Air filters
Dr Nick
PostPosted: 23:23 - 26 Jan 2005    Post subject: Air filters Reply with quote
Having my Major service next week and was thinking about putting a k&n filter or gibson filter on instead of the standard honda air filter as i apparently need a new air filter at 16k mile service, i asked the mechanic if it need rejetting and he said not really, i already have a Leovince end can on at the moment, and thought it would need a dynojet kit with both air filter and end can?, as it would run lean? attached is a scan of my dynochart which has fuel to air ratio on it if anyone could tell me if its running rich of lean at the moment? thought it would help
Thanks
is that it
AcIdBuRnZ
PostPosted: 01:46 - 27 Jan 2005    Post subject: Reply with quote
I'd say that is a very nice power curve you got there Thumbs Up
No dips or flat spots - any idea what it was like before you fitted the can?
As far as dyno jetting, maybe you should fit the air filter and see how it runs first? Will it cost a lot to get it (dyno jetting) done?
I know K&N sell jetting kits designed to match their air filters. Wouldn't do any harm I suppose - think they go for around £30-£50.
Been thinking about this myself too, let us know if you do it Thumbs Up
Mark
instigator
PostPosted: 10:15 - 27 Jan 2005    Post subject: Reply with quote
I got a k&n filter in my er5 mark. Thumbs Up
Haven't realy noticed the difference really. First gear feels as if its more useful and my mpg has gone up (ABOUT BLOODY TIME)
I automatically assumed that when you got an end can and k&n filter, dynojetting came after that. I don't suppose its vital on every bike, but I suggest you run the bike and see how it feels, and if it wallows in power where you think it shouldn't, then you probably should have it done
Gracie Jones
PostPosted: 10:18 - 27 Jan 2005    Post subject: Reply with quote
Can somebody explain what re-jetting is? Do they adjust the size of the jets in the carbs or what?
cc123
Geez a joab?
PostPosted: 10:25 - 27 Jan 2005    Post subject: Reply with quote
Thats my next step. I wouldn't put a K&N on unless I had the DynoJet kit to match....
I don't think it will instantly make a huge difference but might start knocking the air/fuel mixture out after time.
Nick, how much did it cost you for your Dyno run? What was all included, just a run or some setting up?
Old bikes >>> https://www.bikepics.com/members/cc123/
instigator
PostPosted: 10:37 - 27 Jan 2005    Post subject: Reply with quote
If its just a run(usualy 2 or 3 minimum) and a print out of the power output, it would set you back anywhere between £30 to £60.
Mine cost £45 in stirling and that was with 3 runs.
PostPosted: 11:56 - 27 Jan 2005    Post subject: Reply with quote
To be honest I am very doubtful of any claims for much extra peformance from a K&N. It still has much the same surface area and still retains the standard airbox. Difference in power (and fueling requirements) is probably about the same as the effects of the weather on 2 different days. Most people who will have fitted one will have replaced and old and dirty as hell filter with a new K&N, and noticed the gain more from that.
A can is more likely to need jetting changes while a full system designed for more power is very likely to need them (and that is where the main gain are to be had, rather than just bunging on a cheap can).
Rejetting involves changing various jets in the carb to change the fueling at different revs. Mainly (with a CV carb) the main jet size, needle jet shape, needle jet position and changing the hole in the slide transferring pressure above the slide to affect the speed it opens.
The last post was made 21 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 54.19 Kb
