cleaning caliper piston
Random13
PostPosted: 13:13 - 20 Jan 2015    Post subject: cleaning caliper piston Reply with quote
what would you use to clean a rusty caliper piston ?
dremel with wire brush ? would that scratch it and hence dangerous ?
Thanking you
mentalboy
PostPosted: 13:28 - 20 Jan 2015    Post subject: Reply with quote
Pics??? (of the piston, not the dremel!)
Make mine a Corona.
Random13
PostPosted: 13:42 - 20 Jan 2015    Post subject: Reply with quote
Proactively asking before taking them apart
wr6133
PostPosted: 13:44 - 20 Jan 2015    Post subject: Reply with quote
If it's really rusted I'd replace it. Though that can get expensive if lots are fucked.
mentalboy
PostPosted: 13:49 - 20 Jan 2015    Post subject: Reply with quote
It shouldn't be critical if the rust is on the lip of the piston and never goes past the seals. It is most likely to need the seal grooves cleaning, for which a dremel (with a reasonably soft brush - brass) is perfect.
If you use a dremel on the piston avoid using a stone and try not to scuff up the clean surface.
Make mine a Corona.
Fizzer Thou
PostPosted: 22:32 - 20 Jan 2015    Post subject: Reply with quote
Is it rust or dirt?
A friend needed one new piston for one of his four piston calipers on his GSXR750 a few years ago.At the time they were really expensive as OEM parts,so I asked a machine shop to make one out of a decent grade of stainless steel.
Cost was about £5 at the time Thumbs Up
Always have a 'Plan B'
Wonko The Sane
PostPosted: 23:05 - 20 Jan 2015    Post subject: Reply with quote
as has been said, might consider a re-build / refurbishment kit of new seals and piston depending how bad it is
otherwise brass brush is softer than the piston so should be ok
Taught2BCauti...
PostPosted: 08:25 - 21 Jan 2015    Post subject: Reply with quote
I use a stainless-steel scourer for most surface rust jobs, because it doesn't break-up like ordinary wire wool.
On a caliper piston though, if it has rusted below the line where it contacts the seal, I would bin it and get a new one - it's not worth the risk.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
kerr
PostPosted: 13:08 - 21 Jan 2015    Post subject: Reply with quote
Fizzer Thou wrote:
Is it rust or dirt?
This.
Are you sure its not just a build up of road crap, try giving it a good scrub with hot soapy water and a toothbrush first.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Random13
PostPosted: 14:36 - 21 Jan 2015    Post subject: Reply with quote
cool , was just concerned if I can use a wire brush on it.
is it not like car piston which any scratch or uneven surface can mess it up ?
worst case scenario, big scratches on the outside of the piston, does it let fluid out ?
mentalboy
PostPosted: 14:55 - 21 Jan 2015    Post subject: Reply with quote
It works just like a car brake piston and requires just the same kind of cleanliness. And yes, big scratches in sides will leak fluid.
Make mine a Corona.
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 71.12 Kb
