Speedo/Rev issues
ninjameaniekt...
PostPosted: 12:28 - 26 Jan 2015    Post subject: Speedo/Rev issues Reply with quote
Howdy
So my ninja has sprung up with an issue recently. Its a 2009 model and has done 33K miles. Ive noticed that the rev needle wobbles and when this happens the speedo goes up and down by 1mph. So say i ride at 50, and i maintain the speed, its showing 49,50,51,50,49,50,51 etc.
The other 'feeling' im getting from the bike is that when i release the throttle, the deceleration is not smooth (as if somebody is ever so slightly blipping the throttle) and so the bike wobbles forwards and backwards - again not massively but its like a rocking sensation.
Any help will be appreciated. Ive not tinkered with the bike recently but before i did i just wanted to know if anybody had any pointers. Its had its normal services but the valve clearances haven't been checked. Thanks Smile
Kawasaki Ninja ZX6R, Kawasaki Meanstreak 1500, KTM RC8, KTM 450 SXF
Taught2BCauti...
PostPosted: 12:52 - 26 Jan 2015    Post subject: Reply with quote
Could be a voltage issue - can you connect a voltmeter across the battery, in such a way that you can see it when you are riding?
If the voltage is fluctuating, that could be the cause.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
ninjameaniekt...
PostPosted: 14:49 - 26 Jan 2015    Post subject: Reply with quote
This can be done with long enough leads i think. Ill try this - just wondering, would you expect a constant value?
RhynoCZ
PostPosted: 14:52 - 26 Jan 2015    Post subject: Reply with quote
The clocks are voltmeters, more volts go in, more the clocks show, so it should show pretty stable voltage at stable speed. Thumbs Up
PostPosted: 14:57 - 26 Jan 2015    Post subject: Reply with quote
On my old TL1000S I had to get the throttle bodies balanced, you could also reset and adjust the throttle position sensor.
Lots of silly little things like that could likely cause those issues.
Taught2BCauti...
PostPosted: 15:00 - 26 Jan 2015    Post subject: Reply with quote
I would expect the readings to be quite stable, as long as the revs are stable, but it might be better to use an old 'Analogue' type meter if you have one.
I have a digital meter that has a 'sampling rate' of 1Hz (once per second) that doesn't show small fluctuations, but my old ex-telecom analogue one does!
You will get a lower reading at tick-over, and it should peak at around 4,000 rpm.
Anything less than 12.4v, or higher than 13.7v will need further investigation - possibly the Reg/Rec is failing.
ninjameaniekt...
PostPosted: 16:06 - 26 Jan 2015    Post subject: Reply with quote
Thanks for all the responses - its a great starting point.
Ive also been reading some other forums and they mention the TPS sensor. Would this be the cause? Apparently these can require adjustment/replacement however im not sure how easy this is to do.
Also...could it be that the battery needs replacing? Ive had the same battery on the bike four about 4 years and do about 30 miles a day for commuting and it always starts first time. When do people replace theirs?
Sorry for he knoob questions.
Taught2BCauti...
PostPosted: 16:42 - 26 Jan 2015    Post subject: Reply with quote
The TPS could be at fault, but wouldn't account for the 'wobble' you are getting on the rev counter speedo at the same time - which is what made me think about checking the system voltage first.
Easier to test, and eliminates a lot of other possible faults.
You are lucky to get 4 years out of a battery - must be a decent make Smile
Edit:
I meant 'Speedo!
PostPosted: 16:53 - 26 Jan 2015    Post subject: Reply with quote
Wouldn't account for the wobble...? Have you seen what happens to the rev gauge when you twist the throttle... it moves. With an iffy TPS it will go up and down..
ninjameaniekt...
PostPosted: 16:58 - 26 Jan 2015    Post subject: Reply with quote
When i accelerate/twist the throttle, the rev needle is like two steps forward one step back. It wobbles up and then as i release it wobbles down. Again by wobble i mean about 2 or 3 mm.
The battery is just the YUASA OEM one...i think its lasted this long because im doing so many miles on it. Im guessing the consensus would be to change every 2 or 3 years.
PostPosted: 17:03 - 26 Jan 2015    Post subject: Reply with quote
Probably worth changing it now anyway, grab yourself a Motobatt
Taught2BCauti...
PostPosted: 17:12 - 26 Jan 2015    Post subject: Reply with quote
Sorry - my bad - I meant to say 'Speedo' (edited).
I'm just not sure how a faulty TPS would affect the speedo and the rev counter at the same time.
PostPosted: 17:17 - 26 Jan 2015    Post subject: Reply with quote
If the speedo is voltage based, I'm sure they would rely on the throttle for some part of that system.
pdg
PostPosted: 17:19 - 26 Jan 2015    Post subject: Reply with quote
'My' consensus is to change it when it needs changing. If it starts acting up within warranty then get a free new one,
Why buy a new one just for the hell of it?
Properly looked after a lead acid battery can last many years, but personally I haven't managed more than ten years from a battery yet (although I have one getting close).
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
ninjameaniekt...
PostPosted: 12:46 - 02 Feb 2015    Post subject: Mechanical or electrical Reply with quote
Thanks all - i was pondering this issue further.
I would be inclined to think that this is a mechanical issue rather than an electrical one (please correct me if im wrong) but heres my trail of thought.
I would assume that as the bike is pulsating (like the bike is being blipped ever so slightly) whilst im riding, then that means the bike is accelerating and decelerating constantly. Could it be that one of the cylinders is not firing as efficiently? Or am i talking bs and its an electrical fault. I cant understand why im feeling the bike pulse. Thanks in advance.
PostPosted: 12:49 - 02 Feb 2015    Post subject: Reply with quote
Have you balanced throttle bodies and reset the throttle position sensor.
Start on a level playing field.
The last post was made 11 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.95 - MySQL Queries: 13 - Page Size: 90.16 Kb
