KTM Duke 2 Smoking (oil)
KevTM
PostPosted: 17:51 - 06 Feb 2015    Post subject: KTM Duke 2 Smoking (oil) Reply with quote
I'm having problems with my 1999 Duke 2 as it's developed a smoking habit.
I deduced the problem to valve stem seals so I did the necessary, got them changed. I took the head to an engineering shop and left them with the seals to change for me as I couldn't get a spring compressor to do the job myself!
The bike runs fine again but still has the smoking problem. Here's the run down:
It doesn't smoke when first started.
Doesn't smoke when cruising along.
Smokes the worst at idle after having run the bike a bit and you do get a puff if you blip the throttle.
High gear under load it doesn't smoke so much
Smokes constantly if you full throttle up the gears
Staying in a low gear coming down a steep gradient then blipping the throttle tends to give a fair puff of smoke.
This would still lead me to believe it's the valve stem seals (did the shop change them?) rather than piston rings etc - I could be wrong.
Any ideas? Thanks in advance for any help as it's really a bit of a pain now!
Iain.
PostPosted: 12:23 - 07 Feb 2015    Post subject: Reply with quote
You had the head off and diddn't change the rings anyway? Confused
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 36.56 Kb
