| billybaggins |
 billybaggins Renault 5 Driver
 Posted: 20:22 - 08 Feb 2015 Post subject: ZZR600 E3 few niggles |
Hi , haven't posted in here for a while, i've picked up a cheap, rough 1995 zzr600 with 65k miles to use for the rest of the winter. Some issues ill list if anyone can help with
1. Downshifting from a couple of gears is very stiff, almost have to hold clutch in for a few seconds until revs die down to be able to shift. I have adjusted clutch cable tonight so will get out on it in the next couple of days and see if that has any effect. Any other ideas?
2. Throttle won't spring back all the way on its own. Cable seems pretty free, my only thought is the grip is very worn and a bit out of shape so its maybe rubbing on bar end etc therefore resisting a bit, ill maybe take the grips off my vf500 to try. Any other ideas or any ideas on how to remove an awkward tight grip.... cut it off etc and lube up the new one?
3. Brakes.... the front one feels a bit notchy, eg i put it on from say 40mph and its sort of on-off-on-off but not majorly, just jerky. 1 pad is quite worn where the other 3 aren't so bad, could this affect it? Fluid level is fine, but not sure how to check if theres air etc in there.
Rear brake works when rolling bike forward though when riding it barely works, pads are good, disc is good, lever feels fairly normal although slightly hard towards the end... any ideas?
4. Front wheel is quite badly corroded, not much green paint left on it. What is the best method to smooth this before I paint it so as the paint will stick?
5. Idle was low, ive now cranked it up, but when it was low there was a rumble noise from engine area, then when I pulle din the clutch lever the rumble went, is this a sign of a clutch basket being loose of plates needing replaced?
Cheers for any help in advance, dont want to spend much money on it as shes old and for winter. Just want it safe and a bit smoother |
| mentalboy |
 mentalboy World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
| billybaggins |
| mentalboy |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
 Posted: 16:05 - 09 Feb 2015 Post subject: Re: ZZR600 E3 few niggles |
I'll try and help with my limited experience with the exact model of the bike you have - slightly lower mileage though.
1. Downshifting from a couple of gears is very stiff.
When was the oil last changed? Our bikes can get a bit upset with gear changes with crappy oil and also check chain tension. When my chain gets a bit too slack, the gear shifts get clunky.
Check the grip like you mention, if the bar end hasn't been off before, be careful you don't shear the bolt - use an impact driver if you can, the threadlock makes it REALLY tight.
I assume you have the stock Tokicos? I had my bike for around 2 months before the brake lever got notchy, almost like there were 3 levels of braking. They are notorious for their demand in maintenance, keeping the pistons nice and clean. These are commonly upgraded to Nissin 4 pots - like I have done which can be neglected more without serious detriment and notchiness of the lever.
Can't help here.
5. Idle was low, ive now cranked it up, but when it was low there was a rumble noise from engine area.
Mine gives a rumble while cold, when it's warm it's better but as has been mentioned they can be tractorific
Take home - Keep on top of cleaning the brakes, and if you ever have to bleed the brakes, make sure you have a full day free. ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 21:10 - 11 Feb 2015 Post subject: Re: ZZR600 E3 few niggles |
| billybaggins wrote: | Hi , haven't posted in here for a while, i've picked up a cheap, rough 1995 zzr600 with 65k miles to use for the rest of the winter. Some issues ill list if anyone can help with
Mine feels like that if I've put off an oil change for too long + chain adjustment / lubrication not great
| Quote: |
tried lubricating cables? Checked cables at carb end?
| Quote: |
What brakes are on? It's common to change from the Tokos or whatever they are to Nissin's my front brake feels a bit notchy as the speed drops, cleaning and maintaining helps with the feel - one of my disks has a slightly wider spot somehow, apparently not uncommon as the disks wear. Having one cylinder stuck at 45deg in it's barrel didn't help much - it's better following a re-build!
Rear brake should float but often seizes up causing pad wear on one side but not the other and feeling vague, clean and copper slip moving parts
| Quote: |
| I thought a bit of rumble from the gearbox in neutral was normal, just like the agricultural 'clunk' as it goes into 1st ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
The last post was made 11 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
