| Pol Anorl |
 Pol Anorl Banned
| Aff |
 Aff World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| andym |
 andym World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| Rogerborg |
 Rogerborg nimbA
| Carvel |
 Carvel World Chat Champion
| mudcow007 |
 mudcow007 World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:29 - 10 Feb 2015 Post subject: |
shirley that would read wrong as the hoses are different lengths so lining all 3 up would make them different |
| andym |
 Posted: 00:46 - 10 Feb 2015 Post subject: |
The last one I made was 2 bits of hose in 'U' shapes.... which technically I only ever used 1.
Anyway, since I don't have any hose or fork oil (and having the carbs out for a bloody good clean) I've just shone a torch through the butterfly valve and got them all as equal as possible.... I may post a video of how crap the bike runs |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 02:10 - 10 Feb 2015 Post subject: |
Best method I have seen is using one u loop of tube to balance all four cylinders from the base cylinder. Ie no 2 is base cylinder. So 1 & 2, then 2 & 3, then 2 & 4 etc ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 02:29 - 10 Feb 2015 Post subject: |
Has anyone any experience of this contraption? If it works as well as the reviews it would be worth forking out 17 quid just to avoid the messing about with a DIY setup. ____________________ Make mine a Corona. |
| Pol Anorl |
 Pol Anorl Banned
| mentalboy |
| andym |
| orac |
 orac World Chat Champion
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 10:50 - 10 Feb 2015 Post subject: |
had a set for a number of years... they are fine. ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| cb1rocket |
 Posted: 14:07 - 11 Feb 2015 Post subject: |
Your balancing against the non adjustable cylinder so balancing 3 and 4 for example would be an error. The non adjustable carb is the base for balancing and should be set against that as its just that you can't set no. 2. It does differ from bike to bikes i believe. Triple cylinder bikes are easy, it's the same process ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| cb1rocket |
 Posted: 14:15 - 11 Feb 2015 Post subject: |
As taken from that 17 quid ebay advert
This amazing Carb Balancer can synchronise 2,3 and 4 cylinder bikes. Start with the base cylinder and any other carb, then subsequent carbs. The base cylinder is the carb with the throttle stop/tick over screw. This carb does not have a synchronisation screw, as the throttle stop screw is its only adjustment. Repeat the process to super synch your carbs.If your carbs are badly out of synch your engine will be under terrific extra strain as your pistons are working hard against each other, and not with each other, sapping vital power and fuel. No matter how much throttle you apply the weaker working cylinder will allways lag behind, sapping the power from the harder working piston! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| trisers |
 trisers Scooby Slapper
| orac |
| mentalboy |
| raak |
 raak Spanner Monkey
 Posted: 17:08 - 12 Feb 2015 Post subject: |
| Copycat73 wrote: |
had a set for a number of years... they are fine. |
a good investment.
had mine several years also.
use em to and set up carbs at least once a year...£30 well spent.  ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| johnsmith222 |
 johnsmith222 World Chat Champion
The last post was made 11 years, 240 days ago. Instead of replying here, would creating a new thread be more useful? |
