Fooked bearings?
tatters
Exxon Valdez
PostPosted: 01:18 - 26 Jan 2005    Post subject: Fooked bearings? Reply with quote
The awful humming noise from my KR1-S engine has returned and is now much louder and l thinks that it has nothing to with the cooling system as before. Me and my old man reckon that it’s coming either from the main bearings/ magneto/ balancer shaft area. So last night l took the balancer shaft out all looks fine apart from some small amounts of magnetic metal underneath on of the bearing each side of the shaft also this bearing is not a pressed fit and moves/sides off the shaft (no wear on shaft Confused ) which l think shouldn’t be right could this cause the loud humming noise?
Symptoms:
No noise at all at tick over or below 3,000 revs or after 7,000 revs
Noise can only really be heard on the throttle after-burn
Comes from the left hand side of the engine
Any Suggestions, very Grateful for any
sickpup
Old Timer
PostPosted: 02:38 - 26 Jan 2005    Post subject: Reply with quote
Sounds like the small ends but could be any bearing really. Strip the engine and find out.
Robby
Dirty Old Man
PostPosted: 07:05 - 26 Jan 2005    Post subject: Reply with quote
I like this guy. He has a proper 2 stroke man response.
tatters
Exxon Valdez
PostPosted: 19:20 - 26 Jan 2005    Post subject: Reply with quote
l don,t think its the small end bearings beacuse they were re-placed at the 1st re-build 2,000 miles ago and small end bearing noise is ushally heard at tick over, were l have no noise.
sickpup
Old Timer
PostPosted: 04:29 - 27 Jan 2005    Post subject: Reply with quote
The amount of times I stripped My X7 pistoned 300cc RG250WD you would not believe. Bit of a bitch to work on as I had to machine the pistons to fit. Ah 55ish BHP and 120KG RG500 front end great second bike mate.
catgate
PostPosted: 16:30 - 27 Jan 2005    Post subject: Reply with quote
Heavy rumbling low down in the engine on "over run" is usually a good (or perhaps bad) sign of worn main bearings (perhaps balance shafts too, I am not sure about that) because the "load" on them, whilst under load, keeps them from waving about in their locating "holes" (often called bearings).
"Always remember you're unique, just like everyone else."
PostPosted: 20:41 - 27 Jan 2005    Post subject: Reply with quote
Main bearings have normally whinned when they have been on their way out on me. Suspect they could rumble is badly worn, but (assuming it comes from the engine not the gearbox) then I would be a bit more suspicious of a big end bearing starting to fail.
sickpup
Old Timer
PostPosted: 21:00 - 27 Jan 2005    Post subject: Reply with quote
And if it's not the small ends your gonna have to strip it anyway so why wait, strip the fucker.
catgate
PostPosted: 23:55 - 27 Jan 2005    Post subject: Reply with quote
strip the fucker.
I thought that was a Yamaha model?
The last post was made 21 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 61.34 Kb
