Peugeot blaster exhaust issues
Dylanjones
PostPosted: 20:44 - 20 Jan 2015    Post subject: Peugeot blaster exhaust issues Reply with quote
My peugeot blaster was doing around 60mph but then had exhaust issues. Fitted a new full through exhaust but now the bike is only doing around 40mph max. Cleaned carbs, filter and had new spark plugs. Any advice will be appreciated.
Dylan.j
pdg
PostPosted: 21:17 - 20 Jan 2015    Post subject: Reply with quote
Which engine size is it?
Also, why did it need new spark plugS - was one plug not enough?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
BMWilliams
PostPosted: 21:58 - 20 Jan 2015    Post subject: Reply with quote
is the new Exhaust a sports exhaust?
it may need to get the carb rejetted or change the rollers to suit the pipe
were there any rollers supplied with the new pipe?
A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat.
andyscooter
PostPosted: 22:21 - 20 Jan 2015    Post subject: Reply with quote
Blasters only came as 50cc AFAIK
Is new pipe the same as the old one
As above are rollors right does it need a new belt
And PS it wasn't doing 60
andyscooter
PostPosted: 22:22 - 20 Jan 2015    Post subject: Reply with quote
pdg
PostPosted: 22:30 - 20 Jan 2015    Post subject: Reply with quote
I don't know enough about scooters to say whether one particular 'name' was put on multiple sizes or not.
I do know however that a 50cc scooter will not have been doing 60mph, unless it was on a trailer.
Mentaldazza
PostPosted: 15:42 - 21 Jan 2015    Post subject: Reply with quote
To do 60mph it has been played with alot if it is air cooled my bike is modified all bar the engine size and a can't hit 60 but if its watercooled you have more chance. If sport exhaust need to up jet and rollers I got a new exhaust and had to change the clutch springs for it to run right . Also is there a ristrictor in the pipe or end can. If you have brought a 70cc pipe will not have a great effect on a 50
Mental
wr6133
PostPosted: 15:50 - 21 Jan 2015    Post subject: Reply with quote
It's a 2 smoke, liquid cooled, 50 weighing about 80kg. Doesn't do 60 though. OP probably has one with Kph clocks and hasn't noticed/learned the alphabet far enough to realise the markings..... 60 kph = 37 Mph which sounds more realistic.
Andy_Pagin
PostPosted: 16:18 - 21 Jan 2015    Post subject: Re: Peugeot blaster exhaust issues Reply with quote
Start by informing the DVLA and your insurers that you've converted it from a moped to a motorcycle.
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 58.92 Kb
