Variator cover held on with 2/3 screws
piggoy
PostPosted: 10:38 - 21 Jan 2015    Post subject: Variator cover held on with 2/3 screws Reply with quote
Hi guys,
I'm in the process of restoring an old Peugeot Speedfight 100cc scooter. Yesterday I removed the variator pulley to inspect the drive belt and rollers. I've discovered that in the past someone has drilled out one of the variator cover screws, presumably because it had seized or the screw head rounded off. Anyhow the variator cover is now only held on with 2 out of 3 screws. This cover only keeps the rollers in place within the variator assembly so presumably isn't subject to a great deal of force? Do people think it's fine as is or is there a danger of the transmission destroying itself?
Thanks
Mentaldazza
PostPosted: 12:16 - 21 Jan 2015    Post subject: Reply with quote
No the cover don't hold it in place the pully and the nut does that that's y you need a locking tool to undo it a lot of peugeots crankcase bolts fall out if not looked after only thing you can do is try to re thread it or buy a new engine case I know this problem because I only have 4 in myn. A little heads up the 100ccs are not great for kickstart so keep the electric start working for as long as posible
Mental
Mentaldazza
PostPosted: 12:19 - 21 Jan 2015    Post subject: Reply with quote
I'm sorry I misread take is it a metal ring going around it if so take it off its a redtrictor
Mental
piggoy
PostPosted: 13:02 - 21 Jan 2015    Post subject: Reply with quote
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/37kAAOxyXJxR7VSp/$(KGrHqR,!qYFHm!BPwn9BR7VSo)wBw~~60_35.JPG
It's not a restrictor plate. Its the cover on the moving part of the variator pulley that hold the rollers and slider plate in place. In the attached image it's the three little screws on the right, one of them is now a drilled out stud.
wut?
barrkel
PostPosted: 13:21 - 21 Jan 2015    Post subject: Reply with quote
AFAIK that's to stop grease getting out, when your rollers are greased.
My own scooter uses no lubricant as stock, so there are no screws holding anything in. And besides that, I use Dr Pulley sliders that don't need lubrication.
piggoy
PostPosted: 13:28 - 21 Jan 2015    Post subject: Reply with quote
Thanks Barrkel. As per your reply on my previous thread I am planning to reassemble the variator dry - only putting moly grease on the shaft.
The last post was made 11 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 52.17 Kb
