Speedfigher 2 100cc bad starting for my charity bike ride :)
Scrappygit
PostPosted: 12:30 - 07 Feb 2015    Post subject: Speedfigher 2 100cc bad starting for my charity bike ride :) Reply with quote
First things first, I bought a real cheap 2008 speedfigher 2 100cc moped as me and a few friends are doing a charity bike trip from landsend to John o'groats on mopeds that cost no more than £200 in September for cancer research. For abit of fun and to raise money for a great charity that so many people have been effected by.
Ok I've picked up a speedfigher 2 100cc and I've got a few issues. When I bought the moped it was running. I got it home tried to start it the next day and no joy, I got a new battery, spark plug and cleaned the carb out. And the only way I can get it started is if I use abit of carb cleaner to get it started by spraying it in the carb. The immobilisers works good as light goes out. I've not got a manual to check carb setting etc for adjustment. What tests can I do on the auto chock? Can I just power up the auto choke and see if it moves to check that it works? I've got fuel and spark but it just won't start without carb cleaner being sprayed into to the carb. Also many wiring issue that ive also fixed from previous bodged repairs lol. I'm a car mechanic by trade but very realy work on bikes. Any help would be great. Cheers
CaNsA
PostPosted: 12:34 - 07 Feb 2015    Post subject: Reply with quote
you weren't rememeberingsester of red rings most spreader of awarenessings.
Scrappygit
PostPosted: 12:38 - 07 Feb 2015    Post subject: Reply with quote
Thanks for the reply lol
Iain.
PostPosted: 16:14 - 07 Feb 2015    Post subject: Reply with quote
Break it up a bit Shocked
Sounds like not enough fuel in the carb...have you tried running it from a seperate gravity fed tank?
Scrappygit
PostPosted: 16:35 - 07 Feb 2015    Post subject: Reply with quote
Sorry mate thanks for the reply. I've not tried that yet but the vaccume fuel tap seems to be working as I've tested it and seems to be all ok.
mentalboy
PostPosted: 16:48 - 07 Feb 2015    Post subject: Reply with quote
It's not too clear but I'm assuming the bike will run once it's had it's carb cleaner dose?
Does it not start either when it's hot or cold?
How does it react to throttle once it's running?
Is the plug looking as though it's suffering from a lean mixture?
When you cleaned the carb what exactly did that entail? Did you just spray carb cleaner in there or strip it totally? If the latter was there any significant amount of cleaning required?
What state was the carb mounting gasket in? you haven't overtightened it have you (If I recall these are hard mounted to the engine and have a nasty plastic gasket, correct?)
Make mine a Corona.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:00 - 07 Feb 2015    Post subject: Reply with quote
Scrappygit wrote:
vaccume
Nice try but your attempt just made you look stupid
Triumph Sprint ST 1050
Scrappygit
PostPosted: 21:26 - 07 Feb 2015    Post subject: Reply with quote
yeah the bike runs and revs good once started and it makes no difference if its hot or cold it just wont fire up inless it has it's carb dose....
the plug looked good neither lean or rich.
i removed carb, all jets, and float, it was not dirty to be honest but used an air line and carb cleaner to clean through all jets etc, and made sure it all went back as i found it.
the carb on my speedfight is not hard mounted with a gasket its different to the 50cc that are hard mounted.
Scrappygit
PostPosted: 21:32 - 07 Feb 2015    Post subject: Reply with quote
Nobby the Bastard wrote:
Scrappygit wrote:
vaccume
I did not realise it was wrong until then!
please don't reply if you haven't got anything good or helpful to say.
Nemo
PostPosted: 21:41 - 07 Feb 2015    Post subject: Reply with quote
Was it sat for a while before you got it? Stale fuel?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
bypass2
PostPosted: 22:25 - 07 Feb 2015    Post subject: Reply with quote
Is the petrol cap vent blocked. Vacuum pipe split. Auto Choke not working.
Scrappygit
PostPosted: 03:00 - 08 Feb 2015    Post subject: Reply with quote
Yeah it was sat up for about a month so I was told but ive also removed all the fuel and cleaned the vacuum fuel switch and the fuel pipes are good. put fresh fuel in the tank.
What the best way to test the auto choke? Can I just remove and then put a 12v feed to it to see it it moves?
Also has anyone got the factory settings for the carb?
pdg
PostPosted: 10:26 - 08 Feb 2015    Post subject: Reply with quote
It's a SPEEDFIGHT you chavvy gimp.
Not a 'speedfighter', or
Scrappygit wrote:
speedfigher
That is all.
(I didn't bother to read any more.)
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
nowhere.elysium
The Pork Lord
PostPosted: 10:49 - 08 Feb 2015    Post subject: Re: Speedfigher 2 100cc bad starting for my charity bike rid Reply with quote
So. You bought a shitter, and discovered that it's shit. You then elect to name-drop a charity on a forum that's historically been notably hostile to charity touts.
This thread will not go in the direction you want it to.
veroom
PostPosted: 11:44 - 08 Feb 2015    Post subject: Reply with quote
Come on guys, if you can help, help, if you can't don't.
Sorry scrappy, I'm lacking the mechanical skillset but good luck getting sorted for your venture.
GSXR 600 - Got bike, must pass test, wish me luck.
Scrappygit
PostPosted: 12:06 - 08 Feb 2015    Post subject: Reply with quote
Can someone please delete this thread. I only came on here for some advise thank you very much for the people that have helped with suggestions but for the people who have been sarcastic and want to be like children just grow up. I might have spelt a couple things wrong but come on is there any need for it? won't be coming on here again..........
pdg
PostPosted: 21:35 - 08 Feb 2015    Post subject: Reply with quote
I've seen thicker skins on pre-packed custard.
Edit to add:
https://img1.wikia.nocookie.net/__cb20140303003450/creepypasta/images/5/5a/Flounce.jpg
and
https://i370.photobucket.com/albums/oo141/bramble43/flounce_oneniner.jpg
etc.
DanRLee
PostPosted: 22:10 - 12 Feb 2015    Post subject: Reply with quote
Tried popping the air filter off, completely covering the carb opening with your hand and see if it starts up?, I had this problem with an old street fighter I had years back and ended up installing a bodged manual choke.
Six Strings & Two Wheels!
Nobby the Bastard
Harley Gaydar
PostPosted: 22:15 - 12 Feb 2015    Post subject: Reply with quote
How will bodging a choke help with this? A choke covers in intake in the same way that the throttle does.
What this will do is show that the air filter is either blocked of missing. Sticking your hand over the intake will limit the air getting in.
DanRLee
PostPosted: 22:19 - 12 Feb 2015    Post subject: Reply with quote
Yes.
WD Forte
PostPosted: 23:52 - 12 Feb 2015    Post subject: Reply with quote
For a 'car mechanic by trade' I'd have thought a wee single cylinder bike would have been a peice of piss as the fundemental principals are the same.
Squirting anything down the inlet instead of proper fault finding
is bad practise. tut tut!
I'd allow it as a get you home/garage measure but that's all
bikers smell of wee
mentalboy
PostPosted: 02:20 - 13 Feb 2015    Post subject: Reply with quote
WD Forte wrote:
For a 'car mechanic by trade' I'd have thought a wee single cylinder bike would have been a peice of piss....
...I just assumed OP to be a Halfords/Kwikfit 'car mechanic'
Make mine a Corona.
The last post was made 11 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 113.81 Kb
