Why would an air screw not have any effect on running?
Iain.
PostPosted: 10:59 - 06 Feb 2015    Post subject: Why would an air screw not have any effect on running? Reply with quote
As title suggests really...what'd cause that?
I can run the screw all the way in, and all the way out with no change to tickover on this new carb. It's a 21mm Motoforce...looks like some sort of Dellorto clone & takes 5mm Dellorto jets.
https://www.pedparts.co.uk/c/products/lg/Motoforce_Racing_21MM_Carb_Kit.jpg
21mm Motoforce racing carb kit, these are high quality carbs of significantly better quality than most other carbs in their price range.
They include fuel, oil and vacuum connections and 2 overflow nipples. The carb comes as standard with a cable choke adaptor and air filter adaptor allowing you to use different size filters.
Obviously it changes massively when you take the screw completely out of the carburettor due to huge air leak, but it's pretty bizzare & I can't help but wonder what is going on. Should note that it has a Stage 6 manual choke lever fitted to it, and that's operating correctly - however the ped starts without choke, and flicking the choke on kills the engine.
Doesn't really matter cause the ped only sees full throttle or zero thottle, so part throttle fuelling isn't a concern...but I'm interested Thinking
PostPosted: 11:06 - 06 Feb 2015    Post subject: Reply with quote
is it an air screw or a fuel screw?
Iain.
PostPosted: 11:12 - 06 Feb 2015    Post subject: Reply with quote
No idea. Looks to be a clone of a PHBG carb if thats of any help whatsoever?
https://www.mopedarmy.com/wiki/How_To_Tune_PHBG_Carburetors
Reading this, is it possible that my idle jetting is massively out and thats causing the screw to not be able to make enough of a difference to notice?
Triton Thrasher
PostPosted: 13:33 - 06 Feb 2015    Post subject: Reply with quote
Check for a blocked pilot jet.
Rrrrrrrrrrrrrrrrrr
stirlinggaz
PostPosted: 14:10 - 06 Feb 2015    Post subject: Reply with quote
hi,
its fairly easy to tell tbf.....
YES
cheers,
GAZ
Iain.
PostPosted: 14:25 - 06 Feb 2015    Post subject: Reply with quote
How so? On every carb I've looked at you have a mixture screw, and an idle screw.
Ordered a load of idle jets in. Thumbs Up
PostPosted: 14:54 - 06 Feb 2015    Post subject: Reply with quote
Mixture screws AFAIK either let in more air or fuel, hence Air Screw or Fuel screw.
PostPosted: 15:03 - 06 Feb 2015    Post subject: Reply with quote
Fuel screw to adjust how much fuel goes in? That's jets no?
PostPosted: 17:38 - 06 Feb 2015    Post subject: Reply with quote
The mixture screw bypasses that to change the mixture, it either lets more air or more fuel in.
YBR Ric
PostPosted: 18:15 - 06 Feb 2015    Post subject: Reply with quote
Unless you have something exotic, then the general rule of thumb is that the fuel screw is found on the engine side and an air screw on the filter side of the carb.
Most probably an incorrect float height is the cause of your problem.
stirlinggaz
PostPosted: 19:31 - 06 Feb 2015    Post subject: Reply with quote
^^^^this^^^^
HTH,
cheers,
GAZ
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 71.47 Kb
