what do you think of those brake pads?
Orennayar
PostPosted: 13:30 - 08 Feb 2015    Post subject: what do you think of those brake pads? Reply with quote
Hi all,
Recently my front brake became really squeaky when braking so I decided to check if they were worn or something, I couldn't see the indicator groove so I took of the whole thing to have a look and that's what it looks like.
I can't find any groove in there so my guess is they need changing asap but on the other hand it looks like the pads are still quite thick so I don't really know what to think of that.
Any suggestions?
https://i.imgur.com/tNvWlc9l.jpg
DAS passed: 21/07/14
2011 YBR125(sold)
2009 XJ6N
cb1rocket
PostPosted: 13:51 - 08 Feb 2015    Post subject: Reply with quote
Loads of life. As for the squeaking noise, its probably because the caliper needs a clean esp the pistons and slide pins need regreasing. Otherwise looks good to me
PostPosted: 13:55 - 08 Feb 2015    Post subject: Reply with quote
Not all pads have indicator grooves. Unless I am missing something in that pic the pads look almost unworn.
Give everything a good clean up and put a bit of copper grease on the BACK of the pads (ie, between the pads and the caliper piston).
Skudd
PostPosted: 14:53 - 08 Feb 2015    Post subject: Reply with quote
Just clean it and put all back. Brakes make noises from time to time.
Orennayar
PostPosted: 15:04 - 08 Feb 2015    Post subject: Reply with quote
thanks for the replies, I just wanted to double check Thumbs Up I thought all brake pads had indicators though.
I'll have a look at regreasing the pistons etc.. I guess all the recent riding in the wet and salt didn't help Confused
2011 YBR125(sold)
2009 XJ6N
Islander
PostPosted: 16:14 - 08 Feb 2015    Post subject: Reply with quote
Try a smear of copper grease on the back of the pads. Thumbs Up
talkToTheHat
PostPosted: 02:02 - 11 Feb 2015    Post subject: Reply with quote
Just don't overdo it with the copper grease, thin film where the metal backing pads touch the caliper. Not gobs of it. I found ferodo organic pads really noisy. Brembos kind of make a whooshing noise unless my caliper is really shocking, then they squeal a little.
And clean the solidified black dust before you throw more grease at it all. And copper grease or high temp brake greas only or you will die a horrible death.
Bandit. does. everything.
Ed Case
PostPosted: 10:06 - 11 Feb 2015    Post subject: Reply with quote
The reason for squeaking brakes often is because of dust worn off the pad material. It's worth wiping the discs with a piece of kitchen roll or clean cloth wetted with methylated spirit as this leaves no residue. Your pads incidentally look almost new.
talkToTheHat
PostPosted: 16:00 - 11 Feb 2015    Post subject: Reply with quote
Or brake cleaner if you're posh or in a rush. Convenient aerosol can. About £3 from small automotive suppliers. I get away with keeping some under the sink at the girlfriend's, in my mother's garage, and have trained my car driving friend to keep some under the guise of occasionally fixing the brakes on his cars or various bits of studio equipment.
Note that some transfer of pad material to disk may be required for optimal brake performance and most brakes self clean in optimal conditions. Salty and grease mess with this.
DrDonnyBrago
PostPosted: 16:29 - 11 Feb 2015    Post subject: Reply with quote
Look almost new to me.
Orennayar
PostPosted: 17:28 - 12 Feb 2015    Post subject: Reply with quote
Thanks for the advice. I gave the brakes a good clean and now the noise seems to be gone Thumbs Up
2011 YBR125(sold)
2009 XJ6N
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 67.79 Kb
