Tutoro oiler - type of tube.
defblade
PostPosted: 00:39 - 12 Feb 2015    Post subject: Tutoro oiler - type of tube. Reply with quote
I've got a Tutoro oiler, I use the twin feed nozzle with it.
The first one got eaten by the sprocket as I forgot to check after the garage changed my tyre.
The I ran with the single nozzle for a while, but it wasn't enough for winter. So I ordered a couple more. They're not cheap, and I fitted one tonight and it had vanished 40 miles later Sad So I think I'll try and make my own up.
Here's a picture (you can click on it to zoom):
https://www.tutorochainoiler.com/index.php/store-mobile/accessory-reptwin-detail
I've found the y splitter on ebay, can anyone guess what type of tube it is? Approx 3mm or 3.2mm OD, quite thin walled, obviously a bit of a stretch over the 3mm splitter, holds the curve well but is quite flexible at the same time.
It's NOT silicone! Quite thin walled.
I'm starting to wonder if it's heat shrink, shrunk down over a curved former?
PostPosted: 10:33 - 12 Feb 2015    Post subject: Reply with quote
Halfrauds do Y splitters in 8mm or 6mm for £2.79. Another couple of lengths of tube with wire stiffeners in them, and wedge some pices of cable tie up the tube for the final feeders.
Would be my ghetto bodge.
Might go to Halfrauds today.
davebike
PostPosted: 13:22 - 12 Feb 2015    Post subject: Reply with quote
I a dealer fro Tutoro but don't do the twin sided despensor May be as I had so much greaf with the scottoiler version :=)
If it is just the same tube as the main line from the oiler mail me and I pot a bit in the post
Just looked on the site looks more like Scot oiler vacume tubing
From them it is about £7 +P&P
Dave
NC750Xdct + others at work !
[email protected]
defblade
PostPosted: 14:02 - 12 Feb 2015    Post subject: Reply with quote
It's definitely not the same tube as the main line - much less flexible. It's not scotoiler tube of any type, either (I've had 2 of those before.
It did work really well while it worked!
defblade
PostPosted: 17:00 - 12 Feb 2015    Post subject: Reply with quote
A bit of playing about in the shed, and I'm fairly sure it's 5mm heatshrink. I haven't got a bit long enough to test this with at the moment, but I think it's one loop that is heated onto 2 of the connectors, then cut.
Anyway, off to ebay to order a small pile of connectors and heatshrink Smile
Fisty
PostPosted: 17:08 - 12 Feb 2015    Post subject: Reply with quote
#scottoilermasterrace
Fatter and faster than Fret
defblade
PostPosted: 18:32 - 12 Feb 2015    Post subject: Reply with quote
I'm sorry, I'm old, I have no idea what you just said/meant...
temeluchus
PostPosted: 19:35 - 12 Feb 2015    Post subject: Reply with quote
I ended up not fitting any nozzle and having it drip onto the rollers just before the sprocket.
Ed Case
PostPosted: 23:20 - 12 Feb 2015    Post subject: Reply with quote
I had a tutoro or whatever it's called...........binned it......crap !.
C1REX
PostPosted: 02:33 - 13 Feb 2015    Post subject: Reply with quote
I swapped twin one for a single one. Works better for me.
I really can't notice any less oil on the other side of the chain and it's some much more convenient.
MCForum meetup - One of the biggest motorcycle clubs in UK
The Tot
PostPosted: 11:49 - 15 Feb 2015    Post subject: Reply with quote
Had Tutoros on my 6R - fine. On the FireBlade, the twin delivery got chewed up much in the same vain as yours did. I switched to a single side. The after 3 or so years, the reservoir got gunked up and stopped working. Not sure if engine oil and whatever polymers they used to make the thing had caused it to swell and seize up.
Either way, going Scottoiler now.
Never argue with autism
defblade
PostPosted: 00:04 - 22 Feb 2015    Post subject: Reply with quote
If anyone's interested, definitely 5mm heat shrink. Use about 7cm each side, curve them together while warm and blow them cold while you hold them. Save about £6 a go.
The last post was made 11 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 74.3 Kb
