Pan european cam belt change
PC800 Lee
PostPosted: 22:17 - 19 Jan 2015    Post subject: Pan european cam belt change Reply with quote
I was just wondering if anyone knew roughly how much a cam belt change would cost on a ST1100 ?
wr6133
PostPosted: 22:39 - 19 Jan 2015    Post subject: Reply with quote
The price of a cam belt
HTH Thumbs Up
PC800 Lee
PostPosted: 22:42 - 19 Jan 2015    Post subject: Reply with quote
is it something that can be done by a home mechanic or best go into the local bike shop to be done professionally ?
misscrabstick
PostPosted: 22:51 - 19 Jan 2015    Post subject: Reply with quote
Body work off, drain coolant, radiator out the way, covers off, ensure camshaft and crankshaft alignment marks are where they need to be, slacken tensioner, remove old belt fit new and retension, make sure timing still correct. Just about covers the basic process, someone with a basic knowledge, reasonable toolkit and a Haynes manual should be allright.
b422063
PostPosted: 05:02 - 20 Jan 2015    Post subject: Reply with quote
Just to add to the above; Ducati belts needs the tension checked. I'm not sure if these are the same.
davebike
PostPosted: 08:15 - 20 Jan 2015    Post subject: Reply with quote
I done a good few
Make sure you have lots of time
Belly pan and lower fairing parts off
Drain remove radiator
Remove front part of cam covers
Soak main belt cover screws in penetrating oil
Remove screws may need replete of penetrating oil don't use force or you will brake the cover or inner cover remove cover
Remove spark plugs and rotate engine until timing marks line up
Loosen tensioner remove old belt check water pump and idler wheel bearings and replace belt
Re-tension
turn engine over by hand and re check valve timing
Replace all removed parts fresh coolant
you done
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 47.29 Kb
