Radiator Woes
chickenstrip
PostPosted: 11:39 - 05 Feb 2015    Post subject: Radiator Woes Reply with quote
TL;DR as highlighted.
So, selling the house, just put it on the market and two radiators have packed up (of course Rolling Eyes ).
All but one radiator in the house are twin entry with 15mm pipe, so a cheap job by the looks of it. The two that have stopped getting warm are twin entry. British Gas engineer who looked at it yesterday said that there was probably a blockage or two in the narrow pipes, but because of the twin entry valves, it can't be flushed. We were then quoted £1300 to replace all the pipework and convert all rads to single entry, with a "guarantee" (spoken) that the system would be fully functional after this.
Anybody with a bit of knowledge in these matters? Does that sound right? Is there a quick fix (we only need it all to work until the place is sold, so if there's a quick, temporary fix...)? What would you do now?
A little bit of additional info: all the other radiators work, the bathroom one needs regular bleeding though. The boiler was recently serviced and although old, works well. The engineer who visited yesterday did manage to clean quite a lot of gunge out, but to no avail. As far as I know, he just drained and refilled, and cleaned the bottom of the tank.
RhynoCZ
PostPosted: 11:48 - 05 Feb 2015    Post subject: Reply with quote
Drop 1000 pounds, and sell it as it is. Thumbs Up
chickenstrip
PostPosted: 11:53 - 05 Feb 2015    Post subject: Reply with quote
This is what I've been thinking, as I'm concerned if they do the work, they'll just find something else wrong or cause some other expense (flooring?). Unfortunately, we (read as bruv Laughing ) has handed in the contract to the estate agent ticking that the heating system is all up and running. I guess we could always change this?
mudcow007
PostPosted: 12:14 - 05 Feb 2015    Post subject: Reply with quote
im no plumber but....
if you were to remove one fo the blocked rads an run a hose pipe through it, what would happen?
try a magnet along the pipe an see if it gets stuck (magnetised) that could be your blockage
(just googled it)
oh also could it be air locked?
PostPosted: 12:23 - 05 Feb 2015    Post subject: Reply with quote
How do houses know? In the interval between me moving out my last house and the new owners moving in, the downstairs radiators and the shower all packed up, legit.
Turns out they were intending to upgrade them anyway, and £500 cash kept us from wasting time and money on wrangling.
British Gas engineer? Give a local independent a try.
PostPosted: 12:28 - 05 Feb 2015    Post subject: Reply with quote
When people ask for advice on here they are looking for people with experience, not people to google it for them, I'm sure the OP knows how google works. I very much doubt it is air locked. This is a very basic issue and OP/BG would have spotted it.
However one thing I will say is I thought my rad was airlocked, and I screwed the bleed nipple and nothing came out. Turned out the bleeder was blocked. Completely remove the bleed valve and then poke it with something small and spiky. It's unlikely but worth a go before throwing £???? at it
chickenstrip
PostPosted: 12:39 - 05 Feb 2015    Post subject: Reply with quote
I think that's effectively what the engineer did yesterday, because at one point he was running hot water into the system (but not directly into the rad) and the radiator got hot. But he said something about when it was all connected up again, the water wasn't getting round quick enough to heat the radiator under the pressure from the pump, because of blockage. Which is a bit puzzling to me.
Interesting idea, think I'll have to try that. Thumbs Up
Dunno, that's why I'm asking Smile
I've emailed someone I know who is a heating engineer to see if he has an answer, and we would definitely get an independent assessment before spending.
There is a strong temptation to say, "well, it was all working when we signed the estate agent's contract", and just knock a bit off the asking price. The only thing that bothers me is will it affect the chances of the house getting a quick(ish) sale? I have now handed my notice in at work (end of Feb to finish) so I can start my house hunt more seriously and generally sort out the things I need to do, so although I'm ok financially for good bit, I don't want this sale to drag out forever.
Chris, we get water comes out of the bleed valves on the radiators in question.
mudcow007
PostPosted: 13:11 - 05 Feb 2015    Post subject: Reply with quote
I guess the plumber who came out would have checked the bleed valves - for air locked
https://www.homeserve.com/help-advice/boiler-heating/how-to-bleed-a-radiator
maybe worth going around all the rads, when you open the bleeds you will get a drop in pressure on the boiler, so you may have to refill it
chickenstrip
PostPosted: 13:15 - 05 Feb 2015    Post subject: Reply with quote
The engineer refilled the system yesterday. Still 2 rads not working Sad
PostPosted: 13:18 - 05 Feb 2015    Post subject: Reply with quote
Try turning all the other radiators off except one of the blocked ones. Turn that on full and give the valve a good rap with a mallet.
It's worked for me before with a "dead" radiator.
If it's a pressurised system, you could even try letting a bit more water pressure in (within reason).
KaGantua
PostPosted: 13:40 - 05 Feb 2015    Post subject: Reply with quote
is the pin stuck?
it could be it turns to let water in/ out but the actual bearing underneath is seized....
try tightening/ loosening a few times see how you go
DrDonnyBrago
PostPosted: 16:24 - 05 Feb 2015    Post subject: Reply with quote
On a related note...
How would the buyers know? Is it covered in a homebuyers survey?
I ask because I'm buying a house, not because I want to sell a borked one Thumbs Up .
Skudd
PostPosted: 16:32 - 05 Feb 2015    Post subject: Reply with quote
Don't tell of faults selling, sort them out as a buyer, that is what you do. Nothing is perfect and you will change stuff any way. Just one of those things that happens when you buy/sell houses.
RhynoCZ
PostPosted: 18:18 - 05 Feb 2015    Post subject: Reply with quote
I do not know the English law, but the final version of the contract is, commonly, based on the mutual consensus of the seller and buyer.
EDIT: If there was no contract yet, you could wait till the summer. No one is going to check the heating when there's 20°C+ outside. Smile
zark
PostPosted: 18:52 - 05 Feb 2015    Post subject: Reply with quote
Depending on how much you want to fix it - or whether you're asking if you can bodge it and sell the house...
Assuming it used to work... Turn off both parts of the valve to the dodgy rad.
Undo the pipework (the flow pipe will be a long pipe inside the radiator)
Remove rad from wall, blast hose through it in the garden til the water comes out clean. Open each valve a little bit one at a time to make sure water comes out and the valve isn't blocked.
Refit rad, open valves, open air vent to fill rad and check it all gets hot.
If not - then the hot water isn't getting through the valve(s), which means draining down the system to replace.
It's not rocket science, just be methodical.
Or - just sell the house. Thumbs Up
Fizzer Thou
PostPosted: 20:47 - 05 Feb 2015    Post subject: Reply with quote
The mallet trick has worked for me when sorting my Dads house ready for sale.
If there are thermostatic valves on the feed end of the radiator,then the actuating pins inside become jammed closed,particularly if they are situated in a room where the valve shuts down regularly once the room gets to that setting.
Always have a 'Plan B'
Suntan Sid
PostPosted: 21:15 - 05 Feb 2015    Post subject: Reply with quote
I've had the same problem as Fizzer Thou describes, the CH in the house in Cyprus was used very irregularly and the water is super hard there.
When I fired the heating up in winter I had to go round every thermostatic valve and free each pin, they all stuck in place when not being used!
swampy
PostPosted: 23:25 - 05 Feb 2015    Post subject: Reply with quote
Its never been noted (either way - working/not working) on any valuation survey I've had (I've bought five houses over the years). Two of our radiators didn't work when we moved in , and this wasn't raised.
chickenstrip
PostPosted: 23:30 - 05 Feb 2015    Post subject: Reply with quote
They're not thermostatic valves Sad
It would seem that it's one or more blockages in the pipes somewhere. The pipe feed to one of the radiators in question (which I've subsequently realised is single entry) sometimes gets warm, sometimes not. But the radiator itself never gets warm.
I don't think we'll be going with any repairs at this stage, but will negotiate a reduction in the house sale, or offer a "cash-back" incentive, if a prospective buyer pulls us up on it. I have a figure in my mind that I'd be happy to walk away with, and I don't think this will put that in danger.
Thanks to all for advice and suggestions given here though, it's appreciated, and may stand me in good stead for the future Thumbs Up
hmmmnz
PostPosted: 02:45 - 07 Feb 2015    Post subject: Reply with quote
i think we had the same problem in our house, in reguards to the radiator pipe being blocked not the radiator
i flushed the whole system a couple of times and then did a "power flush with the hose connected,
made it better, but not completly unblocked,
i then used kamco hyper flush
put that in the system for a week running it as per normal,
then drained it all out again, flushed, and refilled,
bang all good,
a bit of a palava but seemed to work
the humans are dead
I kick arse for the lord
chickenstrip
PostPosted: 11:16 - 07 Feb 2015    Post subject: Reply with quote
bang all good,
I don't know if we're just being fed BS, but the engineer said we can't flush it through cos of the twin entry radiators?
Al
PostPosted: 18:26 - 07 Feb 2015    Post subject: Reply with quote
I think the issue with power flushing those twin entry valves is that they have a tiny feeder tube that extends along the radiator and there is risk of this blowing off when flushed. The tube is very thin so a flush would be pretty ineffective anyway.
Yamaha FZR400RR 3tj
My Instagram Thingy
kawakid
PostPosted: 19:26 - 07 Feb 2015    Post subject: Reply with quote
£1300 wow, where in the world do you,live.
I've a twin and a 4.
RhynoCZ
PostPosted: 19:53 - 07 Feb 2015    Post subject: Reply with quote
https://i.giftrunk.com/rhn4zf.gif
Anyway, keep us posted. Thumbs Up
Fowlersrs
PostPosted: 23:32 - 07 Feb 2015    Post subject: Reply with quote
Interesting, I do this for a living so il see if I can be of any help.
Could u take a photo of said twin or single entry radiators, this is so I can see what u mean as I've heard of single pipe systems and the more common practice two pipe system now, single pipe is floored in it's desgin and was used in the early days before twin pipe systems where used.
If the engineers had the radiators off the wall and flushed them through with water and they where ok then it's gotta be in the pipe work, what diameter pipe work feeds your radiators, please tell me it's not microbore. To check the flow to the radiators u can actually turn the valves off, take the rad off the wall and then with a bucket by the valve open the valve to see what flow u get through, it should piss out, if it doesn't then there's your prob. No circulation = cold radiator.
I've had houses where I've had to repipe radiators because the pipes feeding it have been literally blocked solid, they where 15mm diameter but where not flushed properly after being on a back boiler system, I could even get a drill bit down them they where that blocked.
The problem with all this power flushing bollocks is that if a system is past a certain point no amount of flushing will solve it, it's cut and replace tbh.
Sounds to me like British gas have offered to repipe the rads affected?
The last post was made 11 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 146.49 Kb
