CBR125R 2005 Problem Cold Start
danbeer1991
PostPosted: 22:27 - 10 Feb 2015    Post subject: CBR125R 2005 Problem Cold Start Reply with quote
Just under 9000 miles 2005 carb model
Each morning i go to start up my bike atm it is rather cold outside and has been struggling but i have noticed one or two days if i have had a lye in and havent tried starting my bike till miday or later and it has warmed up a bit around the bike is still the same and struggles but once started will be fine for the rest of the day bearing in mind i ride to work in the morning and it is left until i go home or sometimes on my breaks.
From the start when i got this bike it used to start with no problem with the choke and to keep it going a little revs then after about 2-3 seconds it would splutter like it wanted to die and it was really cold and didnt like it, i would turn the choke down with the revs on a little bit and then the choke back up and it would get past the cold spluttering and let me warm my bike up and then work fine from there and for the rest of the day would have no problem starting or warming up only when left over night or a very long period. i found a nak to do it as to my knowledge it shouldnt have been like that but if i didnt keep it alight and it did cut out it would be hard to start again with choke on or off, its like it was struggling to stay alight it was getting worse so i changed the spark plug got a new air filter got a new fuel filter also got the valves tightened timing checked cleaned my jets cleaned my carb checked my fuel lines it seemed a bit better but still couldnt just leave it to warm up
but now i start the bike with choke on it starts fine when cold i give a little rev to keep it going it wont splutter it will just cut out after 2-3 seconds even with me trying to keep it alight with choke on or off and with revs and when it cuts out it is really hard to start and wont let me bump start it
is it possible that something little could have worn away on something that could be causing this problem? When i first got the bike i could get it past it and that was when it was really cold, it is cold now but no where near as cold and it has got worse
Once i have got it past that and it cuts out and i get it alight with a struggle and struggle to keep it alight it will let me warm it up like normal and be fine all day even left for a good few hours to get cold again either way i have never just been able to leave it to warm up i have got to get it past that first bit but now a days that isnt a option it just cuts out, i used to be able to get it past that messing around with the choke on / off
I understand a bike will cut out sometimes if it is cold but not constantly everytime even when you are trying to keep it alight at first i was blaming it on the cold weather but it is rediculous it is constant all the time and its the same ruitine everytime hoping it does start to get to work but it starts perfect the first time just dies, can anyone help me i hope you can understand im not too good at putting words into writting
thanks dan Thumbs Up
PostPosted: 22:43 - 10 Feb 2015    Post subject: Reply with quote
Full choke, keep it there while you put your lid on and ride away gently.
danbeer1991
PostPosted: 22:47 - 10 Feb 2015    Post subject: tryed it Reply with quote
tryed it it wont even let me get to that it just cuts out
PostPosted: 22:58 - 10 Feb 2015    Post subject: Reply with quote
Carb clean?
danbeer1991
PostPosted: 23:04 - 10 Feb 2015    Post subject: Reply with quote
Paddy. wrote:
Carb clean?
i have said above i have cleaned pretty much everything and i have tried pretty much everything i can think of, These where my first thoughts so tried it and still havent found a solution
PostPosted: 23:08 - 10 Feb 2015    Post subject: Reply with quote
Are you a spacker... Confused I'm actively helping you and you are rating my posts, incorrectly Laughing
I've owned tons of these. None ever had this issue.
Cold, 1/8th throttle, full choke and starter.
el_oso
PostPosted: 09:17 - 11 Feb 2015    Post subject: Reply with quote
After cleaning the carb on my one I haven't had any issues at all getting it started. I'd be checking that there is fuel in the bowl. Then I'd be checking the spark. Then I'd be re-cleaning the carb paying close attention to the jets in case of blockages.
Duke 390
Car: Jeep Wrangler 4.0L
finchy95
PostPosted: 10:17 - 11 Feb 2015    Post subject: Reply with quote
Are you 100,000% sure you reassembled the carb properly? I understand there's a few small fiddly parts (jets and such)
2005 suzuki van van - Sold. -> 2015 honda cbr 125 r - current bike.
Now's not the time for fear. That comes later.
danbeer1991 This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Simba76
PostPosted: 13:43 - 11 Feb 2015    Post subject: Reply with quote
Wow.
Good luck getting decent reply now.
I know you're frustrated, but theses guys and gals are just trying to hel pand without having the bike in front of them they are pointing you in a particular direction.
If you want to get it fixed, take it to a garage and pay your money.
But I guess from your post you would rather try and sort it yourself, and rightly so.
If that is the case, let people give their help.
If you dont like it......The doors over there.
If you can keep your head while all around are loosing theirs....you're probably in some sort of Zombie movie!
-Current bike ......
danbeer1991
PostPosted: 14:02 - 11 Feb 2015    Post subject: Reply with quote
i appreciate everyones help but i just felt as if i was repeating myself.
i wrote what i did above to try and avoid the obvious solutions which i have already tried.
i have asked the shop but its a matter of give it a go and see if it sorts it and didnt really want to waste £100's when it could be something very simple. i was just wondering if anyone has experienced simular problems. Thanks
el_oso
thing is, there really isn't that many parts to a small single cylinder engine.
My guess is still a blocked pilot jet and you just haven't cleaned it well enough. Let us know how you get on. We might pretend to care.
Duke 390
danbeer1991
PostPosted: 14:16 - 11 Feb 2015    Post subject: Reply with quote
i accept help, i am willing to accept all answers but i clearly stated whats wrong and then some plank comes along and states what i have already said, he obviously didnt read anything i said so dont stick up for other people i am far from fustrated i just dont need planks coming along and stating the obvious telling me to put lid on and choke i have clearly said that doesnt work.
Why would you write on my post just to stick up for other people and not give some helpfull advice
PostPosted: 14:22 - 11 Feb 2015    Post subject: Reply with quote
Rolling Eyes
OK, so I've had LOADS of these and could probably rebuild one from a box.
If it doesn't run with the way I've said, you need to recheck the carb, check the air filter and the airbox>carb pipe.
While you are there check or replace the vacuum pipe to the tank.
I don't care if you've already done it, do it again as evidently it didn't work.
PostPosted: 14:24 - 11 Feb 2015    Post subject: Reply with quote
It sounds like you're demanding a solution that doesn't exist.
A blocked pilot jet seems to be a common issue on these bikes and it's what I'd be checking, along with the inlet rubber and any vacuum gubbins.
Yes, it's been cleaned - maybe - but if it got blocked once, then it's likely to get blocked again.
Did you clean the jets yourself? Did you do it thoroughly? Or did you take someone else's word that they'd been done?
How's your tank? If you drain the carb, is there any crud at all in the fuel? It doesn't take much to block a pilot jet.
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 87.61 Kb
