Pan euro electrics.
Marmalade
PostPosted: 23:29 - 08 Feb 2015    Post subject: Pan euro electrics. Reply with quote
I fitted heated grips, charge plugs and alarm to my pan euro.
Ran it for 10 mins to make sure grips got hot etc. turned it off and refitted the panels.
Now it won't start.
It has power at ign switch, it powers lights, indicators, dash etc when on but no live to the coils, ECU, start button or fuel pump.
Putting in a temp live to the coils powers up the pump etc and it'll run.
Any suggestions?
pdg
PostPosted: 23:34 - 08 Feb 2015    Post subject: Reply with quote
Is the killswitch in the right position? Wink
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 08:54 - 09 Feb 2015    Post subject: Reply with quote
You've checked the fuses, right?
Taught2BCauti...
PostPosted: 10:21 - 09 Feb 2015    Post subject: Reply with quote
Apart from the Kill Switch and Main Fuses, also check the 30A fuse on the Starter Relay.
The coils should get power from the ECM, so check it to see if you are getting 12V on the Black/White wire.
If not, a sensor is possible faulty - Side Stand Switch, Bank Angle Sensor Relay, Clutch Switch, or the Fuel Cut-Off Relay.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Skudd
PostPosted: 10:44 - 09 Feb 2015    Post subject: Reply with quote
Have you done a compression test? That seems to be the new answer to anything these days.
I would disconnect all you have done and put bits on, bit by bit until the fault is found. It may just be too much stuff. fuses would be the first thing for ma as would wires in the right places.
barrkel
PostPosted: 11:58 - 09 Feb 2015    Post subject: Reply with quote
Check main connector blocks for fried wires.
davebike
PostPosted: 12:37 - 09 Feb 2015    Post subject: Reply with quote
Witch Pan?? 1100 is very different to 1300
ST1100 multi block connector in to Starter relay and main fuse on starter relay is the usual suspects
ST1300 the earthing point under the back of the tank is the common fault
Dave
NC750Xdct + others at work !
[email protected]
Marmalade
PostPosted: 01:03 - 12 Feb 2015    Post subject: Reply with quote
it's in neutral so it's not stand switch, it normaly turns over when the kill switch is off so it's not the switch, same with the bank sensor, which is laying in the garden somewhere.
It was running for 10 or so mins after fitting the bits on, I turned it off to refit the panels.
When the main wires burn on the relay, or the 30a fuse blows, it kills everything.
The ignition comes on, the dash all works properly, headlights work, horn, brakes etc, Just no starting or turning over.
barrkel
PostPosted: 02:07 - 12 Feb 2015    Post subject: Reply with quote
A wire fried in the connector block just below the fuse box on my VFR took out the headlights - just the headlights, nothing else. Corrosion in the connector block contacts increases resistance, causes high temperatures, sparking, burns out wire. I'd be trying to isolate wires / blocks specific to the starter.
But you've been around a lot longer than me, I'm not telling you anything new.
Marmalade
PostPosted: 21:51 - 13 Feb 2015    Post subject: Reply with quote
Yes. Fuse box been out, replaced every fuse on the bike as a matter of course.
Tested all power on back of box and a few mods previously made, air box out, all main wiring plugs checked.
Had a cold and got lung infection at the mo so not spending any time outside.
soon as I do, it'll be a wiring bridge from fuse box to the dead side of fuel pump relay. That should power up everything that's missing.
tatfan
PostPosted: 22:58 - 13 Feb 2015    Post subject: Reply with quote
It's not the alternator failed is it? They can stop the engine dead in its tracks when they go.
Marmalade
PostPosted: 15:56 - 14 Feb 2015    Post subject: Reply with quote
If they are left parked for weeks at a time, they can rust and seize.
It'd still click and have power to the relevant parts. you can take them out and still run on the battery.
tatfan
PostPosted: 18:33 - 14 Feb 2015    Post subject: Reply with quote
Mine was fine one day, dead the next. Kris thought it had dropped a valve. He's a shit mechanic.
bugeye_bob
PostPosted: 18:47 - 14 Feb 2015    Post subject: Reply with quote
is there a immobilizer fitted at all ?
PostPosted: 22:58 - 14 Feb 2015    Post subject: Reply with quote
Given this, the obvious answer is a wire trapped under a panel either broken or shorting.
Easily done.
misscrabstick
PostPosted: 00:50 - 15 Feb 2015    Post subject: Reply with quote
Starter solenoid, 4 wire plug comes out of it, has a ignition live in it, found mine all melted looking and hot, rewired around it, worth a look.
Marmalade
PostPosted: 01:18 - 15 Feb 2015    Post subject: Reply with quote
As above, The ignition comes on.
Matt B
PostPosted: 11:37 - 15 Feb 2015    Post subject: Reply with quote
Isn't there a relay as well as the sensor though, if still in there maybe the relay is FUBAR?
Stinkwheel seems right - sounds like something got pinched or pulled when it went back together.
I reckon you must have seen this already, but just in case:
https://www.sharetheexperience.co.uk/ST1100/18%20Ignition%20system.pdf
PostPosted: 12:50 - 15 Feb 2015    Post subject: Reply with quote
Easily done.
I'll give you a good example of how esoteric this can be.
I once has a problem with my KLE500, the oil pressure warning light would stay on, flicker then go out as you revved up the bike. I was pretty convinced this was an electrical issue but what? I was convinced it must be a short somewhere.
I started by taking the plastics and tank off one at a time and trying it after each. Finally, I took the sump bash guard off and it started working properly. Put it back on and it happened again. Now this is very odd because there are no wires anywhere near the bash guard, I'd mainly removed it to check the idiot switch wiring.
Turns out I'd fitted a new exhaust a few weeks previously. I'd had a pannier resting on the exhaust prior to the fault occurring. This had shifted the exhaust mid-section slightly so it pushed against the bash guard which in turn deflected it against the end of the oil pressure switch plunger, pushing it in and making the light stay on until there was enough pressure to force it out against the exhaust (at higher revs). Removing the bash guard allowed the exhaust to move away from the switch.
So. What I'm saying is you need a methodical approach and to check for success after each step. I'd start by taking off all the plastics/bodywork/componants you did last time, one at a time and checking in between.
I'd then disconnect the parts you have added one at a time. Then I'd go to the wiring diagram and systematically check each wire that could be preventing the system working.
Mentally I find an approach of "find where the electricity stops" is a good one. So with a voltmeter, one end connected to earth, I work my way along the circuit until I find the point there is no longer a voltage when there should be. Say it was your fuel pump circuit: Power at fuse? Power into relay? Power out of relay? Power at fuel pump? If all those are yes, the fuel pump should be on. FInding where the power stops helps localise the problem.
Marmalade
PostPosted: 16:43 - 17 Feb 2015    Post subject: Reply with quote
Finally, now I can breath unaided after a lung infection, I got the haynes book of lies and went through the loom, following wiring digram.
It was a section between fuse box and ecu which I was targeting but this included start switch, cut off switch, tilt sensor, relay and all the wires connecting.
Turned out, it was a broken wire in the loom that would have gone to the tilt switch (if it still had one)
I cut out the plug, connected the wires directly and it's all good.
Wired in new clocks while I was there and it's ready to go.
https://i881.photobucket.com/albums/ac17/Marmalade43/st1100/35C8925F-C217-42E9-B1BB-9E179CACB633_zpsw1ywdnse.jpg
https://i881.photobucket.com/albums/ac17/Marmalade43/st1100/D7173668-0EF2-4C6C-AF7F-B47E1D7E454A_zpsgozfvwpe.jpg
The last post was made 11 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 116.62 Kb
