Hotgrips - Do you need to use a relay?
fatjames
PostPosted: 14:02 - 06 Feb 2015    Post subject: Hotgrips - Do you need to use a relay? Reply with quote
Many thanks to Stinkwheel for his amazing relay wiring guide. It's really helpful (https://www.bikechatforums.com/viewtopic.php?p=2444272).
I plan on following the guide as I also want to add some other electronics, for example, a USB socket and phone charger.
I just wondered if using a relay is still required for heatedgrips, specifically the oxford hotgrips? On the packaging it claims to have battery saving mode "turns the grips off if you forget" How does that work??
WD Forte
PostPosted: 14:12 - 06 Feb 2015    Post subject: Reply with quote
No but a dedicated fuse is a good idea so if it bursts into flames
the rest of the bike will still function as you're screaming
"it burns us! it burns us!"
I reckon the 'smart' types monitor the supply voltage which on a
running bike will be around 14V and if this drops below a threshold voltage,
(as it will when switched off or the bike's struggling to charge sufficiently)
the grips will/should turn themselves off.
While I'm rantin on.....
A relay powered up at ignition on and vice versa
would ensure non smart type grips don't get left on.
You could do the relay method if you want a belt and braces system
bikers smell of wee
Matt B
PostPosted: 14:18 - 06 Feb 2015    Post subject: Reply with quote
You can just wire them into a circuit that is ignition switched.
On the Pan they are wired into the front brake circuit via the microswitch*
* In b 4 your loom will melt and bike will catch fire doing that -this is where the standard Honda grips connect, it has a specific little bit of loom for it.
DrSnoosnoo
PostPosted: 14:24 - 06 Feb 2015    Post subject: Reply with quote
You might as well use it through the relay as when you come to add your charger etc, the relay is already there, you just need to plug the additions in.
PS I followed Stinkwheel's walkthrough too, it was very helpful and really clear too. My bike hasn't set on fire yet.
PostPosted: 14:25 - 06 Feb 2015    Post subject: Reply with quote
I'd use a relay as I wouldn't trust the standard wiring to cope with the current from the grips.
fatjames
PostPosted: 14:29 - 06 Feb 2015    Post subject: Reply with quote
WD Forte wrote:
dedicated fuse
Yeah, it has an inline blade fuse on the + side of the mini loom.
I didn't think it would so I ordered a pack. I do like to fill my workshop with little jars and boxes filled with this type of thing, so don't mind! Then I can lose them and need to buy more next project time!
I'm was half thinking about putting power into my topbox, then I can charge the pad or laptop maybe have a little light. But then I thought this is bike, not a fucking motor home!
Matt B
PostPosted: 14:41 - 06 Feb 2015    Post subject: Reply with quote
Grips under 4A = less than a 55W bulb.
kramdra
PostPosted: 14:59 - 06 Feb 2015    Post subject: Re: Hotgrips - Do you need to use a relay? Reply with quote
fatjames wrote:
Specifically the oxford hotgrips? On the packaging it claims to have battery saving mode "turns the grips off if you forget" How does that work??
Bollocks. Doesnt do shit, as the cutoff voltage set by oxford is 11.8v, which is a very flat battery. Ideally it would be set around 13v, which is that of an almost full battery - but should be higher with engine running.
Plus the controllers are not waterproof, poor design on the casing.
Id say the grips and enevitable bump starting in middle of nowhere did significantly quicken the killing of my regulator and battery in 2012.
Snorty
PostPosted: 15:31 - 06 Feb 2015    Post subject: Reply with quote
I've got the premium grips with the battery saving mode. Wired directly from the battery (with an in-line fuse). They go onto a 2 min turn-off timer when they detect no charging current. Can't fault them thus far.
WD Forte
PostPosted: 15:40 - 06 Feb 2015    Post subject: Re: Hotgrips - Do you need to use a relay? Reply with quote
Yep, a 11.8v threshold is worse than useless as Kramdra says,
I wouldn't want it much below 13.5V
A relay is a safer bet if you can't trust 'smart' controllers
bikers smell of wee
WD Forte
PostPosted: 15:47 - 06 Feb 2015    Post subject: Reply with quote
A heated top box?
Luxury !
I was in town the other day and left the helmet in the top box
An hour so later I got back to the bike and putting my helmet on
got a "Jebus H cripes!" it was freezing and a top box heater project
did cross my mind for a wee while.
I quickly dismissed it as unmanly and the sort of thing
some johnny foriegner would do.
bikers smell of wee
Codezombie
PostPosted: 17:18 - 06 Feb 2015    Post subject: Re: Hotgrips - Do you need to use a relay? Reply with quote
The new ones supposedly look at how noisy the power signal is (DC should'nt really be moving about much after all), if its really clean it assumes the engine is turned off.
Its a known issue for Zero's bikes because their accessory power is normally pretty clean even when the bikes are running, so the hand grips keep turning themselves off.
Least that was what I was told. Wink
2015 Zero-SR; Yamaha Diversion 900
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 06 Feb 2015    Post subject: Reply with quote
Alledgedly not, but I'd rather not overload wiring that is generally only just of a grade capable of managing the load already on there.
Triumph Sprint ST 1050
Snorty
PostPosted: 18:15 - 06 Feb 2015    Post subject: Re: Hotgrips - Do you need to use a relay? Reply with quote
This is what mine does, that's the Premium Hot Grips.
PostPosted: 19:50 - 06 Feb 2015    Post subject: Re: Hotgrips - Do you need to use a relay? Reply with quote
In theory no, and in practice some people have had problems when using these type of grips with a relay.
We had some HG heated grips on one bike and these turned themselves off with a low voltage. Bit of a pain as they wouldn't turn on after just starting the engine, so you needed to ride a bit and then faff around trying to press and hold the tiny buttons to turn them on.
Which is a fairly hefty load and a substantial part of the total output of the charging system on many bikes.
talkToTheHat
PostPosted: 04:09 - 07 Feb 2015    Post subject: Reply with quote
I wired my oxford premiums straight to battery (with inline fuse). I have not yet killed battery through forgetfulness. On some cold days when the idle was shit on the old blowing OEM exhaust i've had the battery saver light come on if i've put the heated grips on straight after starting the bike and the bike is idling and I have left the headlight on. Is not a problem if I dont switch everything on straight away, fixed with new exhaust and idle speed setting.
Will fit an accessory relay if they ever become a problem or if I have other powered accessories, but for now simpler is less to go wrong.
Bandit. does. everything.
Davenaylor
PostPosted: 22:00 - 07 Feb 2015    Post subject: Reply with quote
Mine have died after a years use. I have the Oxford smart grips. They turn themselves off when riding. I've been meaning to post about it on here. They seem to behave when the revs are up, then when the revs drop the control unit decide to turn off like the power is cut.
Reading this I wonder if I have a poorly bike if the revs are upping the current. It started after the bike was blown over in high wind. They are wired straight to the battery. Time for a multi meter me thinks.
evoboy
PostPosted: 00:47 - 09 Feb 2015    Post subject: Reply with quote
In my experience, the grips perform much better when ran through a relay instead of being spliced into existing wiring.
Rewired the spot light and the heated grips on my NTV last week as I rushed putting them on and just spliced into existing wiring. With the intentions of doing it properly. ( 3 months later Laughing )
The grips would take ages to warm up, but now they are wired in properly, they take 1/4 of the time to get hot.
APT Motorcycles
talkToTheHat
PostPosted: 11:29 - 09 Feb 2015    Post subject: Reply with quote
Davenaylor wrote:
…They turn themselves off when riding. ... They seem to behave when the revs are up, then when the revs drop the control unit decide to turn off like the power is cut.
Could well be the supply voltage is low. You have a short somewhere or a loose / corroded connection or your battery may have leaked when the bike was blown over.
Davenaylor
PostPosted: 11:30 - 09 Feb 2015    Post subject: Reply with quote
cheers, i'll get the seat off and look at the weekend
iooi
PostPosted: 12:08 - 09 Feb 2015    Post subject: Reply with quote
Which is another reason to wire through a relay. You get a nice clean supply to them.
Each connection can = a drop in power to them.
Which is why if you wire your headlights direct through a relay you get much better lighting, than when wired through the usual switches Thumbs Up
PostPosted: 20:13 - 09 Feb 2015    Post subject: Reply with quote
Would probably depend on what you wire them through (and after a switch is adding a load of extra load on the switch). The power sensing ones are normally meant to be wired directly to the battery (hopefully via a fuse) without chopping into any existing wiring.
talkToTheHat
PostPosted: 18:59 - 11 Feb 2015    Post subject: Reply with quote
Indeed the loom provided with the power sensing oxford kit is complete with crimped eyelets to fit direct to battery and an inline fuse, so the wiring is sufficient and minimal. It's at joints, connections and switches that the largest voltage dropmwill be found on a small vehicle loom.
The last post was made 11 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.98 - MySQL Queries: 13 - Page Size: 125.26 Kb
