can i put a 3.50 18 tyre on a 1.60 18 rim ?
one off
PostPosted: 17:25 - 23 Jan 2015    Post subject: can i put a 3.50 18 tyre on a 1.60 18 rim ? Reply with quote
newbie here !
as the title really im looking to put trail tyres on and would like to go up to 3.50 wide but can i safely run them on my 1.60 front rim ?
cheers
pdg
PostPosted: 20:57 - 24 Jan 2015    Post subject: Reply with quote
Personally I wouldn't put a 3.50 onto a 1.6" rim... To keep a sensible profile on the tyre you really need a 2" rim width.
You can get some decently aggressive 3.00 fronts though.
What bike is it you're putting it on? Chances are that if it has a 1.6 rim it won't have the clearance around it for a 3.50 tyre anyway.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
cb1rocket
PostPosted: 00:37 - 25 Jan 2015    Post subject: Reply with quote
Honda h100 rims are 1.4 and take a 2.75 tyre just for comparison
smegballs
PostPosted: 01:55 - 25 Jan 2015    Post subject: Reply with quote
https://i.imgur.com/ZP6VHMM.png
Another sizing chart straight from Maxxis:
https://www.maxxis.co.uk/media/65556/2013-Motorcycle-Tyre-Catalogue.pdf
https://i.imgur.com/rcXXVFB.png
one off
PostPosted: 12:17 - 25 Jan 2015    Post subject: Reply with quote
thanks for the replys
would it be unsafe so fit a 3.50 ? what are the problems with doing so ?
also where is a good place for rims and wheel parts and rebuilds ? im looking at all the options.
i have a 16" rear wheel and would like to go to 18" but need to find a cheap enough way of getting a wheel that will actually fit in my suzuki gn 125
cheers
smegballs
PostPosted: 01:11 - 26 Jan 2015    Post subject: Reply with quote
cheers
Simply speaking, the wider the tyre (for a given rim) the more "pointy" the profile of the tyre will be. Increase the pointyness a little and the bike will turn in faster but increase the pointyness too far and the bike will be unstable and feel like you are riding on ice.
Teflon-Mike
tl;dr
PostPosted: 10:29 - 26 Jan 2015    Post subject: Reply with quote
1/ Why do you want trial tyres on a GN125 cruiser?
2/ WHY do you want trail tyres on a GN125 cruiser!
3/ Having trouble wrapping my head round WHY you would want trail tyres on a 125 cruiser still....
4/ Why... would you want a 'fat' rear tyre, on the front?
Most trial bikes have a 4.00 ish sized rear, and a 2.75 ish sized front.... in fact that is the 'regulation' tyre sizing for competition trials, funnily enough.... and there are a lot of very good reasons why, trail, trial, MX, and enduro 'off-road' bikes, and in fact MOST bikes, road bikes, sports bkes, race bikes, even cruiser's, funnily enough; have this narrow front / fat rear combination..... to a greater or lesser degree.....
5/ I feel an answer that is ether going to involve 'I can Count to Van-Van', or get round to it..... but we'll see. Bottom line, unless it's purely for some warped notion of a survival special or brat-chop; I suspect this is not the 'answer' to any real problem that you might e hoping to solve.. but, back up, elaborate, explain to us WHY you want a fat front trial tyre on a cruiser style commuter 125... and we might be ale to a) explain why it wont solve your problem, b) offer suggestion that might.
6/ Have you got a tape-measure? Have you measured the clearances between the fork-legs and in the rear swing-arm? A 4.00" tyre isn't always 4.00", and when it comes to more 'knobly' off-road tyres, you can often run into issues of the actual knobles making the tyres significantly wider than the stated carcass width and, usually, cos sensible folk tend to be fitting the fat tyre to the back, the treads fouling in the swing arm, chain run, or mudguard... I can only see this being even more of an issue a generally narrower front fork.
one off
PostPosted: 18:14 - 26 Jan 2015    Post subject: Reply with quote
ok thanks for the comments, as a newbie im just looking for some friendly advice, its early days and im still working out what i want to do and what to order and what is safe etc.
pdg
PostPosted: 22:06 - 27 Jan 2015    Post subject: Reply with quote
If this is something you're intending to ride on the road, have you asked about insurance with these modifications you seem to be planning?
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 61.52 Kb
