How often do trackday bike engines need a refresh? (600cc)
DaveCR
PostPosted: 17:22 - 06 Feb 2015    Post subject: How often do trackday bike engines need a refresh? (600cc) Reply with quote
Hello!
I've got a CBR600RR (05) and with HRC cams as the main engine mod. It's done about 1000 miles since the last refresh - which included new pistons / rings / mains and big end shells and the cam chain (work done by Ray Stringer). At the time, Ray advised it looked like the valves had very recently been changed.
The bike is used for trackdays these days by me, a low-end fast group rider with what I would call a "slow club racer" skill level (lap times around Oulton at 1:59s).
Please can anyone advise what's a safe mileage to take the engines before a refresh with new valves?
Any advice would be much appreciated!
Dave.
robertw95
PostPosted: 18:29 - 06 Feb 2015    Post subject: Reply with quote
As long as oil and filter is done regularly I dont think you need to worry too much, Id maybe just give the valve clearances a check for piece of mind
07 Dt125r, sv650s k8, zx6rr 04
PostPosted: 18:52 - 06 Feb 2015    Post subject: Reply with quote
You're joking, right?
Carvel
PostPosted: 18:53 - 06 Feb 2015    Post subject: Reply with quote
Lol
monkeybiker
PostPosted: 20:12 - 06 Feb 2015    Post subject: Reply with quote
Isn't the regular engine rebuild more for racing engines were the tolerances are tighter?
PostPosted: 20:19 - 06 Feb 2015    Post subject: Reply with quote
I'd just ride it. Regular oil changes.
Fisty
PostPosted: 20:51 - 06 Feb 2015    Post subject: Reply with quote
Is this a troll?
Fatter and faster than Fret
stevo as b4
PostPosted: 20:53 - 06 Feb 2015    Post subject: Reply with quote
As paddy said, unless you've gone all out on expensive engine tuning work/internals that you don't want to trash, then why not do regular services and oil/filter changes and just ride the thing?
Trackday riding is still quite a bit away from race use, but you just need to find a suitable way to equate hours of use to mileage. If your doing regular maintenance you'd pick up on any problems developing most likely too. Things like 1/2ing valve clearance checks and a yearly compression or leak down test would give you engine health indications, as would keeping an eye on oil levels and coolant etc.
How anal do you want to be? You could strip the engine every year and have all the moving parts analysed under the micro scope to look for cracks and plastigauge all your bearing surfaces, and measure the bores and pistons with a micrometer/bore gauge, but it would be a waste of riding time.
I also bet spare engines are cheaper from broken bikes than re-building a modern 600cc lump too.
DaveCR
PostPosted: 21:10 - 17 Feb 2015    Post subject: Reply with quote
Hi everyone,
Many thanks for all the responses, much appreciated! I've checked the valve clearances today. They are all the same as when it was refreshed apart from one of the exhaust valves which is now .01mm smaller!
Looks like there's a few more miles left in it yet and about £1800 I don't have to fork out Wink
Dave.
PostPosted: 23:04 - 17 Feb 2015    Post subject: Re: How often do trackday bike engines need a refresh? (600c Reply with quote
I'd only start worrying about 'refreshes' when you're getting to maybe 15-20% extra power over standard.
And for a trackbike, rather than bike you're trying to win races on; I'd just get a new engine and sell the old for parts, which'll have you quite a few trackdays worth of money better off compared to paying for it to be properly 'refreshed'.
Ariel Badger
PostPosted: 23:20 - 17 Feb 2015    Post subject: Reply with quote
My bike (which produces double the designed HP) gets a rebuild every 25 miles or so and an oil change every 5.
PostPosted: 09:47 - 18 Feb 2015    Post subject: Reply with quote
I fail to understand why you need such a highly strung 600 as a track day bike? Why not buy a FireBlade instead, and service it once a year?
DaveCR
PostPosted: 11:30 - 19 Feb 2015    Post subject: Reply with quote
I did consider changing the bike for a 1000 a while back but decided not to. I've had it for 6 years nearly and it's an ex Cal Crutchlow bike and so don't want to part with it. It's cost someone (Gary Eckerold?) over £20,000 to originally build, looking at the price of all the mods on it!! So it's a bit special.
Dave.
PostPosted: 13:32 - 19 Feb 2015    Post subject: Reply with quote
Dave.
In my view you have three options with this bike:
1.) Sell it to a racer who will use it
2.) Race it
3.) put it in your living room as an ornament.
It seems a waste to keep such a highly tuned and probably highly strung bike as a track day only bike. It's like keeping a St Bernard in a top floor flat.
PostPosted: 14:42 - 19 Feb 2015    Post subject: Reply with quote
Not sure how it'll compare to a newer bike for racing, but it probably makes even less sense to race it - as you still won't be up to newer tuned bikes and will more likely need to spend more cash for the sake of having a slower bike.
I might consider selling the engine if it was mine, if I could get a good price.
Oh and St Bernards don't actually need THAT much space - often littler more energetic dogs that need the space to run around Smile.
RedPanda
PostPosted: 15:33 - 19 Feb 2015    Post subject: Reply with quote
I think this thread needs pictures.
CBF125 (2013) -> CBR600F (2001) -> 'Ninja' 300 (2014)
The last post was made 11 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 88.24 Kb
