What is this bit?
SteveSmith
PostPosted: 12:52 - 15 Jan 2015    Post subject: What is this bit? Reply with quote
I had the tank off at the weekend to do the valve clearances and couldn't work out what the component I've circled in the attached photo is. It looks like it's something to do with oil, but beyond that I haven't got a clue.
Can anyone help? As you can tell I'm pretty new to this!
Thanks,
Steve.
Supermoto_Fan
PostPosted: 13:18 - 15 Jan 2015    Post subject: Reply with quote
Educated guess > Fuel tap?
Looks like identical lines and clips to my SV fuel lines
Matt B
PostPosted: 13:20 - 15 Jan 2015    Post subject: Reply with quote
Try vacuum fuel pump.
Taught2BCauti...
PostPosted: 14:19 - 15 Jan 2015    Post subject: Reply with quote
It might help to know make, model & year, but my guess is EGR Valve.
If not, part of the cooling system?
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 14:23 - 15 Jan 2015    Post subject: Reply with quote
It's the Flux Capacitor. You just need to add in an uprated alternator to provide 1.21 gigawatts and you'll be fine.
Try not to go 88mph Thumbs Up
temeluchus
PostPosted: 15:15 - 15 Jan 2015    Post subject: Reply with quote
https://www.cmsnl.com/suzuki-gsf600-s-bandit-2000-2003-usa_model16067/valve-assy-2nd-air_1845033e12/#.VLfLV1WsXuI
its part of the emissions control gubbins.
Matt B
PostPosted: 20:23 - 15 Jan 2015    Post subject: Reply with quote
Vincent wrote:
...in other words, find out how, then get rid Thumbs Up
Unless of course it provides a vacuum that allows the fuel to flow...
PostPosted: 23:49 - 15 Jan 2015    Post subject: Reply with quote
It's a pair pump. It sends fresh air from the airbox into the exhaust port to introduce oxygen into the exhaust which will allow any un-spent hydrocarbons to burn.
The very small pipe is the vacuum signal which causes the pump to operate.
The one big pipe is the air feed from the airbox
The four smaller pipes connect to metal tubes that run one to each exhaust port.
It does nothing for the bike's performance or economy, it just reduces the amount of hydrocarbons (un-burnt fuel) that's sent out into the atmosphere.
SteveSmith
PostPosted: 10:13 - 16 Jan 2015    Post subject: Reply with quote
Pete. wrote:
It's a pair pump...
Now that makes sense (although I was hoping it would be the flux capacitor!)
Thanks.
Steve.
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 69.9 Kb
