Honda Nsr 80 Help needed with first project
kev250
PostPosted: 01:43 - 22 Jan 2015    Post subject: Honda Nsr 80 Help needed with first project Reply with quote
Hello, I have no previous experience with bikes so i bought an nsr that was in the process of being rebuilt, but the seller didn't know how to go any further with it so i bought it to learn and finish the project. Engine was supposedly rebuilt and we eventually got this going although at times it still does not start. Have not used the fuel tank yet as there is some rust in it that needs to be cleaned out, which i why the funnel can be seen in the second picture.Basically been like a jigsaw, with the help of a friend taking parts from a box and figuring out where they go on the bike. Confused
I have what i'm sure are basic questions but first here is the bike about to be unloaded, was a tight fit as i expected the bike to be smaller.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20141213_112543_zps05e6d9ea.jpg
And here is how it sat a few days ago. You will notice how dirty the whole thing is and i would prefer to have it all cleaned down but the engine was in aswel as other bits when i got it and for a first project i feel it is better to focus on other areas.
https://i1020.photobucket.com/albums/af329/Kev250/IMG_20150120_161912_zps4d2e9a05.jpg
Problem 1
While connecting the clutch cable it was obvious there was something wrong. Am i missing some connection at the end of the cable connecting to the handlebars. The hole the cable goes into is threaded so it looks like i am missing a connection on the end of my cable.I have adjusted the nuts next to the clutch pedal but there is no spring at all in the clutch lever so if it is not related to the first issue maybe my clutch cable needs to be replaced too?
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_205124_zpse6b1e196.jpg
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_205032_zpsdcf48851.jpg
Problem 2
When screwing the clocks onto the holder, it felt under quite a bit of pressure but when locking the steering right it hits the clock but when locking left it covers the rev gauge.So it looks like i have an issue here.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_204722_zps6105bc63.jpg
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_204732_zpsfbaa7cd9.jpg
Problem 3
The clocks are not working, seems i am missing a cable. The temperature gauge is working. I have one cable that is coming from an area between the clutch pedal and oil cap. I presume this is the cable that is for the rev gauge? I presume i need to buy a cable similar to this for the speed gauge but where does it connect to.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_204913_zps83cdb15f.jpg
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_204900_zps17493b90.jpg
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_205239_zps1cadcbbe.jpg
Problem 4
The radiator is on hinges on the bottom, on the top it does not reach the hole it pops into. Do i need to push/bend the bracket from the bike frame so that it sits onto the rad. I'm fairly sure on this one just making sure.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_205328_zpsf55f8511.jpg
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_205342_zps3f3788d2.jpg
Now i have a few things that i am trying to figure out where they go/what they do.
Object 1
Looks like i am missing something on the end of this.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_213032_zpseeb7888e.jpg
Object 2
Have 3 bottles that i am sure i need to attach somewhere.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_212632_zpsc7c4a40f.jpg
Object 3
What does this attach to?
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_213311_zps4787e466.jpg
Object 4
Have this connection near to the front headlamp.
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_213012_zps8212cc2b.jpg
Onject 5
Have a wire and fuse that looks like it connects onto the battery, where does this go?
https://i1020.photobucket.com/albums/af329/Kev250/Honda%20Nsr%2080/IMG_20150121_212737_zps35abf7b0.jpg
Lots of pictures i know and also posted this on an nsr forum but it is not very active, cars are my main interest so remember i am new too all this when you laugh at some of my questions.
Thanks for any help Very Happy
Jaco
PostPosted: 02:28 - 22 Jan 2015    Post subject: Reply with quote
Build a bike with Kev!
Object one is the other half of your speedo. The cable should connect here and at the clocks.
Sure everyone will be along any minute to answer your other questions Thumbs Up
garth
PostPosted: 09:25 - 22 Jan 2015    Post subject: Reply with quote
Problem 1. End of the cable is missing as is the free play adjuster on the lever.
Problem 2. Bent bracket?
Problem 3. Get a wiring diagram.
Problem 4. I'd assume bend the tang if it looks as though it was burnt before. Hard to tell with the filth on it.
Object 1. Speedo drive. Cable goes to. The threaded nub on the rear if the clocks.
Object 2. Yes you do. Coolant, oil, ???
Object 3. Fuck knows. I'd assume airbox - carb but its an extra hole.
Object 4. Horn? Get a wiring diagram.
Object 5. Get a wir....
DrDonnyBrago
PostPosted: 10:08 - 22 Jan 2015    Post subject: Reply with quote
I'll be quite impressed if you turn that scruffy box of shite into something rideable Thumbs Up .
What are you doing for fastener locations, just guessing?
SQL
PostPosted: 13:10 - 22 Jan 2015    Post subject: Reply with quote
Carb rubber with a hole for a boost bottle
PostPosted: 13:29 - 22 Jan 2015    Post subject: Reply with quote
Hole might have went to a weird black box like this;
https://thumbs1.ebaystatic.com/d/l225/m/m2QIjSPNipX7OjayWTKtTTg.jpg
wr6133
PostPosted: 14:17 - 22 Jan 2015    Post subject: Re: Honda Nsr 80 Help needed with first project Reply with quote
And you decided to start with this? Laughing Good luck!
Problem 1 - It's buggered (technical term). If you are restoring the whole bike you may as well replace every cable and bearing anyway. Also it appears to be missing an adjuster at the end of the lever bit.
Problem 2 - What is hitting it, the bar or the clutch lever? If it's the clutch lever it may just be on the bar at a wrong angle. Clock brackets behind may be bodged/bent as well making the clocks stick out to much on that side.
Problem 3 - No idea, read the manual.
Problem 4 - Probably, read the manual or find a picture of a less fucked one.
Object 1 - Speedo drive, you put one end of the speedo cable here and the other end goes to the clocks.
Object 2 - 1 will be coolant... could another be for 2 smoke oil? Fuck knows read the manual
Object 3 - Airbox - carb would be my guess....... however read the manual
Object 4 - Connection for the headlamp? Sidelight? Read the manual
Object 5 - Probably the battery but...... read the manual!
You need some kind of workshop manual the mechanical stuff you can probably assemble with common sense but the wiring and electrics are going to drive you insane without a proper diagram.
Also before farting about with all the bits clean everything to a good standard. It'll make it easier to identify, work on and there is no point doing all this to assemble it as a filthy wreck.
Just_James
PostPosted: 14:38 - 22 Jan 2015    Post subject: Reply with quote
Object 2 - You have oil tank, coolant tank and the little one in the middle looks to be a resonator which you should find fits into the hole of 'object 3' which should be your carb' rubber.
The last post was made 11 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 63.63 Kb
