NINJA 250 0-60
RideOrDie
PostPosted: 20:12 - 25 Jan 2015    Post subject: NINJA 250 0-60 Reply with quote
Hello
my ninja 2009 shape
has an exhaust and air filter slot in pods
i have been told they are usless without
Power Commander
so i have purchase a power commander to sort the air and fuel ratio
with the exhaust and air filter
Standard 0-60 is 7.5seconds
what would i be able to get to 0-60 >?
as all im intrested in is 0-60
and what else can i do to improve it,
as i dont want a bigger bike im happy with this just want to improve acceleration
wr6133
PostPosted: 20:21 - 25 Jan 2015    Post subject: Reply with quote
Smaller front sprocket.
The pod filters may be losing you power
RideOrDie
PostPosted: 20:28 - 25 Jan 2015    Post subject: Reply with quote
Hi, i didn't use the pod filters i replaced the standard one with a k&n
slot in filter is that okay?
what smaller sprocket size shall i get?
does it reduce top end of i change
and do i have to also change the rear sprocket or can i leave that
Musketeer
PostPosted: 20:30 - 25 Jan 2015    Post subject: Reply with quote
You've got many options:
- bigger rear sprocket
- pink power bands
- engine swap
- jet pack
- warp drive
- flux capacitor
wr6133
PostPosted: 20:32 - 25 Jan 2015    Post subject: Reply with quote
Dropping a tooth on the front is equivalent too adding a few on the rear. It can gain you acceleration but will lose you top end.
Fladdem
PostPosted: 22:30 - 25 Jan 2015    Post subject: Reply with quote
Sold your YZF-R125, bought a ninja 250 and got a licence over Christmas did you? Laughing
Chain and sprockets wise, to gain acceleration, you will lose top-end, if your bike has the power to pull all the way to the redline that is. My TTR 250 doesn't have the torque to rev out in top with the standard gearing so actually went faster flat-out with slightly shorter gearing as well as accelerating better, because the engine could actually rev higher to get to the top speed. Thumbs Up May not work with all bikes, but that's what happened with mine.
My CRM is the same, it will only touch a tonne if you thrash it to about 90 in 5th before changing to top, or else the revs drop off and it falls out of the powerband and doesn't have the torque to pick the revs back up into the power, so you have to drop it down a cog or two and begin again.
Have a play with this if you're telling the truth:
https://www.gearingcommander.com/
The last post was made 11 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.99 - MySQL Queries: 15 - Page Size: 48.56 Kb
