| mr-jermy |
 mr-jermy Nitrous Nuisance
 Posted: 16:42 - 13 Jan 2015 Post subject: TV wall bracket |
hi all got a couple of questions for those that know with regards to mounting a tv on the wall,
Ideally i want the tv to be mounted on the chimney breast which i've been informed is fine however i have my fish tank below it, which i would move however its the only place for it to go as it is 4ft long and weighs a ton. would it be safe to mount it above the fish tank if i get the right bolts?
secondly what bolts do i need to mount it on to the wall as its a second hand bracket coming from my grandfather but he got rid of the bolts that he had and is in france for the next 3 weeks so i am unable to contact him,
Any help and advice would be much appreciated,
thanks,
Chris, ____________________ currently rebuilding a Honda NS125RL selling a baotian bt49 qt-9 |
| t121anf |
 t121anf World Chat Champion
| Baffler186 |
 Baffler186 World Chat Champion
 Posted: 17:22 - 13 Jan 2015 Post subject: |
look on Amazon/Ebay for a bracket suitable for ypur size TV, and see what fixings it's supplied with. Also look at the back of your TV and see what size screws you'll need. It's likely that the TV mounting points will be the weakest link so you'll need to get the correct sizes.
IIRC my TV had only a few holes with threaded inserts, so you need to get those sizes right. The bracket and wall fixings (i.e. the holes in the bracket) will be numerous so I'd put in as wide a screw as the bracket will allow, with good quality wall plugs. Better be safe than sorry. buy from Toolstation if you have one near, as B&Q etc are a rip-off.
Also as t121anf says, make sure you don't mount it too high, else you'll get a sore neck after 20 minutes. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
| map |
 map Mr Calendar
 Posted: 17:37 - 13 Jan 2015 Post subject: |
Bolt/screw wise to the wall I'd look at coach screw into rawplug fitting.
For fitting TV to bracket as said I'd look at what's provided in a normal kit and get suitable same bits.
Once upon a time I was told bad to put tv on chimney as affected by rising heat. Sounds like that will not be an issue with yours. Probably was just in the early days of plasma and led tv too. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| t121anf |
| mr-jermy |
 Posted: 12:32 - 14 Jan 2015 Post subject: |
thanks for all the advice,
weight wise the tv i've got weighs more than a standard tv not sure why though i presume its just an older tv,
It wouldnt be massively high as my sofa is fairly high and im 6ft 4 so doesnt bother me too much, although i will put my current tv carefully on top of the fish tank making sure that theres enough support for it there to check that it isnt uncomfortable,
i'll be getting the relevant bracket for the tv shortly as soon as my grandad gets back from france as it was his tv to begin with and he had to pay £200 for the bracket,
i have no idea what a coach screw is so ill have to google that haha
you are correct it is bad to have them there or above a radiator however the fire was taken out by the council when we moved in unfortunately they blocked up the fire as i was going to put shelving inside it for dvds etc, the only other place to mount the tv is above the radiator which isnt a good idea unless i turn the radiator off permanently, as where it is i keep knocking it and i keep feeling that im going to knock it off the unit.
will have a look into the suggestions and see what i can sort out, any other ideas are much appreciated,
thanks,
| map |
 map Mr Calendar
| Benjums |
 Benjums Scooby Slapper
| weasley |
 weasley World Chat Champion
 Posted: 14:27 - 14 Jan 2015 Post subject: |
My main cause for vex with wall-mounting is the cable runs. Ideally, if I were doing it, I would install at least power, co-ax and HDMI sockets behind where the TV will sit, so that the TV can operate with no trailing cables. My TV currently has power, 3 HDMI, 1 SCART ( ) and one 3.5 mm connected. That's without any aerial or ethernet connection and relies on direct audio connections from my PS3 and Sky box to the amp (otherwise you could add an optical connection to the TV too). I also have a PS3 camera and Wii sensor on it and occasionally connect my DSLR by USB or HDMI.
Once the TV is up, you have to think about how you will feed it power and pictures - where will all that stuff go? I'm a bit OCD when it comes to cables though - I can't stand seeing trailed cables and don't like trunking.
For the mounting, I would probably also use coach bolts and plugs - luckily my walls are brick so will take a plug (but I always use my own, never the randomly supplied ones). ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| mr-jermy |
 Posted: 14:50 - 14 Jan 2015 Post subject: |
It's a brick chimney so should be easy enough to mount on there its just a question as to how long should the bolts be? as i dont want to get some that are too short,
yeah thats what i would rather do i have a tendancy to overtighten screws and round off the heads haha.
I'm not keen on the cables either im going to have to get some cable tidy for it but thankfully as it will be above my fish tank i can hide the cables behind that. i've currently got everything on my unit which will fit comfortably next to the chimney so will be tucked out of the way thankfully, ideally when the council give me the chance to purchase the house i'm planning to put a hole back in the chimney breast and mount everything in there as it will be alot tidier.
thanks,
| Vincent |
 Vincent Banned
| mr-jermy |
 Posted: 12:08 - 16 Jan 2015 Post subject: |
i think a spirit level is the only thing i havent got i must remember to get one before i attempt this,
thanks,
| BTTD |
 BTTD World Chat Champion
| mr-jermy |
 Posted: 14:14 - 16 Jan 2015 Post subject: |
i'm not sure i think the bracket and tv were bought around 2006-2007 so the prices for the brackets would have been a lot more expensive then rather than now, plus its probably about twice the weight of my old tv so needs a decent one to secure it on the wall. will pick up some nylon plugs as well,
thanks,
| fredsredhat |
 fredsredhat Traffic Copper
| Ribenapigeon |
 Ribenapigeon Super Spammer
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
