Zinc plate on exhaust to stop rust?
Ribenapigeon
PostPosted: 18:59 - 06 Feb 2015    Post subject: Zinc plate on exhaust to stop rust? Reply with quote
I noticed the exhaust box is getting a bit rusty on my XJ6. If I clamped a bit of zinc onto it would that work to stop the rust. I know this method is used on ships and drilling rigs but can it work on a bike?
Copycat73
PostPosted: 19:08 - 06 Feb 2015    Post subject: Reply with quote
as wit many things the theory is spot on but in practice the effect is minimal ... unless you call your bike ss titanic or summit the like..
otherwise try summit like
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0&_nkw=zinc+paint+for+steel&_sacat=0
then spray wit vht. paint ontop.
caveat emptor
RhynoCZ
PostPosted: 19:15 - 06 Feb 2015    Post subject: Reply with quote
It won't help, if the rust is there, it'll rust under the layer of the zinc, I'm afraid. You'd need to get the piece perfect clean before you do the procedure.
I'd rather get some ''rust-eating'' paint instead. Thumbs Up
mjn51
PostPosted: 20:44 - 06 Feb 2015    Post subject: Reply with quote
Only if you're going to immerse your bike in salt water, will this work!
Ribenapigeon
PostPosted: 22:19 - 06 Feb 2015    Post subject: Reply with quote
Wont getting regularly wet with water from the road count? Say if I attached a 10cm x 2cm x 3mm plate of zinc to the can underneath were road spray will wet the plate and the exhaust? Surely Il get the neccesary circuit?
weasley
PostPosted: 10:04 - 07 Feb 2015    Post subject: Reply with quote
It'll only form a galvanic circuit with any areas immersed in a continuous run of salt-laden water. It would need to be galvanised fully; dipped or sprayed.
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 47.12 Kb
