NSR 125 problems plz help me
should i fixe this bike or burn it and claim(jk)
yes
50%
 50%  [ 3 ]
no
50%
 50%  [ 3 ]
Total Votes : 6
jesus_tricky
PostPosted: 21:45 - 25 Jan 2005    Post subject: NSR 125 problems plz help me Reply with quote
i got a baby nsr and had nothing but trouble with it, i have had a new carb and anew barrel fitted,
origanily i had a block in the injectors, it all got cleaned out and then i got my bike back and began to work on the fairing a full respray, i proceeded to take of the fairing to find a frightful crack on the barrel, since then it has been rapaired and i have been cutting out when ticking over i nuetral, i have tried to kick start it, but there is no feul getting to it,
i have a:
G reg nsr125rk
all original no fancy stuff on it
plz if anyone has an idea pleas tell me
Gazdaman
I did a trackday!!!
PostPosted: 22:56 - 25 Jan 2005    Post subject: Reply with quote
Sounds like a carb problem, there'll be a screw on it to adjust the revs at tickover.
Don't just play with the screws willy-nilly though, if you're adjusting the mixture the wrong way you could start fouling plugs or worse holing pistons.
Gaz
fuzz
PostPosted: 00:59 - 26 Jan 2005    Post subject: Reply with quote
Check out Keiths post on Dellorto carbs if your unsure how to adjust the screws. https://www.bikechatforums.com/viewtopic.php?t=17124
jesus_tricky
PostPosted: 18:28 - 26 Jan 2005    Post subject: Reply with quote
cheers peeps, i will see what i can do but as i had new one fitted i'm sure the garage wshould do it free for it should have been done in the first place thanks
jesus_tricky
PostPosted: 21:55 - 28 Jan 2005    Post subject: cheers Reply with quote
after taing it to the shops it was simply oil on the spark plug so anyone with soimilar probs here could be the answer
Gazdaman
I did a trackday!!!
PostPosted: 11:52 - 29 Jan 2005    Post subject: Reply with quote
You have to ask yourself *why* there's oil on the spark plug. To me it suggests an underlaying carb misadjustment.
The spark plug should always be the first thing you check with mysterious engine troubles in a 2 smoke.
Gaz
The last post was made 21 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 15 - Page Size: 49.09 Kb
