Need a pick up and spray general lube.
Bonneville63
PostPosted: 13:26 - 18 Jan 2015    Post subject: Need a pick up and spray general lube. Reply with quote
There's nothing better getting home in the dark after a rainy, wet muddy day and then remembering you need to clean the dirt/salt off your bike.
At the moment I use a degreaser to remove the dirt and salt.
But I'd like to give it a quick greasing (wheel hubs, pegs, screws etc) - preferably a spray for ease of use.
Is there anything out there (cheap) that'll do the trick?
I have lubes and greases but nothing in spray form.
Cheers.
https://www.youtube.com/user/TheBonneville63/videos
PostPosted: 13:41 - 18 Jan 2015    Post subject: Reply with quote
Give it a good clean then coat in ACF50 then leave until spring. It will get caked in dirt etc but will be protected by the ACF50. When the weather improves give it a good clean.
Otherwise WD40/GT85.
Suntan Sid
PostPosted: 14:19 - 18 Jan 2015    Post subject: Reply with quote
Duck Oil comes in a spray, it leaves an oily covering, unlike WD40 which de-oils everything.
It is a low surface tension oil so it will dissolve grease, so you would have to regrease at some point.
Copycat73
PostPosted: 15:08 - 18 Jan 2015    Post subject: Reply with quote
is this the sort of thing your after Thinking
https://www.halfords.com/motoring/engine-oils-fluids/grease/halfords-spray-grease-400ml
caveat emptor
Bonneville63
PostPosted: 22:45 - 18 Jan 2015    Post subject: Reply with quote
Copycat73 wrote:
Looks good to me! Thanks.
The last post was made 11 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 44.05 Kb
