Brake disk getting rusty
Jaloopa
PostPosted: 14:31 - 29 Jan 2015    Post subject: Brake disk getting rusty Reply with quote
My brake disk gets a very visible film of rust over it when left overnight, even with a cover over the bike (covering it does seem to help a bit, but not hugely).
Most mornings, it's also a little bit seized up, and the wheel won't move without rocking the bike forwards and back a bit.
Two questions:
1 - is it dangerous? When running I never see any signs that the brake is in danger of seizing, but could it happen?
2 - What can I do about it? Oiling on a brake is obviously a bad idea, but is there any other way short of getting a new disk/pads?
The bike is a 1995 Kawasaki ZZR600, if that's important.
mattsprattuk wrote: but at least the lifan could do like 104mph in 3rd gear
mudcow007
PostPosted: 14:33 - 29 Jan 2015    Post subject: Reply with quote
rusty discs are a good sign, means they have a high iron content, its when they dont rust you get worried
normal usage will wear the rust off
dont worry, be happy.....(how many of you just hummed the song??)
PostPosted: 14:47 - 29 Jan 2015    Post subject: Re: Brake disk getting rusty Reply with quote
Yup, it's fine. But...
I'd clean the calipers and pistons.
wr6133
PostPosted: 14:48 - 29 Jan 2015    Post subject: Reply with quote
Are they cheap Chinese aftermarket ones? If so that is a feature, they cost something like £20 a pop in China so that's the quality you get (the £100 added when they make it to eBay is just the round-eye tax).
Jaloopa
PostPosted: 14:57 - 29 Jan 2015    Post subject: Reply with quote
Don't know, they were already on there when I bought it in November.
The last owner didn't seem the type to cheap out on parts though
Fair enough. Never noticed it on my old ER5, so I wasn't sure. Cheers
mudcow007
PostPosted: 15:00 - 29 Jan 2015    Post subject: Reply with quote
also worth remembering loads of salt on the roads at the moment, which will make rusty crustyness look worserer
dont spray em with oil Thumbs Up
mentalboy
PostPosted: 17:26 - 29 Jan 2015    Post subject: Re: Brake disk getting rusty Reply with quote
Seems a little strange if used every day! Quite likely cheap discs if filming up over just one night.
As Roger said, check your calipers and pistons for easy movement, even with a furred up disc you should have no problem moving a bike that's only been parked up overnight. Probably be needing new pads too if they've been running tight, you may be able to dress them to remove a hard polish on the surface but if it's been run like it for a while the likelihood is that they'll either be cooked or running low.
Make mine a Corona.
wr6133
PostPosted: 17:44 - 29 Jan 2015    Post subject: Reply with quote
If they look like these https://www.ebay.co.uk/itm/KAWASAKI-ZXR-400-ZZR600-ZZR-600-ZR7-ZX4-ZZR400-ZR550-FRONT-REAR-BRAKE-DISC-NEW-/321384847240?pt=UK_Motorcycle_Parts_13&hash=item4ad4079788 then he cheaped out and the rusting overnight is pretty much to be expected
Nexus Icon
PostPosted: 12:58 - 31 Jan 2015    Post subject: Reply with quote
There's nothing unusual about it, especially at this time of year. Some mornings my car gives a good crack from the rear discs after the handbrake's been on all night and the film of rust on the disc is broken.
I don't often take the bike out in wet, salty conditions but I'd imagine it would be similar.
Discs are most commonly made from cast iron so they're bound to rust very quickly.
Greetings from Shitsville!
orac
PostPosted: 15:35 - 31 Jan 2015    Post subject: Reply with quote
I cant say for other brands but EBC discs (£300 a pair) rust faster than you can "rusty" couple miles and they are fine. another to note is that the HH pads will corrode to the disc if left - I have had it happen over night to some degree, a quick rock back and forth normally frees thing up. sometimes its takes more if left for longer.
The last post was made 11 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 65.66 Kb
