Safe to Warm Up Air-Cooled BMW Stationary?
EasyGoingPat
PostPosted: 16:23 - 21 Jan 2015    Post subject: Safe to Warm Up Air-Cooled BMW Stationary? Reply with quote
Hi,
I have just acquired a BMW R1100S. I was surprised in the manual to read that, when the engine is started from cold, you should ride away in less than 30 seconds. Does anyone know how important this is?
Presumably, the lack of air-flow means the engine will warm up unevenly, perhaps stressing some parts, but I've had various air-cooled bikes throughout my life and never worried about this.
It can be inconvenient, too. Recently, I did some maintenance work on the engine and needed to check one or two things with the engine running and warm, but I can't take the bike on the road at the moment because it is declared SORN.
Any help or advice from experienced BM owners (or owners of other big air-cooled bikes) would be very much appreciated.
Kind wishes ~ Patrick
Question
Thank you to anyone taking the time to read my posts.
devojunior
PostPosted: 16:25 - 21 Jan 2015    Post subject: Reply with quote
why would you be concerned about about it benig air cooled if you trying to warm it up anyway aslong as its not sat on choke for 20 mins whilst ya get a shower
Aff
PostPosted: 16:26 - 21 Jan 2015    Post subject: Reply with quote
I assume it's an oil pressure thing rather than uneven warm up.
Letting it warm up from idle for a few times in its life to let you do maintenance won't do any damage.
Electric Bike Project
EasyGoingPat
PostPosted: 16:47 - 21 Jan 2015    Post subject: Reply with quote
Regarding the question about why I would want to warm up the bike, the main one is to get an oil level indication in the sight glass. Again reading from the manual, it states that the level can vary by 1cm if the bike is not properly warm and then allowed to stand for 5 minutes.
I never remember to check the oil when I have been for a ride, so I would like to warm the bike standing.
To be honest, it is just something i'd rather not have to worry about.
Scootaloo
PostPosted: 16:55 - 21 Jan 2015    Post subject: Reply with quote
Just do it man! If its just oil level I wouldn't worry about getting it roasting, just 2 minutes let it warm up, power off check, adjust.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
c_dug
PostPosted: 16:57 - 21 Jan 2015    Post subject: Reply with quote
I wouldn't worry too much, I've seen my dad's r1100s sit idling for that long without issue.
If you're really concerned maybe pop on to the boxertrix forum, there seems to be a wealth of knowledge there.
hmmmnz
PostPosted: 17:06 - 21 Jan 2015    Post subject: Reply with quote
arnt the r1100 oil cooled?
i happily leave my air head idling for a few minutes with no dramas
can't think an oil head is much different, as long as the pump is pumping the oil it shouldnt be a major issue untill it reaches a few hundred degrees, which isnt going to happen in 5 minutes of idling
the humans are dead
I kick arse for the lord
map
Mr Calendar
PostPosted: 17:23 - 21 Jan 2015    Post subject: Reply with quote
hmmmnz wrote:
...can't think an oil head is much different, as long as the pump is pumping the oil it shouldnt be a major issue untill it reaches a few hundred degrees, which isnt going to happen in 5 minutes of idling
Probably worth asking on one of the (many) BMW forums.
However, I thought there were issues with leaving oil heads running when on side stand because then they're non-horizontal so oil has to go uphill.
Oilheads Club site wrote:
BMW is very specific in the Owners Manual. Start the bike and ride off. Don’t leave it idle for long periods even on very cold days.
caragh
PostPosted: 20:23 - 21 Jan 2015    Post subject: Reply with quote
Think it may be due to instances of fire caused by the oil level window blowing and leaking onto the headers, not sure how long it takes to occur but common wisdom seems to be start then ride.
Triumph Tiger 800 XR
temeluchus
PostPosted: 21:33 - 21 Jan 2015    Post subject: Reply with quote
I cant see it hurting, just keep an eye on the oil temperature.
You should be reading the oil level cold anyways. If you allow the engine oil pump to suck oil up into the crevices you will get a false reading, where you got the idea to read it warm I don't know.
Llama-Farmer
PostPosted: 22:55 - 21 Jan 2015    Post subject: Reply with quote
This is standard recommended practice in a lot of vehicles, including water-cooled cars.
Something to do with the exhaust gases... when the engine is cold and idling, the gases are very acidic or something, and can slowly eat cylinder lining and piston rings.
Under load or when the engine is up to temp it is not a problem.
In the real world, it is also not a problem for the most part.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
hmmmnz
PostPosted: 23:18 - 21 Jan 2015    Post subject: Reply with quote
they are precarious enough on the center stand, im sure the design is a bit better on the oil heads but even trying to get an air head on to its side stand is a dodgy thing,
its mounted so far forward because of the weight, that you have to stand on one foot and balance the bike, while holding the side stand forward then lean it over keeping your foot in place to stop the stand flicking back up,
i bet more people have dropped their bmws trying to get it on the side stand than there have been crashes
the humans are dead
PostPosted: 09:47 - 22 Jan 2015    Post subject: Re: Safe to Warm Up Air-Cooled BMW Stationary? Reply with quote
It may be directly from the German translated and so anything that's not prohibited is mandatory.
All I'd read into it is that there's no need or benefit to leaving it blatting and barking away while you put all your gear on, have a fag, and do all those other "warming up" neighbourhood-alienation biker rituals.
Start, ride off gently. Why wouldn't you?
davebike
PostPosted: 11:50 - 22 Jan 2015    Post subject: Reply with quote
Be very careful BMW r series air / oil cooled DO NOT like idling stationery
I have had a customer seize one
No more than 5 mins !
The engine's cooling dose not work unless the bike is in motion
Dave
NC750Xdct + others at work !
davebike1@gmail.com
DrDonnyBrago
PostPosted: 13:57 - 22 Jan 2015    Post subject: Reply with quote
Next time you pop out for currywurst and sauerkraut check the oil when you get back.
pdg
PostPosted: 14:30 - 22 Jan 2015    Post subject: Reply with quote
I can't think of any engine where idling for extended periods does any good at all.
For servicing requirements on air cooled engines, I would personally always stick a fan blowing in the direction of 'normal' airflow if I needed to have it sat running.
As for all this 'warming up' malarkey (except because race car/bike of course), it's just annoying whether it's a bike/car/mower/whatever. As soon as the oil is up to pressure it's circulating and good to go - which is when the oil light goes out (if there's no oil light, 5-10 seconds is more than enough on a reasonable condition engine). You may have a 'cold' engine, but you'll also have cold tyres so take it easyish for the first 1/2 mile and it's all fine.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
bikenut
PostPosted: 15:59 - 22 Jan 2015    Post subject: Reply with quote
blimmey, what about sitting at traffic lights or road works or jams etc
do they have an automatic heat activated cooling fan for this?
nuts about bikes
davebike
PostPosted: 16:03 - 22 Jan 2015    Post subject: Reply with quote
They can get to hot in traffic but as most are ridden by experienced riders who tend to filter there not to much of an issue
I think with any air cooled bike I switch off if stuck for more the 5 mins ! probably on/in any bike /car why sit still burning fuel if not going anywhere
Dave
davebike1@gmail.com
69chris
PostPosted: 03:21 - 23 Jan 2015    Post subject: Reply with quote
it might just be because its illegal to idle your engine in germany....
Section 30 of the StVO (German Road Traffic Licensing Regulations)
states:
“When operating a vehicle it is forbidden to produce
undue noise and avoidable air pollution from exhaust
fumes. Especially prohibited is the unnecessary idling
of engines.”
According to the LImSchG (Federal Immission
Control Act) and the StVO it is against the law to
wilfully and knowingly violate these paragraphs.
Violation can result in a heavy fine.
strange lot Laughing
PostPosted: 09:41 - 23 Jan 2015    Post subject: Reply with quote
69chris wrote:
it might just be because its illegal to idle your engine in germany.... [...] strange lot Laughing
Oh, anything the Hun can do...
the driver of a vehicle shall, when the vehicle is stationary, stop the action of any machinery attached to or forming part of the vehicle so far as may be necessary for the prevention of noise. and A person who contravenes or fails to comply with any construction or use requirement [...] is guilty of an offence.
There's an explicit idling offence in Scootchland.
map
Mr Calendar
PostPosted: 10:19 - 23 Jan 2015    Post subject: Reply with quote
Rogerborg wrote:
I thought for the natives in Scotchland that idle was the default setting Thinking Wink
EasyGoingPat
PostPosted: 11:06 - 23 Jan 2015    Post subject: Reply with quote
Thank you very much for all those replies.
On balance, I think I will aim to avoid idling a cold engine (the seized engine story was SCARY), and I will just try to remember to keep a general eye on the oil level whenever I get back from a run.
In reply to temeluchus about where I got the idea about checking oil on a warm engine, this is a paraphrased quote from the manual: 'Only check the engine oil when the engine is at normal operating temperature. ... Checking the oil level after the engine has only been used for a short time or is only just warm could lead to wrong interpretations...'
Incidentally (and this maybe a separate question), but does anyone know if I need to worry if I get stuck in traffic on a hot day?
- Patrick
bikenut
PostPosted: 12:30 - 23 Jan 2015    Post subject: stuck in traffic Reply with quote
apparently you should turn the engine off like the rest of us do.......?
see the bmw black museum........
the japs fit an auto cooling fan as do most if not all bike makers do.....so bmw being german etc.......
nuts about bikes
pdg
PostPosted: 02:33 - 24 Jan 2015    Post subject: Re: stuck in traffic Reply with quote
Well now, that looks like you are saying that BMW don't fit cooling fans when Japanese manufacturers do.
I haven't seen a Japanese air cooled bike with a cooling fan (except for scooters, but the fans on these are generally flywheel mounted just like in a mower or a chainsaw so not exactly 'automatic'). An airhead BMW is the same idea - it's air-cooled.
Now for oil cooled bikes - there are some that have thermostatic fans, and that 'some' includes a few BMWs.
Water cooled? "But BMW have just started making water cooled bikes". Yes, how true - if you count 1983 as 'just'... The K series has always been water cooled, and has always had a thermostatic 'automatic' cooling fan.
Oh no, a BMW bike engine broke. That must mean they are all on borrowed time because they obviously aren't built very well...
Yeah, ok. Because a Japanese bike will never ever break or have any problems of any sort at all.
I'm quite sure that one day something important will break in my K75 engine. After all, it's got over 80,000 miles on it. Just think, if it was Japanese it would probably have broken and been scrapped 40,000 miles ago because the parts had been discontinued.
CaNsA
PostPosted: 02:36 - 24 Jan 2015    Post subject: Reply with quote
You're killing kittens with posts like that.
What if... the reason it seized was due to the oil not flowing round the engine due to a blockage, and not because he was sat at the traffic lights.
The last post was made 11 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.40 Sec - Server Load: 10.14 - MySQL Queries: 13 - Page Size: 137.22 Kb
