xj600s
Draco87
PostPosted: 23:27 - 11 Feb 2015    Post subject: xj600s Reply with quote
Hi guys, I have a 1998 Yamaha diversion which has a couple of issues, i need to replace a couple of the shins on the intake and rebalance the carb. But the issue im confused about is once its been run for about 20 miles and turned off, there is a large puddle of brown fluid underneath and is coming from the breather pipe from the air box, it smiles like fuel and have looked in the aitbox which is wet could this be an issue with the shins being too worn out and dragging too much fuel through and why would it turn brown?
Fisty
PostPosted: 23:50 - 11 Feb 2015    Post subject: Re: xj600s Reply with quote
Your bike has shins and has a smile like fuel??
Fatter and faster than Fret
pdg
PostPosted: 23:59 - 11 Feb 2015    Post subject: Reply with quote
If your current shins are worn they are obviously going to need replacing.
To make the new shins last longer you can get guards for them
https://www.drjessesaenz.com/wp-content/uploads/2013/07/adidas-f50-tech-shin-guards.jpg
And then, if you slap it hard enough that should soon wipe the smile off it's face.
(the stuff coming out of the airbox is likely a fuel/oil mix and shouldn't be happening)
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Major Doss
PostPosted: 08:39 - 12 Feb 2015    Post subject: Reply with quote
Take the tank off and clean out all the breather hoses. This is a common problem on divvies.
Draco87
PostPosted: 11:23 - 12 Feb 2015    Post subject: Reply with quote
Thanks man Thumbs Up I will be doing this today so hope all goes well Smile
Moo.
PostPosted: 14:11 - 12 Feb 2015    Post subject: Reply with quote
The breather hose is clogged with emulsified oil, will look like white jizz. Clean it out the air box, and replace it with a length of garden hose. A well know mod over on the divvy forums.
The reason it gets blocked is because the hose gets kinked because its rubber. A garden hose is much more rigid, fitted one to mine and it fixed the problem.
A2 Passed 18/6/10
Draco87
PostPosted: 17:14 - 12 Feb 2015    Post subject: Reply with quote
I've just finished stripping all the hoses off and cleaned them through your right though it looked liked it had more fun on a Friday night than average does lol. Gonna take it out for a spin later this evening and check its ok now Smile
The last post was made 11 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 58.19 Kb
