Replacement Master Cylinders
skyehigh
PostPosted: 11:51 - 28 Jan 2015    Post subject: Replacement Master Cylinders Reply with quote
I've had an issue with the front brake master cylinder on my 1991 FZ750 despite renewing the seals etc. I just cannot get the system to firm up and I think the bore within the unit may be scored and allowing air in.
I would love a Brembo or similar replacement but at £250 its not really an option so wondered if anyone had an thoughts or experience of these - at the end of the day nearly everything you buy now is made in China!
https://www.ebay.co.uk/itm/171624169263?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Many Thanks
wr6133
PostPosted: 12:29 - 28 Jan 2015    Post subject: Reply with quote
Try for a used OEM one and rebuild kit. I had one of those Chinese ones (same main bit and reservoir, slightly different lever), it was ok for a week after that it began to let air in the system due to poor sealing. They cost a few pounds in China if you want an idea of the quality you are buying.
Are you sure the M/C is knackered? On my ZZR I went through 2 caliper rebuilds, 3 M/C's and rebuilds just to finally out of desperation/process of elimination swap the goodridge braided lines back to the crappy OEM ones and then ended up with perfect brakes!
Fizzer Thou
PostPosted: 12:33 - 28 Jan 2015    Post subject: Reply with quote
When I first bought my Exup 1000 I preferred the look of master cylinders with a remote reservoir and so got hold of both the brake and the clutch items from a ZXR750R and they work perfectly
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture027.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture028.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20091222_10.jpg
The adjustable span levers are a real bonus.
The master cylinders from a YZF750R are also the same Wink
Always have a 'Plan B'
PostPosted: 12:40 - 28 Jan 2015    Post subject: Reply with quote
Would you really trust your life to a £30 part from ebay made in china?
Edit:- Fucking hell I just realised you get both master cylinders for £30!!!
I wouldn't touch with a bargepole.
PostPosted: 13:32 - 28 Jan 2015    Post subject: Reply with quote
Many people do, unwittingly.
I'd echo wr's comment about not leaping to assumptions. Have you had the rebuild M/C apart again to check that the new seals haven't given out? That just happened to me with a "new" rebuild kit that I suspect had been sitting around dry for years.
bladeblaster
PostPosted: 13:35 - 28 Jan 2015    Post subject: Reply with quote
The mistake most people make when bleeding brakes is not properly bleeding the master cylinder itself. If I were a betting man, I would wager that is your problem.
skyehigh
PostPosted: 14:16 - 28 Jan 2015    Post subject: Reply with quote
Quite a few wise words guys. The bike had been sitting for 5 years before I started a refurb. New Calipers were required and yes it does have braided hose so maybe worth changing them as well. I also like the look of those Kawasaki items - may see if any are available on eBay!
Matt B
PostPosted: 14:36 - 28 Jan 2015    Post subject: Reply with quote
Is it any different to buying a Chinese made bike with Chinese made brake parts fitted?
Anyways, don't think I would do it.
The last post was made 10 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 57.45 Kb
