What Type of Bit to Drill Rounded Bolt
b422063
PostPosted: 10:02 - 01 Feb 2015    Post subject: What Type of Bit to Drill Rounded Bolt Reply with quote
I'm looking to drill out a rounded bolt as I can't get a grinder to it. Is this the type of drill bit one uses, or is there a better/stronger type?
Don't want it to blunt after seconds of use.
stirlinggaz
PostPosted: 10:33 - 01 Feb 2015    Post subject: Reply with quote
hi,
yup thats what you need, cobalt drill bits Thumbs Up
i have a set & they have NEVER failed me.
there are "better"(carbide?) drill bits available but would just be overkill.
you can usually get away with just buying 3 or 4 ie 3,5 & 7mm as an example.
remember to drill slowly, keep the bit cool & use some sort of cutting oil.
i normally use a cheap can of 3 in 1 oil aerosol from poundland, with the wee red straw. it cleans most of the swarf away, cools the bit & lubes it too.
i know i should go look for more suitable cutting oil, but can never remember where i put it lol.
cheers,
GAZ
Taught2BCauti...
PostPosted: 11:05 - 01 Feb 2015    Post subject: Reply with quote
I use a set of These . Use them like a drill, but in reverse. If you are lucky, they will dig-in and grip the bolt, and remove it.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
b422063
PostPosted: 12:26 - 01 Feb 2015    Post subject: Reply with quote
Woo! Took about 30 seconds to drill out! Perfect! Smile
PostPosted: 13:45 - 01 Feb 2015    Post subject: Reply with quote
Or just get a set of drill bits that work spinning to the left and 9/10 the bolt will unwind as you drill it out. Worst case scenario is that you drill it out.
kramdra
PostPosted: 14:32 - 01 Feb 2015    Post subject: Reply with quote
Its useful to have a 80grit and 600grit drill attachments for sharpening, only takes a couple of seconds - HSS wont blunt quickly unless your drilling harder metals/stainless or getting it too hot.
Toolstation/heller cobalt ones are good enough.
Carbide is overkill and because if its hardness, needs diamond abrasives/grinding wheel to sharpen and will chip easily. It will cut anything with ease Thumbs Up Have a Dormer set.
Tauht2BCautious - that set is cheap carbon steel, probably made in china, unlikely to last more than 5 mins, but might do the job..
The last post was made 11 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 48.79 Kb
