Lithium batteries, you get what you pay for?
Snowdonia Rider
PostPosted: 20:11 - 21 Jan 2015    Post subject: Lithium batteries, you get what you pay for? Reply with quote
So, I've finally had enough of the Dynavolt in my bike and I want a new battery. The Motobatt gel seems highly rated and at £44 it's only a tenner more than a standard battery for peace of mind. But whilst trawling eGay, I've come across a JMT Lithium battery for £54, so is it worth the extra tenner or is it like standard batteries where you get what you pay for? £54 seems a bit cheap for a lithium battery, the cheapest I'd previously seen Lithium batteries for was £75. Thought I'd ask incase I end up getting angry with another battery!
wr6133
PostPosted: 20:30 - 21 Jan 2015    Post subject: Reply with quote
No idea about lithium, I thought they were for fairly specialist uses, not day to day bikes. Motobatt though are worth every penny, I used to get plagued with batteries dying in cold weather (bikes live outside), never had the issue with motobatt.
Commuter_Tim
PostPosted: 21:24 - 21 Jan 2015    Post subject: Reply with quote
Can rate the AGM motobatts quite highly too.
However I learned recently if you use a charger, you best be sure its suited to AGM batteries (a lot arent, as far as what happens if you use a non-compatible charger, I'm struggling to find any actual documentation on it, but who wants to risk their bike not starting?)
I ride a Bandit 600... badly.
CaNsA
PostPosted: 22:25 - 21 Jan 2015    Post subject: Reply with quote
I'm probably wrong... but...
Aren't Lithium batteries/cells meant to drain to 20% before charging them again.
Hence why they are used in a Total Loss system.
They are not meant for use in a system that continuously keeps it topped up.
PostPosted: 22:27 - 21 Jan 2015    Post subject: Reply with quote
Didn't N3O have one in his GSXR?
CaNsA
PostPosted: 22:28 - 21 Jan 2015    Post subject: Reply with quote
I'll ask him.
CaNsA
PostPosted: 22:36 - 21 Jan 2015    Post subject: Reply with quote
I asked him.
CaNsA
you're input is required
https://www.bikechatforums.com/viewtopic.php?p=4057033#4057033
N30
Cba to log in lol
https://www.ebay.com/itm/200908348213
That was more than enough to Crank my k7 1000 though mate
CaNsA
how well did it handle being on a continuous charge though?
N30
I never trickle charged it. I think they need a special charger for that.
CaNsA
ta for the info
if you can be arsed.... let them know
N30
Np fat head. You could make your own battery out of A123 cells. But that's exactly what that Chinese one is made from. So saves you the bother lol
Aff
PostPosted: 22:42 - 21 Jan 2015    Post subject: Reply with quote
There is no issue with discharging small amounts and topping up again with Li-Ion.
I assume they have a BMS built into the battery, as the procedure for charging Lithium is very different from charging Lead.
The down side of Lithiums is they don't like being stored at full charge. At 25C they loose something like 20% capacity a year when at full charge.
But I hope the BMS they put in the batteries would be smart enough to sort this out. Unfortunately most of the stuff from China isn't.
Electric Bike Project
wr6133
PostPosted: 23:05 - 21 Jan 2015    Post subject: Reply with quote
I've charged them with the super cheapo eBay chargers that are not much more than a plug, 2 wires and a pair of clips.
They didn't immolate my flat and they worked fine after.
defblade
PostPosted: 23:08 - 21 Jan 2015    Post subject: Reply with quote
Lithiums are supposed to be brilliant for power v weight... ntil they get cold, then they just don't want to know. If you ride all year round, stick to normal stuff.
Aff
PostPosted: 23:19 - 21 Jan 2015    Post subject: Reply with quote
This is a bit of a myth. A Lithium cell will out perform an equivalent weight or capacity Lead cell at pretty much any temperature.
At -10C a lithium cell looses about 40% of its capacity, similar to a Lead cell however a Lithium cell has about 7-8 times the usable capacity as an equivalent weight lead cell and can discharge at much higher rates. So will start your engine easily if a lead can.
The Artist
PostPosted: 23:58 - 21 Jan 2015    Post subject: Reply with quote
Complete waste of money for a bike IMO. A well maintained bog standard lead acid will do the job just fine.
Snowdonia Rider
PostPosted: 00:47 - 22 Jan 2015    Post subject: Reply with quote
Thanks for the input guys Thumbs Up The battery in my bike is well and truly shagged. I'll let you know what I go with and how it does.
Pie-Roe
PostPosted: 13:24 - 22 Jan 2015    Post subject: Reply with quote
Motobatt was fine to turn over TLR, even in the cold and with a cig lighter socket charging my phone while left.
Scootaloo
PostPosted: 14:37 - 22 Jan 2015    Post subject: Reply with quote
Another Vote for MotoBatt
My CB-1 is a turdy sh*t f**k the MotoBatt allowed it to start correctly at any temperature.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
reed
PostPosted: 18:34 - 22 Jan 2015    Post subject: Reply with quote
Been running a motto bat since before last summer, it has never let me down, and since passing my driving test over a month ago, i've only started the bike twice, and both times it turned over spot on, no loss of charge whatsoever. Smile
and you get funky allen key bolts, although be careful, i lost one instantly as i was putting the battery in. Laughing
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
PostPosted: 20:13 - 22 Jan 2015    Post subject: Reply with quote
Riding the bike should be equivalent to a trickle charger as far as charging goes - the circuitry in any decent lithium battery should sort it out, I expect.
Presuming they're running 4 cell lithium batteries, they shouldn't over charge anyway, because their peak voltage is higher than a 6 cell lead acid.
However, do still want to be careful with lithium regardless.
CaNsA
PostPosted: 20:23 - 22 Jan 2015    Post subject: Reply with quote
Overcharging is a bad thing, that's pretty much obvious and is bad news on most things I can think of.
What I'm getting at is, unless a lithium cell gets drained to 20% (i think) before being charged back up then the total capacity of that battery decreases over a pretty short amount of time.
PostPosted: 20:32 - 22 Jan 2015    Post subject: Reply with quote
Nope, afraid not.
You're probably thinking of memory effect, which is linked to nickel based batteries, not lithium.
https://en.wikipedia.org/wiki/Memory_effect
As with lead acid, they typically have a longer life if kept at a higher charge, rather than being repeatedly discharged.
Overcharging lithium batteries typically results in worse effects than overcharging lead acid - sure, releasing hydrogen isn't ideal, but better a reasonably hot fire.
Aff
This is just legacy information left over from Nicads and NiMh's. It doesn't apply to Lithium based cells.
Lithium based cells actually get exponentially more life cycles the lower the DoD (depth of discharge) on each cycle
However as I said, if stored at full charge (even for a week) they will start to lose a lot of capacity.
CaNsA
PostPosted: 21:03 - 22 Jan 2015    Post subject: Reply with quote
Learn something new every day Very Happy
moonzoomer
PostPosted: 01:05 - 23 Jan 2015    Post subject: Reply with quote
Bought an expensive Lithium -Iron battery for the SV650, it lasted 3 months only being capable of running the lights etc but not starting the bike, frankly a waste of money as a few lead /acid batteries cost the same as one Lithium -Iron and will last a hell of a lot longer.
PostPosted: 01:08 - 23 Jan 2015    Post subject: Reply with quote
Probably should have bought a lithium-ion battery instead Wink.
Got details of the make?
Did you return it?
Despite the saying, I often find that 'what you pay for' is often a smaller bank balance, rather than better kit Smile.
moonzoomer
PostPosted: 01:21 - 23 Jan 2015    Post subject: Reply with quote
Did you return it?
I thought about Lithium -ion but the weight saving with the Lithium -Iron Wink was better being a track day bike, the battery cost me 129.99 GBP so it was not cheap, complained about it and still waiting for a refund or replacement. The brand is Shorai, type number LFX14A1-BS12.
PostPosted: 01:35 - 23 Jan 2015    Post subject: Reply with quote
First off - Embarassed - I forgot that of course LiFePo4 chemistry is Lithium Iron.
However, to save some face I should note that typically I believe they are heavier than Lithium Ion, but should have a significantly longer shelf life.
Not sure what's up with yours. For a while now I've been using a LiPo (lithium polymer) RC plane helicopter style battery to start my van (have got some replacement lead acid batteries for van, but want to set them up to also be used as leisure batteries.)
It's a little bit taller than a coke can, but under half the cross section and starts my 2.2td van fine.
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 128.21 Kb
