How to power this LED
The Artist
PostPosted: 22:49 - 22 Jan 2015    Post subject: How to power this LED Reply with quote
https://www.aliexpress.com/item/Freeshipping-10pcs-3W-UV-Ultra-Violet-High-Power-LED-Bead-Emitter-395-400NM-with-20mm-Star/2050610694.html
Can I just connect this to a 3.7V 18650 type battery? Do I need anything else to power it?
PostPosted: 23:30 - 22 Jan 2015    Post subject: Re: How to power this LED Reply with quote
I'm not sure regarding that specific one.
If you search for 'direct drive LED' you get a variety of responses to similar questions that should be able to get an idea of the answer for this specific LED.
smegballs
PostPosted: 00:35 - 23 Jan 2015    Post subject: Reply with quote
I'd find the datasheet for it and then use a LM317 in constant current mode to drive it safely. You'll need more than 3.7V from a lithium ion battery tho Sad
You could do it just with a resistor, but remember the working voltage of a li-ion battery is 4.2V charged, and 2.9V discharges (below the diode forward voltage). If you set the resistor for max permissible current at 4.2V, you will get less current, therefore less output, as the voltage falls off. A proper constant current regulation circuit skirts this problem. If you be wantings I can draw you a simple circuit that should work with it for you?
smegballs
PostPosted: 00:40 - 23 Jan 2015    Post subject: Reply with quote
Whats that application? It would be pikey as fuck, but you could have a resistor for when the battery is fully charged, then as it dims off you throw a switch that shorts out the resistor and drives the led directly. It won't have any protection against the battery voltage recovering a bit and forcing more current through tho.
Remember unlike a resistor, current through a diode is non-linear with voltage. A increase in voltage across and led can cause large increases in current, all-too-easily blowing the led. Hence the proliferation of all the various means of driving them.
Even better idea....
Use of of these constant current LED driver boards that come in the chinese 188650 torches.
https://www.dx.com/p/2-7v-6v-3w-cree-circuit-board-for-flashlights-15mm-2-7mm-25518#.VMGKokesWgY
They are small, cheap and designed to run power LEDS from 18650 batteries! Pretty much exactly what you want no?
Aff
PostPosted: 10:05 - 23 Jan 2015    Post subject: Reply with quote
Buy a Buck Boost Converter from eBay for a few ponds.
Electric Bike Project
PostPosted: 10:32 - 23 Jan 2015    Post subject: Reply with quote
Incidentally, this site has loads of LED drivers etc:
https://www.kaidomain.com/
WD Forte
PostPosted: 14:30 - 23 Jan 2015    Post subject: Reply with quote
UV eh?
I'd be interested to know what the application is as well
security scanner? micro grow light? Very Happy
bikers smell of wee
The Artist
PostPosted: 17:09 - 23 Jan 2015    Post subject: Reply with quote
Industrial leak detection. Nothing too interesting. Laughing
I am going to do some reading of the above links over the weekend and see what is most likely to work. Thumbs Up Karma
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 55.94 Kb
