Yamaha ybr125 clutch lever issue
Thesmit87
PostPosted: 08:51 - 24 Jan 2015    Post subject: Yamaha ybr125 clutch lever issue Reply with quote
Hello,
I am new to biking and fell off my yamaha ybr 125 on my first ride. Fail.
Nothing spectacular but I snapped off my left mirror, my top box came off and I bent the clutch lever.
Since the fall when I pull the clutch lever, it hits the handlebar. This has meant that occasionnaly it won't allow me to change gear because I can't fully pull in the clutch lever. I thought this was due to it being slightly bent but I have since replaced it and still it hits the handlebar.
Any thoughts?
Snowdonia Rider
PostPosted: 09:17 - 24 Jan 2015    Post subject: Reply with quote
Are the handlebars bent? Did you replace just the lever or the whole assembly where it clamps to the bars?
monkeybiker
PostPosted: 09:24 - 24 Jan 2015    Post subject: Reply with quote
Is there any play/slack in the clutch lever cable? You need to adjust it so you only have a little clutch cable slack.
You can make the adjustment at the handle bar or were the cable goes to the engine clutch cover.
Taught2BCauti...
PostPosted: 10:22 - 24 Jan 2015    Post subject: Reply with quote
Check to see how much movement you have at the clutch end by moving the lever forwards and backwards:
You shouldn't be able to move it back (away from the cable) by more than a couple of mm, and the angle between the lever and the cable should be less than 90 degrees, as in the pic below.
Just another thought... does the replacement lever have the same amount of travel as the original, on the cable side of the pivot?
Post pictures of the old and new levers - it could be that the new lever isn't pulling the clutch cable far enough.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Thesmit87
PostPosted: 12:09 - 24 Jan 2015    Post subject: Reply with quote
Thank you for your replies,
As far as I can tell the handlebars aren't bent but I will give them another look,
I just replaced the lever itself with a like for like swap but the issue was evident with the old lever.
If I was to adjust the cable to take out any potential slack, would that then stop the lever being pulled back as far as the handlebar?
Taught2BCauti...
PostPosted: 12:19 - 24 Jan 2015    Post subject: Reply with quote
Yes - you don't need more than 1 or 2mm of free-play in the cable.
You need a little slack, otherwise you will be putting pressure on the internals, which will cause rapid wear.
How much slack do you have at the moment?
Test this by seeing how far you can easily pull and push the outer cable at the lever end, where the cable ferrule goes inside the threaded adjuster.
monkeybiker
PostPosted: 12:21 - 24 Jan 2015    Post subject: Reply with quote
You will still pull the lever to the handle bar but because there is less slack you will pull the cable more and so will open the clutch more.
The last post was made 11 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 53.09 Kb
