Gs125 6k misfire when riding fine when free revving
bradh511
PostPosted: 16:10 - 17 Jan 2015    Post subject: Gs125 6k misfire when riding fine when free revving Reply with quote
hi there basically i finally got my gs back together bits that are new
Moto Batt battery
New carb
New ignition coil
New inlet rubber
New ignition barrel
Engines been apart top end off all cam marks line up.. So 99% sure timing spot on
It starts on button revs well past 6 k with clutch in just misfires under load.
New carb it was off good old eBay i had a problem with a sticking open float on it when i first fitted it, it said in the add jetted to uk spec model Gs 125 witch mine is as far as I'm aware you they don't have a mixture screw on the diaphragm carbs
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
Taught2BCauti...
PostPosted: 18:39 - 18 Jan 2015    Post subject: Reply with quote
If it's only mis-firing under load, I would suspect the Spark Plug (check electrode gap and insulator condition), HT Lead or Spark Plug Cap.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
bradh511
PostPosted: 18:43 - 18 Jan 2015    Post subject: Reply with quote
I don't think its electronic. And I think float height but no show if it would cause not running properly past 6k jetting mabey ? To your reply its new ht lead plug cap spark plug ect
Taught2BCauti...
PostPosted: 19:05 - 18 Jan 2015    Post subject: Reply with quote
I would still check the Spark Plug gap - unless you are sure you did it accurately when you fitted it - just 'cos it's easier than stripping the carb.
A mate of mine had a bad misfire under load on his car after a service, and all 4 brand-new plugs were set too wide. Re-gapped to .0025" and problem solved.
Could also be float height, I guess - especially if it is set too low, but also check fuel flow through the needle valve in case there's an obstruction in the fuel line.
The last post was made 11 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 40.29 Kb
