, they don't look too bad.
https://i979.photobucket.com/albums/ae271/RxsOllie/IMG_1183_zps80dbe629.jpg~original
40,000 miles on it, no history on the clearances so I guess a carb balance and valve clearances are next.
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 67.08 Kb
